Asalam o Alaikum... Dear All i want to make digital speedometer for my motrocycle Dayang 110-26 i want to know about the speed sensor .. which sensor i should use for speed sensing .. so that i read signal ..... | |
| | #2 | |
or are you going to use this for actual use ? I would suggest optical/IR transmitter receiver with a disc having holes. measure the number of rays coming per second and divide it by total number of holes. This will give you Revolutions per second. Then calculate RPM | ||
| | #3 | |
now plz can you tell me where should i install IR transmitter Receiver on my front tyre ? | ||
as the sensor will get dirt in it thus causing false readings. As I understand it most use a hall effect sensor. this uses a magnet attached to the wheel or other rotating object. determine circumference of wheel number of rotations for say 10 feet then calculate the time. there are electronic speedometers on Ebay as to build an accurate unit a micro-controller is suggested. | |
| | #5 | |
| | #6 | |
| | #7 |
just google bike computer or bike speedometer. then hall effect switches. here is a couple of links Simple Bike Computer HALL-EFFECT SWITCHES - Circuit Diagram - Forum - SeekIC.com the bike computer I think uses optical sensors but a hall effect sensor could be incorporated very easy. the second link diecribes a hall effect switch arrangement. reed switches could be used but are not as reliable or IMO as fast as a hall effect sensoe. look at automotive ingition systems - they mostly use a hall effect type sensor. good luck | |
| digital, speedometer |
| Digital speedometer | edzahid | Electronic Projects Design/Ideas/Reviews | 1 | 8th August 2008 11:09 AM |
| Digital Speedometer . | altra22 | Micro Controllers | 13 | 19th May 2006 06:48 AM |
| digital speedometer | navveed | Micro Controllers | 2 | 15th November 2005 03:04 PM |
| digital speedometer | navveed | Micro Controllers | 4 | 11th November 2005 12:11 PM |
| Digital Speedometer | mahesh_jo | General Electronics Chat | 6 | 19th July 2003 05:43 PM |
