Old 1st November 2009, 11:09 PM   #31
ok i got 8 bit mode and 12 bit mode working in VB6 now on to 16 bit
AtomSoft is offline
Old 2nd November 2009, 01:51 AM   #32
Originally Posted by Sceadwian View Post
That makes even less sense atom....
RGB....
All 00s == black. All FFs == white. There should be no separate bytes other than R G and B.
White made of R=255 + G=255 + B=255 / 8bit+8bit+8bit= 24 bit
Each color has 256 level, 0=off, 127 on 50%, 255 on 100%
He use half of it R max 15+ G max 15+ B max 15 / 4bit+4bit+4bit=12 bit
FF white only if you change all 3 channel "RGB" to FF
Csaba
I'm could be wrong many time's, at least I know what I'm doing.
http://shop.ebay.ca/merchant/csaba911
csaba911 is offline
Old 2nd November 2009, 01:53 AM   #33
Ok too much work for 16 bit and will waste to much space on pic to be usefull i think heh
Here is a pic of the new version of the VB6 program.
working on adding the 8 bit stuff to pic code. Should be easy
AtomSoft is offline
Old 2nd November 2009, 03:31 AM   #34
for now i will leave this as is 12bit and PIC only. I have no need to make it otherwise...
I will be working on storage needs now. SD+FAT... New idea and stuff comes to mind.
AtomSoft is offline
Old 2nd November 2009, 05:24 AM   #35
That VB program's looking good .
Mr RB is offline
Old 2nd November 2009, 01:40 PM   #36
thanks to you it may include all the conversions
AtomSoft is offline
Old 2nd November 2009, 05:12 PM   #37
This is version 1 rev 2
Currently 8bit and 12bit are working 100%
AtomSoft is offline
Old 2nd November 2009, 08:05 PM   #38
Hey guys this is eating up quite a bit of my time so i am omitting the 16bit part but the 8 and 12 bit works 100% and i also made a Color conversion part to this so you can convert colors from RGB to 8, 12 and 16 bit version based on this LCD of course
AtomSoft is offline
Old 2nd November 2009, 08:32 PM   #39
Here are the links to it:
Nokia6100.zip (Just exe file)
Nokia6100BIG.zip (exe with all vb6 dll files)
AtomSoft is offline
Old 2nd November 2009, 11:57 PM   #40
You can get around bit depth in some specific applications by using a palleted image format, does the display support pallets? It's the simplest form of compression.
straight answer, har har."
Sceadwian is offline
Old 3rd November 2009, 12:58 AM   #41
I have no clue
AtomSoft is offline
Old 3rd November 2009, 01:02 AM   #42
Good work Jason. I always enjoy reading your threads.
Mark Higgins
DirtyLude is online now
Old 3rd November 2009, 01:25 AM   #43
Thanks I always like good comments
I'm finishing up the code on the pic side when done I'll post it.
Also when done I will be working on a fat16 code I have in mind and mix this all together to list files and open images stored in text files as hex or decimal
AtomSoft is offline
Old 3rd November 2009, 03:11 AM   #44
hey guys i found a issue when trying to load a large image of 132 x 132 but am fixing it now
AtomSoft is offline
Old 3rd November 2009, 03:44 PM   #45
YES! done now i can do images upto 132x132 and odd sizes and all in 8 and 12 bit modes.
Im working on clearing buffers and stuff now. for some reason when ever you do one picture and try another right after its almost all white
AtomSoft is offline
6100, library, nokia
Multisim Library rahulshah Datasheet/Parts Requests 0 15th March 2009 02:12 PM
Rfid Library ollakalla Micro Controllers 0 18th December 2008 07:02 PM
eagle library fedail General Electronics Chat 19 14th October 2008 07:36 PM
Eagle Library bababui Electronic Projects Design/Ideas/Reviews 13 9th May 2007 01:56 PM
Protothread library Dan East Micro Controllers 0 7th October 2005 04:31 AM
