Old 6th November 2009, 01:47 PM   #1
Default LCD time setting code.
Hi all,
I hope all are in good health and spirits.
I wrote this code last night for my lcd clock/calendar. It works fine but maybe there is a more efficient code to achieve the objective. When setting the time the user can toggle the cursor betwen the tens of hours and the unit hours positions and increment the respective value. The code is to prevent any illegitimate values, i.e. any value more than 23.
Is there more efficient code you could suggest? With the benefit of hindsight it may have been more straightforward increment the hours value as a whole rather than as individual digits. But this is where I am at now.
Thanks in advance for any help / suggestions.
Increment_value
    movlw  high Digit_goto      ;get PCLATH at this location
    movwf  PCLATH               ;update PCLATH
    movf   cursor_cnt,w         ;no. of times user has right shifted cursor
    andlw  0x07                 ;clear upper nybble
    rlncf  WREG,W               ;double it
    rlncf  WREG,w               ;and again (because of x2 pc increments)
    addwf  PCL                  ;add it (cursor shift count x4) to prog counter low byte
Digit_goto
    goto    tenhrs
    goto    unithrs
    goto    tenmins
    goto    unitmins
    goto    tendays
    goto    unitdays
    goto    tenmonths
    goto    unitmonths
    goto    tenyrs
    goto    unityrs
;CUMBERSOME CODE STARTS HERE!
tenhrs              ;increment the ten hours value - check for legitimate number
    incf    H10
    movlw   0x34    ;(4)
    cpfslt  H1      ;unit hrs < 4?
    goto    skip3   ;no, it's 4 or more so max value for tenhrs is 2 (23hrs max)
    movlw   0x32    ;yes, unit hrs less than 4 so 2 is valid value for tenhrs
    cpfsgt  H10     ;user trying to set tenhrs>2?
    goto    skip1   ;no, so unit hrs value irrelevant
skip3
    movlw   0x31    ;(1)
    cpfsgt  H10     ;tenhrs >1?
    goto    skip1
    movlw   0X30    ;set tenhrs = 0
    movwf   H10
skip1               ;write the tenhrs value to the lcd
    movf    H10,W
    call    lcd_char                    ;write tenhrs value to lcd
    call    R2C10                       ;cursor back to Row2 Col10 (tenhrs position)
    call    Wait_for_yell_butt_release
    return
unithrs ;increment the unit hours value - legitimate number? Depends on tenhrs value
    incf    H1          ;unit hours register
    movlw   0x32        ;determine if tens of hours is = 2, so
    subwf   H10,w       ;subtract 2 from tenhrs value
    movlw   0x33        ;3 = default max value for unit hrs
    btfss   STATUS,Z    ;was tenhrs = 2?
    movlw   0x39        ;no, max unit hrs value will be 9
    cpfsgt  H1          ;yes, unit hrs max will be default 3, compare with user value
    goto    skip2       ;write unit hrs value to lcd
    movlw   0X30        ;user tried to enter more than 3 when tenhrs = 2 so reset to 0
    movwf   H1          ;set unit hrs to zero
skip2               ;write the unithrs value to the lcd
    movf    H1,W
    call    lcd_char
    call    R2C11
    return
tenmins
    nop
unitmins
    nop
tendays
    nop
unitdays
    nop
tenmonths
    nop
unitmonths
    nop
tenyrs
    nop
unityrs
    nop
loiter
    goto    loiter
Angry Badger is offline
code, lcd, setting, time
code for setting int osc frequency tempus Micro Controllers 12 2nd September 2009 05:23 PM
Question on setting LCD up bryan1 Micro Controllers 6 29th March 2006 10:18 AM
Setting up LCD on 16f877a bryan1 Micro Controllers 2 3rd December 2005 09:54 PM
digital clock setting the time mode Jay Duluguin Electronic Projects Design/Ideas/Reviews 0 19th February 2004 11:09 PM
Setting several output-pins at a time, but not all egh01 Micro Controllers 2 25th September 2003 08:22 PM
