+ Reply to Thread
Results 1 to 11 of 11
Thread: Unable to get interrupt from TMR0
  1. #1
    Monchichack Newbie
    Join Date
    Nov 2009
    Posts
    11
    Default Unable to get interrupt from TMR0
    I am not new to programming micro controllers but I have never got above the hobby level so everytime I revisit them I have to re-learn.
    I am currently having problems receiving an interrupt from TMR0. I have set up a small test program to test the interrupt and also the TMR0 interrupt flag (INTCON,TOIF) but neither seem to be triggering? It is embarrasing to say I have actually been staring at this for 2 days now which is probably my downfall in resolving this issue.
    Here is the code,
    I am sure I am making a stupid mistake and I would be grateful to anyone who points it out.
    list p=16F84A ; list directive to define processor
    #include <p16F84A.inc> ; processor specific variable definitions
    __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _HS_OSC
    w_temp EQU b'1010'
    timer1 EQU b'1011'
    timer2 EQU b'1100'
    status_temp EQU b'1101'
    org 00 ; processor reset vector
    goto Start
    org 04
    goto ISR
    Init clrf PORTA
    clrf PORTB
    clrf TMR0
    bsf STATUS,RP0
    movlw b'00000000'
    tris PORTB
    movlw b'00000'
    tris PORTA
    movlw b'11000111'
    option
    bcf INTCON,T0IF
    movlw b'10100000'
    movwf INTCON
    retlw 0
    Delay
    movlw D'44'
    movwf timer2
    del_loop1 movlw D'44'
    movwf timer1
    del_loop2 decfsz timer1,F
    goto del_loop2
    decfsz timer2,F
    goto del_loop1
    retlw 0
    ISR
    bcf STATUS,RP0
    movwf w_temp
    movfw STATUS
    movwf status_temp
    movlw b'00000000' ;if interrupt occurs PORTB is
    movwf PORTB ;cleared
    call Delay
    movfw status_temp
    STATUS register
    movwf STATUS
    swapf w_temp,f
    swapf w_temp,w
    bcf INTCON,T0IF
    retfie
    Start call Init
    Main call Delay
    bcf STATUS,RP0
    movlw b'00000'
    movwf PORTA
    movlw b'11111111' ;Sets PORTB on
    movwf PORTB
    call Delay
    btfss INTCON,T0IF
    goto Main
    bcf INTCON,T0IF
    movlw b'00000000' ;If TOIF bit is triggered PORTB is
    call Delay
    goto Main
    End
    Also,, while I have your attention:
    The final program I am trying to write is going to switch an output port on for 10ms - 9.99 seconds and switch it off for 10ms to 9.99s. Both periods need to be independently adjusted and displayed on 3 7-segment displays when doing so. I have the displys working but I am currently holding the code in 3 registers for hundreds, tens and units and my timer inc/dec will be in another 2 files which I am not sure how to link?
    Am I overlooking an easier way to do this program?
    Any advise would be appreciated.
    Thanks in advance
    Chris
  2. #2
    Wp100 Good Wp100 Good Wp100 Good
    Join Date
    Feb 2009
    Location
    England
    Posts
    262
    Not going to have chance to rewrite the code for you but a few pointers might help.
    Your ISR routine should be at Org 004 - so no need for the goto ISR
    Avoid using Calls from within the ISR, set a flag instead for doing things in the main code loop.
    Timer0 nornallly needs setting up with things like the prescaler, enable etc. as do the Interrupts - they need enabling too.
  3. #3
    Monchichack Newbie
    Join Date
    Nov 2009
    Posts
    11
    Thanks for the reply.
    I have moved my ISR and removed the call from within my ISR but I thought I have already set up TMR0 prescalers in the OPTION reg and enabled the TMR0 and GIE interrupts via the INTCON register? Is there another register I am overlooking?
    Chris
  4. #4
    Join Date
    Feb 2009
    Location
    England
    Posts
    262
    Sorry, missed those settings first time around.
    Your code is looking for the timer0 overflow by two means, by the ISR and direcly in your code by testing the overflow flag.
    If you run your code in Sim it never seems to get either overflow, but if you remove your Delay routine you can see it clearly is generating the overflow.
    Not sure yet why the ISR is not being inovked, but your code does need a lot of work.
    You might find this link / delay routines of use
    Delay Code Generator
  5. #5
    Monchichack Newbie
    Join Date
    Nov 2009
    Posts
    11
    Thanks for the delay code generator but I am strobing 3 7-segment displays which also double up as switch inputs and I hope to add more features as I progress so I would like to keep the delay independent from the code to prevent the LED's flickering etc.
    I chose to check for the interrupt via two means to help narrow down the problem (didnt help)..
    I know my code is inefficient and lacking technique but it is getting better (cant get any worse.
    I have tryed many things to get the interrupt working but it is as stubborn as I am and stopping me in my tracks so any help would be much appreciated.
  6. #6
    Join Date
    Feb 2009
    Location
    England
    Posts
    262
    Think you need to check your basics again, a couple of errors in your code like the 'Trisa PortA' and you seem to be defining your variables in the space reserved for the systems variables - see the memory map in the data sheet.
    Are you using a fairly recent version of Mplab ?
    Perhaps this tutorial will help with the ISR
    PIC Interrupts - Interrupt - PIC Microcontroller Tutorials - PIC Tutorial Resource - Connect to the PIC
  7. #7
    Monchichack Newbie
    Join Date
    Nov 2009
    Posts
    11
    I am aware of the Trisa PortA error but it still works and I have been unable to find a replacement command for it that works? I would be happy to know the new command for this function.
    I have been following the program structures from a book written by John Morton who includes his variables before the org command? It seems to have worked up until now but after absorbing the tutorial you pointed me to I think I will put an org command before them.
    I am using MPLAB v8.10.
    list p=16F84A
    w_temp EQU b'1010'
    timer1 EQU b'1011'
    timer2 EQU b'1100'
    goto Start
    org 04;interrupt vector
    ISR
    bcf STATUS,RP0
    movwf w_temp
    movfw STATUS
    movwf status_temp
    movlw b'00000000'
    movwf PORTB
    nop ;to make transitions easier to see on my ancient scope
    nop
    nop
    nop
    movfw status_temp
    movwf STATUS
    swapf w_temp,f
    swapf w_temp,w
    bcf INTCON,T0IF ;clear timer0 int flag
    retfie ; return from interrupt ENABLING GIE
    Start
    Init clrf PORTA
    clrf PORTB
    clrf TMR0
    bsf STATUS,RP0
    movlw b'00000000'
    tris PORTB
    movlw b'00000'
    tris PORTA
    movlw b'11000111'
    option
    bcf INTCON,T0IF
    movlw b'10100000'
    movwf INTCON
    Main
    bcf STATUS,RP0
    movlw b'00000'
    movwf PORTA
    movlw b'11111111'
    movwf PORTB
    btfss INTCON,T0IF
    goto Main
    bcf INTCON,T0IF
    movlw b'00000000'
    movwf PORTB
    nop
    nop
    nop
    goto Main
    End
  8. #8
    Monchichack Newbie
    Join Date
    Nov 2009
    Posts
    11
    This is my recent attempt but it still does not work?
    I expect to see PORTB go low for a period if the interrupt occured or if the T0IF bit was set.
    Any ideas?
  9. #9
    Monchichack Newbie
    Join Date
    Nov 2009
    Posts
    11
    I take it back.
    It is working now but pretty hard to capture on my scope without delays.
    Thanks for your time and pointers to some excellent resources!
    Regards
    Chris
  10. #10
    Join Date
    Feb 2009
    Location
    England
    Posts
    262
    You will be hard pressed to see / make use of timer 0 on a scope - try to use the Mplab Debuggers, Mplab Sim with breakpoints in your code as I did in that screenshot, it also allows you to single step through each line of code.
    The problem with your variables is their addresses, would suggest you always specify all eight bits doing it that way, it is however generally more common to address them in hex.
    Would also suggest against using timer1 and timer2 as names for those variables as they could cause confusion with the Pic timer1 and timer2 .
    your code
    w_temp EQU b'1010'
    timer1 EQU b'1011'
    timer2 EQU b'1100'
    for clarity try
    = w_temp EQU 0x0A
    but -
    If you look at the pic18f84a datasheet, memory section, you will see that the available user ram space starts at 0x0C, so you have been trying to overwite the systems variables - perhaps why things are not working.
  11. #11
    Monchichack Newbie
    Join Date
    Nov 2009
    Posts
    11
    Thanks WP100.
    Your advice is very helpful.
    I also took the time to sit down and give MPLAB sim a chance and have realised it is the way forward!
+ Reply to Thread
  1. TMR0 overflow within Interrupt. What will happen?
    By skyrock in forum Micro Controllers
    Latest: 24th May 2008, 08:46 AM
  2. 50% From TMR0 Interrupt
    By Suraj143 in forum Micro Controllers
    Latest: 6th November 2007, 04:02 AM
  3. Replies: 17
    Latest: 21st December 2006, 05:29 AM
  4. TMR0 interrupt for 16F84A
    By Thuria in forum Micro Controllers
    Latest: 8th December 2006, 07:49 AM
  5. TMR0 interrupt with 12C508A?
    By SnM in forum Micro Controllers
    Latest: 14th October 2004, 02:55 PM
Tags for this Thread
