Hi, I have a hunch this may have been discussed on here ad nauseam but I can't seem to find the answer, so here goes... I'm trying to determine what options I have for providing for a firmware upgrade on a (18F) PIC based project. I'm talking about an upgrade that would be done by the customer in the field. I anticipate that the product we are creating would have feature enhancements down the road that we would want to offer an upgrade path to. I would prefer a hardware based option, but would like to hear about the software options for the learning aspect. By hardware option I mean something like an EEPROM in a socket that the customer could change in the field. (maybe it's as simple as sending a whole new PIC?) By software I mean anything that requires a laptop / downloading / Etc. My target customer base (plumbers, electricians, Etc.) is unlikely to have a laptop readily available, and that seems like a support nightmare anyway. If it matters, the project is planned as SMD. Curious as to how this is typically done. Thaks. | |
I would consider a micro-SD card as a firmware upgrade option. The SPI interface is easy to deal with, and there are SMT sockets. This presumes that the 18F can update it's own program memory. The system would work with or without the micro-SD card. If it is absent then the onboard code is a go. If it is there, but identical to the on board code the SD card is ignored. If the SD card is there and it is newer then an update takes place. If the PIC won't allow an in system program memory update I'm sure the Atmel rep will be glad to explain how the AVR might be of interest to you.
__________________ We never have time to do it right; but we always have time to do it over. | |
All 18F PICs support self programming. An SD card is a good end user option. Google tiny bootloader for idea on how the code looks for self programming. | |
| | #4 | |
One minor annoyance will be the realization that the most cost effective micro-SD card may have 4GB-8GB of memory which is several orders of magnitude more memory than you will ever need for firmware upgrades on a PIC18F. Another potential problem is that your firmware may be exposed to disassembly and reverse engineering.
__________________ We never have time to do it right; but we always have time to do it over. Last edited by Papabravo; 2nd November 2009 at 06:25 PM. | ||
| | #5 | |
So inserting the SD will result in a permanent upgrade? (a transfer) or will the system revert to the on-board program when the SD is removed? Since current prices on SD's are more than the PIC itself, what about sending a new PIC and have it in a socket, or is that not typically done? | ||
| | #6 |
I would use a dip and swap out the chip. The returns could be reprogrammed. If surface mount swaping a chip is out and you need field re programming. You will have to decide which trade offs look best to you.
| | #7 | |
Sockets for SMT chips mostly negate the reason for using those SMT chips in the first place. If you find a micro-SD card expensive check out the Emulation Technology website for SMT sockets. On another subject you referenced the folks who would be changing the chips. Are you seriously considering trying to train them in static electricity awareness so they don't destroy either of the chips they will be handling. I don't think you are looking at the economics correctly. At the time of manufacturing the cost is just the SD Socket. The cost and the ability to upgrade is then balanced against the utility of that upgrade. Gotta make sure the charges are in the correct column -- accounting wise.
__________________ We never have time to do it right; but we always have time to do it over. Last edited by Papabravo; 3rd November 2009 at 12:22 AM. | ||
| | #8 |
Micro-SD is fine, but be aware that the program will itself reside on the PIC chip. Programs cannot be run off the SD card. The self-programming function of the PIC must be able to read the SD card's file and program it onto the chip. Preferably not automatically because you don't want to have it reprogram itself every time it turns on. It's a touchy process, a bit slow, a power glitch during self-programming will scramble the ROM, and the PICs have a limited reprogramming endurance. You'll probably use a "secret" user input- like holding down the A and B button at the same time while powering on- to run the PIC in bootloader mode which does nothing but read off the SD card, program it into ROM, display "ROM updated" on the screen or whatever, and restart. You want to make the bootloader be what reads the A & B button thing during powerup as a separate piece of code in a write-protected Bootloader block. That way, even IF the power is cutoff before the ROM is completely written, the ROM is screwed and the main program can't run but the bootloader ROM will not be affected, all you have to do is cycle power with the A & B button held again and have it retry the load off the SD card. Get the bootloader right, because generally it's impossible for a bootloader update in the field to be able to rewrite the bootloader code itself. Not only would that defeat the goal of keeping the bootloader block safe from corruption from bad programming cycles (which would brick the device until you could plug a proper ICD into the header), but the code can't write the block the code is in without some very special tricks to ensure the memblock being written is not pointed to by the program counter. Be aware that once you distribute updates this way, you cannot easily protect the code itself. The code is a code image file on the micro-SD card you gave them. That can be read back with a file reader and disassembled to clone your product. Contrast with sending them a socketed chip with the Read Protect fuse bits set- even if you plug that chip into a PIC programmer, you can't read back the program space (although, for the highly advanced hacker, it is sometimes potentially possible to defeat this feature). They cannot clone that chip into an identical chip, nor can they disassemble the code to figure out what secret algorithms you might have used. Socketed chips are difficult for non-engineers to insert (bent pin 50% of the time), unless it's one of those PLCC sockets. Those are a bit expensive, fairly tall profile relative to an SMD, the number of chips available in such a package are less common, and even still you're not gonna want some nontechnical monkey rubbing their shoes on shag carpeting and sticking his finger in that while trying to bang the old chip out with a screwdriver.
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. Last edited by Oznog; 3rd November 2009 at 07:32 AM. | |
| | #9 | |
| | #10 | ||
The cost of the SD card itself would be charged to the customer (if and) when the upgrade ever happens. I see that the sockets have a "card present" switch, which could be used to initialize the boot loader routine.Quote:
Anyone have any resources to study up on simple encryption algorithms? Thanks. | |||
| | #11 | |
Mike. | ||
| | #12 | |
| I don't see how that will help someone, they won't have the hardware to run it. This is a piece of equipment that is close to $1K. Developing the hardware would be where the money is. The code is trivial. (hell, I'm writing it )Quote:
There are plans for a future version where the RTC would be needed. I have the SMT pads for a coin cell, but not populating at this time. Thanks | ||
| | #13 |
One other point I forgot to mention. A minimally adept customer might need only 1 micro-SD card to update multiple units, further reducing the cost impact if some fraction of your customers have multiple units. Google Search terms include "PGP" which stands for Pretty Good Privacy and "RSA" after the inventors Rivest, Shamir, and Adelman. They may not be the latest and greatest, but as you said they will impde the casual cloner. I am working on a similar project in the consumer audio arena and I may have some bandwidth available to contribute to the specifcation, design, and testing of either the hardware or firmware.
__________________ We never have time to do it right; but we always have time to do it over. Last edited by Papabravo; 3rd November 2009 at 04:30 PM. | |
| | #14 | |
| | #15 |
PGP is a really common but effective strategy. However, you will need to be able to implement the decoder IN THE BOOTLOADER. This may be a problem to fit into the protected bootloader block, and may even be too numerically intensive for the PIC to implement at all. The illegal copier guy would need to know how it's encoded, and have the numerical key for the decoder. And you'll keep that key in a read-protected part of the ROM. In PGP, even IF you know the decoding alorithm (like a copy of the bootloader code, if you grabbed a solution off-the-shelf), and a copy of the encrypted image file, there'd be little practical way to decipher the key and the image file even if he had the bootloader program without the specific key used. IF he could get the bootloader you used, and a key, he's be able to self-program any updates you issue to any number of cloned chips and you'd never be able to stop him unless you physically issue chips with a new key to customers and stop providing updates which use the old key. Of course you could always homebrew a "dumb" encryption method, such as swapping the even and odd bytes and then inverting every 3rd byte and adding +7 to every 4th byte. A cryptographer could figure that out fairly quickly if he searched for a text string known to show up on the display (thus almost certainly exists in ASCII form in the decoded ROM image) but an amateur would be hard-pressed to figure this out. Nobody said it had to be elegantly powerful, only to discourage casual piracy.
| firmware, options |
| Etymology of the word 'firmware' | astronomerroyal | Micro Controllers | 15 | 23rd March 2009 10:46 PM |
| firmware v software | wookiebai | General Electronics Chat | 6 | 8th October 2008 08:53 PM |
| 12F508 same as 12C508 firmware? | William At MyBlueRoom | Micro Controllers | 3 | 9th May 2006 12:59 PM |
| Writing firmware in PIC16F877 | Celestie84 | Micro Controllers | 4 | 8th June 2004 06:50 AM |
| Firmware | Bella | Micro Controllers | 0 | 26th October 2003 06:25 AM |
