| | #16 |
Mine is on a breadboard with 15pF caps and is still keeping good time after a day. Mike. | |
| | #17 |
I suspect not all solderless breadboards are created equal (lol). The very old solderless breadboard I have doesn't like crystals at all. Regards, Mike | |
| | #18 |
Pommie, put the same circuit on a perfboard, I garuntee it won't keep the same time.
| | #19 |
So I should avoid a breadboard? Using a 10pf on one leg and 33 pf on another I got accurate time for about an hour...
| | #20 |
You could do that, but you'll have to use a variable cap to tune this on the final board, or retune it completly once it's in it's final enclosure. Scope leads don't help either.
| | #21 |
Trimmer cap, genius idea! ![]() Now I just need to think of a good way to tune it accurately without wasting half my life | |
| | #22 |
You can use trimmer caps in serires with static ones too if you have am in value in mind.
| | #23 | |
Use a epoxy perf pcb with a simple trim cap say 3 to 30pF and the timing accuracy will be within the spec of the crystal and the associated caps. If you use SRBP perf pcb, varnish the pcb copper area around the crystal and trimmer cap.
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ | ||
| clock, crystal, pic, timer1 |
| Clock with Timer1 | PIC2PIC | Micro Controllers | 17 | 29th August 2009 01:28 PM |
| PIC clock cycles, instructions, and crystal frequency? | Hank Fletcher | Micro Controllers | 4 | 7th June 2008 09:07 PM |
| Timer1 | richb | Micro Controllers | 5 | 27th November 2006 11:44 PM |
| HELP: Connecting 4MHz crystal clock to PIC | mr. mister | Micro Controllers | 3 | 21st April 2005 01:27 PM |
| Can I use a 24mhz or 19.968 mhz crystal clock oscillator ? | xpembedded | Micro Controllers | 1 | 9th June 2004 10:48 PM |
