Hi, I'm trying to get my head around the PIC stuff.
I have written code in MPLAB IDE and been trying to simulate it with PIC Simulator IDE trial from Oshonsoft.
I have even copied some codes from the datasheet but it doesn't help.
Here is my code:
My chip is supposed to have RA0-RA7 as digital inputs and RB0-RB7 as digital outputs, running with internal clock at 4 Hz (MHz? KHz?)Code:LIST P=PIC16F819 #include <P16F819.inc> ;processor specific variable definitions radix hex errorlevel -302, -207 __config _INTRC_IO & _CP_OFF & _DEBUG_OFF & _WRT_ENABLE_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF DC MACRO N MOVLW (3*N) CALL DELAY ENDM ; DD MACRO N MOVLW (1*N) movlw 0x1A ;AV|PSU|RDY|MB|AMP|xxx=011010 >turn RDY on movwf PORTB CALL REARDELAY movlw 0x13 ;AV|PSU|RDY|MB|AMP|xxx=010010 >turn RDY off movwf PORTB ENDM ; CBLOCK H'20' COUNT1, COUNT2, COUNT3, COUNT4 ENDC ; ORG H'00' ;*******************SETUP CONSTANTS******************* ;* Azrudi Mustapha: Shutdown Controller & Rear switcher V2.0 ;* OREN - RA1 - IGNITION - HI 5V ;* KUNING - RA0 - REAR - LO 0V ;* COKLAT - RB1 - AMP EN - HI 5V - turns AMP EN on ;* HIJAU MERAH - RB2 - MB ON - HI 5V turns switch on ;* PUTIH GREY - RB3 - READY - HI 5V turns it on ;* MERAH TEBAL - RB4 - PSU ON - HI turns it on ;* PURPLE BIRU - RB5 - AV SW - HI switches VID ;* ;***************************************************** CLRF INTCON CLRF PCLATH ; ensure page 0 is used GOTO INITIALIZATION ; go to beginning of program ORG H'04' retfie ;******************************************************* ;** ;** ;** DECLARATION & INITIALIZATIONS ;** ;** ;******************************************************* ORG H'05' INITIALIZATION ; enable below to enable interrupts ; bsf INTCON,7 ;GIE – Global interrupt enable (1=enable) ; bsf INTCON,4 ;INTE - RB0 Interrupt Enable (1=enable) ; bcf INTCON,1 ;INTF - Clear FLag Bit Just In Case banksel PORTA ;select BANK of PORTA CLRF PORTA banksel ADCON1 MOVLW 0x06 MOVWF ADCON1 MOVLW 0xFF MOVWF TRISA ;set RA0-RA7 as inputs bsf STATUS,5 ;switch to bank 1 movlw b'01100000' ;clock is 4 kHz movwf OSCCON movlw b'00000000' ;8 bits of PORTB are output movwf TRISB bcf STATUS,5 ;switch back to bank 0 CLRF PORTA CLRF PORTB ;initialize COUNTx registers, this is used upon program execution only, ;after this automatically reset to 0xFF upon subtraction from 0x00 movlw 0xFF movwf COUNT1 movlw 0xFF movwf COUNT2 movlw 0xFF movwf COUNT3 movlw 0xFF movwf COUNT4 ;******************************************************* ;** ;** ;** START OF PROGRAM ;** ;** ;******************************************************* ;initialize OUTPUT state movlw 0x00 ;AV|PSU|RDY|MB|AMP|xxx=000000 >turn RDY off movwf PORTB DC 1 Start TUNGON: movlw 0x08 ;AV|PSU|RDY|MB|AMP|xxx=001000 >turn RDY on movwf PORTB DC 1 BTFSS PORTA,1 Goto TUNGON movlw 0x10 ;AV|PSU|RDY|MB|AMP|xxx=010000 >turn PSU on movwf PORTB DC 2 ; 2 sec delay movlw 0x1C ;AV|PSU|RDY|MB|AMP|xxx=011100 >touch MB switch movwf PORTB DC 1 ; 1 sec delay movlw 0x10 ;AV|PSU|RDY|MB|AMP|xxx=010000 >release MB switch movwf PORTB DC 3 movlw 0x12 ;AV|PSU|RDY|MB|AMP|xxx=010010 >turn AMP on movwf PORTB DC 2 TUNGOFF: movlw 0x1A ;AV|PSU|RDY|MB|AMP|xxx=011010 >turn RDY on movwf PORTB DC 1 movlw 0x12 ;AV|PSU|RDY|MB|AMP|xxx=010010 >turn RDY off movwf PORTB DC 1 BTFSC PORTA, 1 Goto TUNGOFF DC 5 BTFSC PORTA, 1 ;check if really want to turn off Goto TUNGOFF DC 3 movlw 0x16 ;AV|PSU|RDY|MB|AMP|xxx=010110 >press MB switch movwf PORTB DC 1 movlw 0x12 ;AV|PSU|RDY|MB|AMP|xxx=010010 >release MB switch movwf PORTB DC 5 movlw 0x10 ;AV|PSU|RDY|MB|AMP|xxx=010000 >turn AMP off movwf PORTB DC 5 goto Start ;******************************************************* ;** ;** ;** Subroutines ;** ;** ;******************************************************* DELAY ;197ms delay decfsz COUNT1,F goto DELAY ;disabled the next 2 lines for faster monitoring in simulator ;decfsz COUNT2,F ;goto DELAY BTFSC PORTA,0 ;if PORTA,0 is 0 then skip next line call REARACTIVE ADDLW -1 BTFSS STATUS,Z goto DELAY return REARACTIVE movlw 0xFE ;AV|PSU|RDY|MB|AMP|xxx=1000 0000 movwf PORTB goto REARACTIVE DD 2 BTFSS PORTA,0 ;if PORTA,0 is 0 then return ;return DD 4 movlw 0x32 ;AV|PSU|RDY|MB|AMP|xxx=110010 >Switch AV on movwf PORTB DD 1 movlw 0x12 ;AV|PSU|RDY|MB|AMP|xxx=010010 >Switch AV off movwf PORTB DD 2 ;wait for rear to go off, meaning RA0=HI WAITREAR DD 2 BTFSC PORTA,0 Goto WAITREAR movlw 0x32 ;AV|PSU|RDY|MB|AMP|xxx=110010 >Switch AV on movwf PORTB DD 1 movlw 0x12 ;AV|PSU|RDY|MB|AMP|xxx=010010 >Switch AV off movwf PORTB DD 4 movlw 0x32 ;AV|PSU|RDY|MB|AMP|xxx=110010 >Switch AV on movwf PORTB DD 1 movlw 0x12 ;AV|PSU|RDY|MB|AMP|xxx=010010 >Switch AV off movwf PORTB DD 2 return REARDELAY ;197ms delay decfsz COUNT3,F goto REARDELAY ;disabled the next 2 lines for faster monitoring in simulator ;decfsz COUNT4,F ;goto REARDELAY ADDLW -1 BTFSS STATUS,Z goto REARDELAY return end
With the above code, RB3 lights up after 2000usecs as it should.
Now I should input 5V to either RA0 or RA1, and RB1-RB4 should light up (LEDs are connected to the RBx's thru NPN BJT configuration. However, nothing changes and RB3 continues to be lit up with no other pin on PORTB showing any change.
I took this code from the Microchip datasheet:
Now, wierdly, if i change the second last line to:Code:banksel PORTA ;select BANK of PORTA CLRF PORTA banksel ADCON1 MOVLW 0x06 MOVWF ADCON1 MOVLW 0xFF MOVWF TRISA ;set RA0-RA7 as inputs
then the inputs start to work.. I have not been able to test whether the whole circuit works with this yet, but shouldn't I set the pins to 1 to signify it as input?Code:MOVLW 0x00 MOVWF TRISA
p/s sorry for my english, its not my first language. Hope the meaning gets through!
