| | #46 |
Jason: Excellent work, what is the approx size of the viewable screen for the 6100 | |
| | #47 |
Not sure of what your asking do you mean screen size in inches/mm or pixels? Pixels i think it is: 130x130 but not sure... i read: "The Nokia 6100 display has 132 x 132 pixels; Practically speaking, you cannot see the first and last row and columns." And from sparkfun website: Frame Dimensions: 1.35x1.58" Active Display Dimensions: 1.2"x1.2"
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #48 |
If anyone is strapped for cash on these (too expensive) LCDs then dont buy from sparkfun: SparkFun Electronics - Color LCD 128x128 Nokia Knock-Off Buy from ebay: NEW LCD DISPLAY SCREEN FOR NOKIA 6100 REPLACEMENT +TOOL - eBay (item 360153778485 end time Nov-04-09 20:55:10 PST)
| | #49 |
hey thanks for that question. I fixed a nice bug thanks to you. There was a overflow of pixels i didnt notice. But now you save a few hundred bytes on a full 132x132 image. Also you have to start on 1x1 not 0x0 for full images
| | #50 |
You might want to try to implement a very simple compression, like Run Length Encoding or LZW. It won't work with complex images, but the basic images could be compressed quite a bit, so you would need to be able to turn it off and on.
__________________ Mark Higgins | |
| | #51 |
heh i dont think im smart enough to do any compression but i think it would infact save a lot of space. For the full sized images especially is mostly 1 color.
| | #52 |
RLE seems quiet simple. I might use it.. Thanks for that. I'll check the other one now too
| | #53 |
Yes, RLE is really simple and it's easier to decode than encode, which is helpful. It's just that if your image gets too random the file can end up getting larger than the original rather than smaller. It would be easy enough to figure that out and just have the option not to use it in those instances, though.
| | #54 |
| | #55 |
No problem Bryan. Mark I this it would be simple to use the the 3rd byte of image data to test if RLE is on. I already use byte 1 and 2 for width and height. RLE should be simple in VB. Decompressing in a pic should also be simple I'll try it after work. If I get get sd stuff working it would help even more. I made some menu icons yesterday I'll take some pictures today and show everyone.
| | #56 |
i might skip the compression stuff for now as it seems like ill never get the SD stuff up and running ![]() Ill get back to it right after...
| | #57 |
| | #58 |
Here is my code for the LCD even forgot to post it. if you have trouble with it just ask me. Also the AVI: http://atomsofttech.info/code/GEDC0075.MOV.AVI
| | #59 |
New VB6 Program with major fixes heh still some bugs.. if a image comes out bad on micro side try closing vb app the opening it again and reconvert the image; http://atomsofttech.info/code/Nokia6100.zip http://atomsofttech.info/code/Nokia6100BIG.zip Now im off to dev some sd code heh
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 4th November 2009 at 05:32 PM. | |
| | #60 |
Making yourself an awesome cheap universal remote?? I might need to have a shot at this Last edited by birdman0_o; 4th November 2009 at 07:55 PM. | |
| 6100, library, nokia |
| Multisim Library | rahulshah | Datasheet/Parts Requests | 0 | 15th March 2009 02:12 PM |
| Rfid Library | ollakalla | Micro Controllers | 0 | 18th December 2008 07:02 PM |
| eagle library | fedail | General Electronics Chat | 19 | 14th October 2008 07:36 PM |
| Eagle Library | bababui | Electronic Projects Design/Ideas/Reviews | 13 | 9th May 2007 01:56 PM |
| Protothread library | Dan East | Micro Controllers | 0 | 7th October 2005 04:31 AM |
