| | #16 | |
| No, with a 2.5K RESISTANCE it would, but it's not a 2.5K 'resistance', it's not really an impedance either. It's a high resistance/impedance input pin with a small capacitance across it, it's the charging of that capacitor which determines the maximum source impedance. Which was why I said you're wasting your time trying to simulate it in that way. Quote:
| | #17 |
using a 18F452 displaying wind speed and direction on 20x4 LCD using the transducer to measure/indicate the air pressure in the air cannon air chamber. using this data (wind speed, direction, muzzle velocity (two IR sensors 1 foot apart mounted on the barrel) then determind desired air pressure to hit targets at 30, 60,90 yards then shoot for distance. As far as the transducer doing any fast switching, I think not. All it's doing is indicating air pressure in the cannons air chamber. have a rotary switch to select which display I desire DISPLAY 1 = wind speed and direction DISPLAY 2 = air chamber pressure DISPLAY 3 = muzzle velocity after firing using the outputs of all this data, we should be able to determine what pressure to use for a desired distance. note the data specs on the transducer says the output is adjustable DS Series Custom Pressure Transducers | Pressure Sensors | Proportion-Air the transducer is a DSY-150 supply voltage 15-24v supply current min = 35ma output = 0-10v but is adjustable | |
| | #18 |
Right, so you're only using one analogue input - so it shouldn't matter too much. In any case, just use two 4.7K to make your attenuator. | |
| | #19 |
now theres a question why is it called attenuator.? another word for voltage divider output or ?? just waiting for 5:13pm today as the auction on the transducer is ending. these puppies sell for $200+ hoping for under $10 + $10 shipping. | |
| | #20 | |
It's called an 'attenuator' because it 'attenuates' the input. | ||
| | #21 |
Deb. PIC impedance is not 2.5k. The maximum recomended 2.5k analog voltage supply exists because of the Sample And Hold capacitor. If the impedance is too high, this capacitor will take too long to charge. | |
| | #22 |
YEA baby won the auction on transducer sells for $200+, got it for $18.50 with shipping on with design | |
| | #23 |
wonder if I need to de-bounce the selector switch? any suggestions? | |
| 24v, connecting, pic, transducer |
| Connecting a PIC | joellee | Micro Controllers | 6 | 27th August 2009 08:00 PM |
| Need help with connecting a CT to a PIC | tyru | Electronic Projects Design/Ideas/Reviews | 16 | 15th May 2008 04:11 PM |
| Connecting a Buzzer to a PIC | Gayan Soyza | Micro Controllers | 1 | 27th November 2006 06:58 AM |
| connecting DS1307 to pic | amindzo | Micro Controllers | 0 | 14th August 2006 12:17 PM |
| Pic driving ultrasonic transducer | mlt57sooner | Micro Controllers | 1 | 22nd April 2005 09:42 AM |
