Transistor FM Superhet -Initial experiments
« First 12
  1. #11
    audioguru audioguru is offline
    A 455kHz IF transformer is narrow-band for communications.
    A 10.7MHz IF transformer is wideband for low distortion and wide frequency response for FM stereo receivers.
    0
  2. #12
    Nigel Goodwin Nigel Goodwin is online now
    Super Moderator
    Quote Originally Posted by transistor495 View Post
    Dual conversion FM receivers use 10.7(or more) first IF and 455KHz second IF to achieve better selectivity. Still with hi-fi audio.
    Sorry, complete nonsense - dual conversion is for communication receivers, the reason for it is to give low bandwidth voice quality only.
    A 455KHz IF is FAR too low to give decent bandwidth or HiFi quality.
    AG seems to have his own warped opinion about anything that isn't full HiFi quality, and while communication receivers can give excellent voice quality (which is their reason for being) HiFi it isn't, and doesn't want to be.
    Coincidently, there's no 'magic' reason for 10.7MHz IF - it's simple a compromise giving reasonable selectivity, reasonable bandwidth, at a reasonable cost and ease of manufacture.
    With modern filters (rather than pre-WWII transformers) you can make receivers that greatly exceed the performance of 10.7MHz IF receivers, in every aspect. Many more modern communication receivers get their greatly improved performances from far higher IF frequencies.
    0
  3. #13
    I was never an amateur radio HAM.
    In North America local telephone calls are free for any duration and sound better or the same as narrow band radio so I never used radio communications except for cell phones and FRS walkie-talkies.
    0
  4. Thread Starter #14
    transistor495 transistor495 is offline
    Well, not that easy
    I was having a hard time getting this one working though, I had some results with severe overloading and lots of stability problems.
    Within a 5 meter circle, I can move around to get a somewhat clear reception, I had noticed this with other portables also, but in my case its much severe, I've attached front-end RF amp though.
    But all I can say now is I got the basic superheterodyne principle working for FM demodulation, but need more experiments to prove a nice working receiver. Also I'm running bit out of time.
    So signing-off temporarily from this now and will update this thread after some time.
    0
  5. #15
    Ramos Ramos is offline
    G'day guys!
    I've carried out some quick experiments after the arrival of my new RF Signal generator/counter. This is one of that. A transistorized FM superhet receiver which can demodulate and output broadcast band FM stations.
    But the interesting thing is that I have started with a basic Medium Wave receiver circuit with 455KHz two stage IF and basic germanium diode AM detector. This one was a big success and I could receive the local AM stations clearly and apparently I got surprised a bit on how beautiful is the so called 'superheterodyne' principle!
    The next stage was to remove the oscillator/mixer and detector part from the working receiver to actually convert it to an FM receiver. So I've added a simple charge pump FM demodulator consisting of 2 BC547's and a BF494 wired before the IF stages as a simplest mixer. Being connected with just a 5" antenna at the emitter of the transistor and Signal Generator output injected to the base in place of LO, let me say I'm quite surprised that the system could clearly receive couple of strong local FM stations nearby.
    For 102.3MHz, I've injected around 102.9MHz to tune in the station clearly.
    No tuned input circuits employed as of now and the whole circuit is powered using 3V(2xAA cells)
    Next part would be to add an RF amp and LO so that to achieve a stand alone working FM receiver and I feel pretty confident that that would be so simple actually!
    Below is the current status on breadboard, and you can see the signal generator outputting 102.9MHz used for ~455KHz down-converting for the receiver.
    Cheers!
    Attachment 60034
    would you please post the schematic?
    Here is what might be interesting for you too:
    http://philsvalveradiosite.co.uk/phi...receiver_1.htm
    http://www.vk2zay.net/article/250
    http://www.youtube.com/watch?v=1q1NVZNNuiA
    0
  6. Thread Starter #16
    Quote Originally Posted by Ramos View Post
    Well, never noticed this reply ;-)
    Those articles indeed looks interesting, but mine was to prove it with an easiest/simplest circuitry -perhaps I may need to conduct few more crude experiments and study. I'm ready to re-open the strategy -well..the curiosity never ends, sometimes the results will be horrible though
    0
  7. #17
    A breadboard is usually not used for radio circuits because its stray capacitance between the many rows of contacts and between all the wires is far too much. The many long wires cause interference within the circuit and they pickup all kinds of external interference.
    For many years, 10.7MHz crystal filters have been used in the IF of an FM radio instead of 10.7MHz transformers.
    0
  8. Thread Starter #18
    I was getting into the track by doing a simple AM Superhet by using a single BF494 mixer+converter and a YS414 IF amp+detector. It works fine. This can be one of the simplest Superheterodyne designs. It has built in AGC provided by the chip. Audio is clean but it lacks the full punch which I assume because of YS414 has only output for a crystal earphone. I may need pre-amplification of the audio before sending to the power amp. But the current setup is still acceptable though.
    Very quick experiment. Thanks for looking, cheers
    0
« First 12
A 6 transistor-6 IC dual-conversion superhet SW receiver radiomate Electronic Projects Design/Ideas/Reviews 2 22nd August 2008, 05:35 AM
Transistor Operation ElectroMaster Electronic Theory 1 23rd June 2006, 04:26 PM
Transistor as a switch ARIVOUKARASU General Electronics Chat 3 21st January 2004, 07:24 PM
Transistor base voltage/current? hantto General Electronics Chat 1 8th January 2003, 04:25 PM
help with transistor snidekht General Electronics Chat 3 7th January 2003, 05:28 PM
Page Time: 0.13657 seconds      Memory: 7,627 KB      Queries: 17      Templates: 0
