If you could design a PIC development PCB... Examples of development boards. EasyPIC6 LAB-XT PCB size will affect the cost, so remember smaller is cheaper. I would like it to be either so it can be put into a 2 or 3 ring binder. It will be a double sided FR4 PCB with top & bottom solder masks and silkscreen on the top layer. Design goals are to use mostly common readily available parts, also avoiding surface mount for ease of assembly and repair. Standard features (No built in programmer) Programming connector ICD2 (RJ12), Junebug/Inchworm (2x5) or PICkit2 (RA 1x6) 2mm coax power jack with bridge rectifier (round or square?) 5V LM7805 or LM2940 regulator Jumperable USB-B connector & 0.47uF for 18F4550 Crystal socket with jumpers for A6 & A7 16 pin inline 2x16 LCD connector One 10K pot with jumpers for several I/O configurations RS232 port with MAX232 (DTE or DCE?) What onboard features do you consider important for a development board Space around 40 pin socket to support a ZIF socket 35 LEDs one per Output pin 36 pushbuttons one per Input pin 4x4 keyboard matrix pushbutton type joystick keypad (as seen on EasyPIC6) 28 pin socket 18 pin socket 8 pin socket Solderless breadboard, Large, Medium or Small 4.096V voltage reference (not exactly a common part though) RS485 (SN75176 or MAX485 etc...) I2C EEPROM SPI EEPROM I2C RTC (DS1307) will require battery 2x5 I/O headers (as seen on EasyPIC boards) 128x64 GLCD 20pin header 3pin 1wire connector Comments PS I'll edit this post with additional features | |
Temp sensor?
__________________ Unacceptable sig deleted - moderator. | |
Bill, I would like a header to all I/O pins for easy connetion to my own BB, maybe a male and female header configuration...
__________________ Mike2545 | |
Temp sensor sure, which one? The headers seem to be popular. | |
Some ideas: - 7 segment leds - perhaps a speaker - maybe an IR receiver for remote applications? You have covered a lot of stuff already | |
| | #6 |
| Although you state a desire for through-hole only, the SMD TC1047A on a little section of PCB (which can be snapped off) on a PICDEM Mechatronics board is a handy feature. The section is connected by tracks between 2X3 plated through-holes, which allow wires to be used to place the sensor remotely, once the section is snapped off.
| | #7 |
| | #8 |
Hi, Surely the answer to your question depends on your target market or are you trying to do a catch all type of board ? If I was buying a dev board as a beginner or advanced user, an onboard programmer /debugger would be essential. | |
| | #9 |
1. Dip switches for more flexibility in connecting LEDs, push buttons, pull-up/pull-down resistance to I/O pins. 2. One buzzer. 3. A couple of relays. 4. An MT8870 IC for working on telephone related projects. This would make your board unique of others. 5. 1 Digital to analog Converter. 6. A 3-pin female header for DS1820. - Raj Experiments with PIC16F628A | |
| | #10 |
I like the idea of a basic board with expansion boards, similar to the MikroE stuff.
| | #11 |
I second a piezo sounder as standard. I'd like header sockets so you could stack an 'options' board on top of the main demo platform. A cut-down Junebug could be one option for beginners, I'd love an ethernet option. Others could be multi channel mains dimmers, low power motor control etc., all the usual stuff that gets asked about on here. Last edited by monkeybiter; 28th October 2009 at 02:29 AM. Reason: Too slow typing, must be this work keyboard.. | |
| | #12 |
Here's what I'd like to do, try to design a development board where it's sold as a bare PCB. (that's why I'm aiming for easy to get parts) I'd like the size to be either 8.5" x 11" large, or 5.5" x 8" smaller, portable, cheaper. I would like to cut the fat so to speak, just a big board full of empty sockets seems to be a waste of space. I have an Ethernet kit on the backburners. It's got a 64pin TQFP so it's beyond the scope of this project. Motor control has its own power requirements but if there's space it's a possibility, servo control is easy and would just be a couple of three pin jumpers. As for the 120VAC stuff that'll be a very different project. Last edited by blueroomelectronics; 28th October 2009 at 02:34 AM. | |
| | #13 |
Hey Bill, I too have designed a few dev boards, not for commercial purposes, just purely out of frustration at breadboarding regular 'modules'. My designs tend to balloon out of all proportion so I either strip back to basics, or at least have ALL I/O's broken out and labelled, with both single pin header strips, and female ones (mandatory for CPLD and FPGA anyway). ALso its very handy to have a 'aux comms' header which has connections for SPI, I2C and UART - I just use a 10 pin header for that since IDCconnectors are easy to use/find. Check this out: 9" Db Side prototype MCU Develop Board PCB + Connectors on eBay (end time 29-Oct-09 06:13:16 GMT) I have two, one for AVR/PIC's, and one for xilinx/altera CPLD/FPGA's. If you could make somethign similar to that, but with footprints for PICs (and their respective needs) taht would be awesome. Making a 'generic board' really is tough, so many deicisons..... BuriedCode
__________________ Inconsistency is the key to flexibility! Last edited by Blueteeth; 28th October 2009 at 03:06 AM. | |
| | #14 |
I would think about just making it 40 pin PIC only. That frees up PCB space for gizmos. Most app developments can be done on 40 pin then modded later for a smaller target PIC if needed. Definitely look at a ZIF socket. Consider making daughterboards that hold smaller PICs that will slot into the 40 pin ZIF. This won't eat into valuable motherbaord real estate and will probably provide accessory sales. I think compulsory items are text LCD, and LEDs and pushbuttons for every PIC pin, xtal socket, RS232 port and chip, bringing all PIC pins to external header. High value features; buzzer, adc pot, 3 pin connector for DS1820 and LM335 temp sensors, 74HC595 shift regsiter with 8 parallel outputs. Cool feature ideas; R2R SIL network to make easy DAC with little real estate needed, 5x7 LED matrix seem to be popular maybe with a ULN2003 to drive it. IR comms, but BOTH directions! Also a large I2C eeprom. | |
| | #15 |
what about flash SD card slot ?
__________________ ----------------------------------------------------------------------------------- “We can't solve problems by using the same kind of thinking we used when we created them.” -Einstein ----------------------------------------------------------------------------------- | |
| board, development, pic |
| Pic Development Board - uk | hackableFM | Micro Controllers | 2 | 1st February 2009 11:42 AM |
| Pic Development Board - uk | richard.c | Micro Controllers | 5 | 17th December 2008 02:07 PM |
| PIC development board | kta22 | Micro Controllers | 13 | 8th October 2008 08:09 PM |
| help with PIC-01 Development Board | axmanjr | Micro Controllers | 4 | 31st August 2008 09:22 AM |
| pic development board | fivemagics | Micro Controllers | 1 | 26th April 2006 10:06 PM |
