Old 1st November 2009, 12:51 PM   #1
Default I2c EEPROM Read byte
Hi all,
I've used a PIC16f876a and could successfully write 128Byte (as LCD CHR codes) into 24C512 Eeprom, the problem rose when I try to read bytes back and display onto LCD.
when doing random read I can successfully read one byte from any where in the memory page, but after the first byte when i send ACK to read more, all i get is 0xff on all byte and LCD shows █. no matter what.
I'd appreciate any help.
Farshad
FarshadN is offline
Old 1st November 2009, 01:01 PM   #2
Are you sure you're using the right command to read the next byte?
straight answer, har har."
Sceadwian is offline
Old 1st November 2009, 01:55 PM   #3
Post your code. You must be doing something wrong but I can't think what it might be.
Pommie is offline
Old 4th November 2009, 11:52 AM   #4
here is my code:
as I mentioned the first read is fine but when it goes to the loop for next bytes it's wrong data display on LCD.
setup
bcf STATUS, RP0
clrf PORTB
clrf PORTC
bsf STATUS, RP0 ;bank1
movlw b'00011100'
movwf TRISC ; PORTC <4:3> as input
bcf STATUS, RP0 ;bank0
call INITLCD
clrf SSPCON
movlw b'00101000' ;init I2C with FOsc
movwf SSPCON
bcf PIR1, SSPIF ;init XT flag bit
clrf SSPCON2 ;init SSPCON2
clrf SSPSTAT
bsf SSPSTAT, SMP ;slew disable for 100KHz
bcf SSPSTAT, CKE ;SMBus disabled
movlw h'9'
movwf SSPADD ; 100Khz baud rate
movlw d'16'
movwf data_count
read_mode
bsf SSPCON2, SEN ; send Start
btfss SSPSTAT, S
goto $-1
btfss PIR1, SSPIF ;wait till Start completed
goto $-1
bcf PIR1, SSPIF ; clear TXflag bit
movlw b'10100000'
movwf SSPBUF ;set device address<0>write
btfsc SSPSTAT, BF ; check if buffer is empty
goto $-1
btfsc SSPCON2, ACKSTAT ; check if ACK received
goto $-1
goto $-1
movlw d'0'
movwf SSPBUF ; first word address
goto $-1
goto $-1
goto $-1
movlw d'5'
movwf SSPBUF ;second word address page0=0, page1=128
goto $-1
goto $-1
goto $-1
bsf SSPCON2, RSEN ;send Restart
btfss SSPSTAT, S
goto $-1
goto $-1
movlw b'10100001'
movwf SSPBUF ;set device address<1>read
goto $-1
goto $-1
btfss PIR1, SSPIF ; wait XT complete
goto $-1
data_read
bsf SSPCON2, RCEN ;I2C receive enabled
btfss SSPSTAT, BF ; check if buffer is full
goto $-1
goto $-1
bcf STATUS, RP0
movf SSPBUF, w
call LCDWRITE ;data to LCD
clrf SSPBUF
bsf STATUS, RP0
bcf SSPCON2, ACKDT ;ACK send
bsf SSPCON2, ACKEN ;init Sequel ACK
goto $-1
decfsz data_count, f
goto data_read
return
read_end
bsf SSPCON2, ACKDT ;NO acknowlege bit
goto $-1
bsf SSPCON2, PEN ;send Stop bit
btfss SSPSTAT, P
goto $-1
goto $-1
FarshadN is offline
Old 4th November 2009, 11:54 AM   #5
Hi
please have a look at my code.
thanks!
FarshadN is offline
Old 4th November 2009, 12:29 PM   #6
Too late for me now. If nobody answers before tomorrow I'll take a look.
Pommie is offline
Old 9th November 2009, 12:06 PM   #7
Hi Mike!
have you had time to look at my code. I also added a "btfsc SSPSTAT, R-W" check after the RCEN was set to slow down the loop, but still same problem all I get is 0xff on all bytes.
FarshadN is offline
byte, eeprom, eeprom read, i2c, pic 16f, read
Page-mode EEPROM - may I write a singe byte? atferrari General Electronics Chat 2 20th June 2009 08:19 AM
when pin goes 1, need to send 1 byte to specific telephone number and read it with PC miro_gt General Electronics Chat 2 16th April 2009 01:30 AM
Atmega EEPROM, does each location = 1-byte? pwotoole AVR 8 11th February 2009 08:26 PM
How to Read EEPROM without PC devigan Electronic Projects Design/Ideas/Reviews 4 19th May 2005 04:02 PM
i2c eeprom jijita Micro Controllers 3 19th July 2004 07:30 AM
