Hey guys great news!!! Im making a Nokia 6100 Color LCD library. WIll use SPI BitBang , 12bit color per pixel. Here is a image of some progress: ![]() So far i have: CIRCLE, RECTANGLE, CHAR, STRING, BASIC COLORS
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
Very nice. I ended up destroying the connector on my 6100. Watch if you try to unplug it from the board. It's definitely a pretty little LCD and not too hard to develop for. Main problem I've seen is the complaints about the different versions. If anyone finds a really cheap source, I might get another one or two, but right now I haven't found a need to replace my old broken one.
__________________ Mark Higgins | |
Good job, where'd you get the LCD from though!
Sorry lol forgot... I got it from eBay.. Came on a noce board for $15 .. You can also get from sparkfun cheaper but no board .. I'm tired like crazy..I'll post links in a little bit
Here is mines: Nokia 6100 / 6610 Color LCD (PCF8833) (Espon S1D15G10) - eBay (item 130320476366 end time Oct-15-09 03:18:31 PDT) Its a PHILLIPS
| | #6 |
Never mind...
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 28th October 2009 at 03:20 PM. | |
| | #7 |
hey guys i ran into a snag. I need a BMP converter the only thing is i have this code written using 12bit color code and dont want to use 8 bit. This is a 8-Bit converter: How to: Nokia 6100 LCD (english) | Zipfelmaus - Blog Anyone know where i can get a 12-bit version or similar application.. Im sure i can make one in VB but heh dont have much time on my hands anymore.
| | #8 |
Hey guys check this out so far: ![]() Youtube: (maybe still loading) YouTube - Nokia 6100 LCD Test Non Youtube: http://atomsofttech.info/code/GEDC0020.MOV.MP4
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 29th October 2009 at 04:22 PM. | |
| | #9 |
Ok im working in VB6 and so far i can open a image and get the RGB of each pixel. Im not sure if im converting it correctly since i havnt tried it yet. But since the RGB is 4-4-4 for this LCD to be 12bit .... Im diving the 255,255,255 by 17 each this way the max of 255 is turned into 15(F)(1111) which is 4 bits. I hope this works heh.. Now i have to code the creation on data bytes. I need to connect every 2 parts together to make one byte and if then append a 0 to the end if need be (odd amount of pixel data) Wish me luck. Remember all the code and stuff will be shared and posted when complete or if i quite (most likely complete )
| | #10 |
How do you use VB to decompose an image into pixels :O
| | #11 |
its a nice api called: GetPixel
| | #12 | |
I am about to test out some hex it generated ill post a comment on it in a bit 24x9 bmp of 4 main colors RGB and Black Quote:
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 31st October 2009 at 01:47 AM. | ||
| | #13 |
RGB and black? What the heck colour pallet are you using? RGB at all FFs is white, RGB at all 00s is black, if you have a fourth colour it's either an alpha channel a mask or you badly mistyped something.
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 31st October 2009 at 01:12 AM. | |
| | #14 |
heh i mean im trying RED, GREEN, BLUE, WHITE and BLACK color image... I ran into a issue:: MAX = unsigned long the width and height = unsigned char Code: max = width * height; any thoughts????
| | #15 |
dude for this display it uses 4 bit color for each RGB so RED = 4 bit GREEN = 4 bit BLUE = 4 bit Now if pixel 1 is solid red you get F0,0 and if pixel 2 is solid blue you get 0F,0 but as decimals so thats.... 240,0,240 the way the lcd works is it will read the 2 bytes like RRRRGGGG,BBBBRRRR,GGGGBBBB = 11110000,0000,11110000 you see?
| 6100, library, nokia |
| Multisim Library | rahulshah | Datasheet/Parts Requests | 0 | 15th March 2009 02:12 PM |
| Rfid Library | ollakalla | Micro Controllers | 0 | 18th December 2008 07:02 PM |
| eagle library | fedail | General Electronics Chat | 19 | 14th October 2008 07:36 PM |
| Eagle Library | bababui | Electronic Projects Design/Ideas/Reviews | 13 | 9th May 2007 01:56 PM |
| Protothread library | Dan East | Micro Controllers | 0 | 7th October 2005 04:31 AM |
