Old 29th October 2009, 05:02 PM   #1
Smile 16F72 digital clock
Hi all,
i am new to PIC. I am trying to create a digital clock with 16F72 and Hitech C.
I want to use timer1 in sleep mode with backup battery when the external power goes down..
I want to get precise timing for half a second to toggle second LED to make it blink once in a second. ie. half of a second in OFF condition and half of a second in ON condition so that i can see a proper blinking of 60 times in a minute.
Please suggest a crystal speed that i can use for this requirement with its prescaler. I dont like to set the timer1 with a initial value because it will cause precision errors in time.. i would like to use bresenhams method for timer to get precise timing. Please suggest...
GreenBeret is offline
Old 29th October 2009, 06:16 PM   #2
Originally Posted by GreenBeret View Post
Hi all,
can u provied it ckt dia.?
sahu is offline
Old 29th October 2009, 06:47 PM   #3
I dont have any circuit as of now... My idea is to connect PORTB to 7segment display parallely and scan segment using PORTA. I know we can use 32.768KHz crystal, but it will take 8seconds delay to overflow. I want to use this low speed crystal because of power saving... I wanted to 0.5 second notification for second blinking...
Old 29th October 2009, 06:54 PM   #4
Red face
i have F84 Miniature Real-Time Controller, but it is no usefull for u.
sahu is offline
Old 29th October 2009, 06:54 PM   #5
With no prescaler it should take 2 seconds to overflow. You can bsf the top two bits on the timer register to cause overflow every 0.5sec
bsf will not reset the prescaler.
Bill
Smart Kits build Smart People
Old 29th October 2009, 07:29 PM   #6
Thanks blueroomelectronics for your help.
Here i have some more doubts according to your method...
1. While setting top two bits, will i loose some instruction cycles and will it lead to precision errors..?
2. After each overflow, do i need to set the top two bit again.. meaning for each overflow, do i need to bsf two bits?
Old 29th October 2009, 07:35 PM   #7
Hopefully your clock is interrupt driven, you won't loose cycles as it'll set them when the count is very low in that register.
Bill
Old 29th October 2009, 07:43 PM   #8
Thanks a lot... I will try it and let u know.. As i am new to PIC, it will take me couple of days to complete the full pgm and circuit...
Old 29th October 2009, 11:58 PM   #9
Pic can use as little as 2ma -- no output ports, so you may not need sleep mode.
Russ Hensel is offline
Old 30th October 2009, 04:12 AM   #10
In sleep a PIC uses much less than 2mA, think uA
Bill
Old 1st November 2009, 05:44 PM   #11
Now i am facing a issue with my code. I enabled the PIE1<0> bit to enable timer1 interrupt. I am getting the interrupts for only sometimes, after that its not giving interrupt. I have a simulator software, when i test in that, i can see the PIE1<0> bit is getting cleared after some time... How this bit gets cleared automatically.. ? Pls help..
16f72, clock, digital
Digital Clock junaid766 Micro Controllers 8 9th December 2008 11:12 PM
digital clock xVorticity General Electronics Chat 5 28th October 2008 08:20 PM
Digital clock amsung2 Micro Controllers 22 5th August 2008 04:51 PM
Digital Clock Overclocked Electronic Projects Design/Ideas/Reviews 19 5th July 2006 10:06 AM
Digital Clock help Tom McCurdy General Electronics Chat 3 14th July 2005 03:48 AM
