Old 3rd November 2009, 12:50 PM   #1
Default Microcontroller
Hi
I am a postgraduate student and a beginner in micro controller
I need to design a PC interfaced electronic circuit to control relays. I feel switch design is straight forward. I got struck in interfacing the switch with PC.
Is it possible to do with micro controller ?. If it is yes could you please let me know the cheap Micro controller with basic capabilities ?.
I prefer USB interface
Regards
Faisal
pfaisalbe is offline
Old 3rd November 2009, 12:56 PM   #2
Maybe a stamp module or arduino is what your looking for, google those two (They are both usb).
Mike
My website: www.ElectroBird.net
birdman0_o is offline
Old 3rd November 2009, 01:10 PM   #3
I don't know about the ardunio but the Stamps are RS-232 [DB9] serial...
Mike2545
Mike2545 is offline
Old 3rd November 2009, 02:23 PM   #4
Hi
Many Thanks for your response.
I will explain my requirement more clearly. I have done Intel 8085 programming during undergraduate course. It was 10 years back.
Now I need to control relays via PC which means PC will send a command to an electronic circuit to energize relay coil and PC will send other command to deenergize the relay coil. Electronic circuit and relay is straight forward. I can do that.
My problem is how to communicate electronic circuit using PC.?
I guess micro controller together with PC can do that. Is there any alternate solution ?
If it can be done with Micro controller , I need to get familiar with Micro controller first. Can you suggest me where to start with micro controller?
Regards
Faisal
Old 3rd November 2009, 02:42 PM   #5
Try here if you like the Microchip PICs.
12F675 tutorial 3 : Adding a PIC Serial port.
mramos1 is offline
Old 4th November 2009, 04:39 PM   #6
A vote for Arduino. Communications with PC is very easy even for beginners. PIC has great flexibility that you probably do not need.
Russ Hensel is offline
Old 10th November 2009, 03:26 AM   #7
If parallel port is available, you can directly control relay from that port without using microcontroller.
shree-electronics.com - Abrreviations and microcontroller related stuff.
srikanthsamaga is offline
microcontroller
Looking for a microcontroller CloudedVision Micro Controllers 17 19th November 2008 05:00 PM
HOW TO INTERFACE A MICROCONTROLLER TO PIC17C44 microcontroller alsa7er Micro Controllers 2 4th February 2008 08:43 PM
how to interface a ADC 0809 TO MICROCONTROLLER AND THEN MICROCONTROLLER TO DECODER praneeth22 Micro Controllers 1 9th March 2007 07:20 PM
microcontroller prachi Micro Controllers 12 29th October 2005 07:15 PM
help about microcontroller -simon- Micro Controllers 6 12th January 2004 05:34 PM
