Old 8th July 2004, 08:23 AM   #1
Default flash uC
what is the meaning of In circuit programmable (ISP) flash memory.I found tat one of the uC is equipped with this feature.what can i do with it?is it RAM or ROM?
LCY
louislu is offline
Old 8th July 2004, 08:43 AM   #2
FLASH memory is an alternative ROM to EEPROM. It is usually used as program memory in microcontrollers, although they may also be used for data memory. They are definitely not RAM, though they are reprogrammable.
In-circuit programmable is a feature which makes the programming of the FLASH memory very convenient. The flash memory can be programmed while the microcontroller is in its own circuit. The circuit would have to be slightly modified to enable ISP, and the programming pins are pulled out to a socket, where it may be connected to a programmer.
checkmate is offline
Old 8th July 2004, 10:08 AM   #3
thanks for help...so that ISP can provide a very convenient programming way right...emm...how if i want to design something that need to store user's phone number.can i make use of this ISP flash.means writting to it n read it back....
I found a debugger on web...reads51.anyone who used this before...Is it compatible to the chip tat i gonna to use...atmel 89s51
Thanks very much
LCY
louislu is offline
Old 8th July 2004, 11:08 AM   #4
Usually you wouldn't store data like that in program memory, you would use EEPROM data memory, many micro-controllers have internal EEPROM data memory for that very reason.
I don't use Atmel processors, but lots of PIC processors provide various amounts of data EEPROM, usually between 64 bytes to 256 bytes. I would expect the Atmel processors to be similar.
Old 9th July 2004, 05:13 AM   #5
what is MCS 51 language...every microcontroller manufacturer using the same MCS51 language? thanks
LCY
louislu is offline
Old 9th July 2004, 06:30 AM   #6
YOu would need external EEPROM to store large amount of data
I havent heard of MSC51 before.. but I do know about C 51. It is a C compiler for 8051 family microcontroller
StupidDum is offline
flash
