Old 28th October 2009, 10:34 AM   #16
But how would i code this in c? And what about the 1ms part?
mischa is online now
Old 28th October 2009, 10:38 AM   #17
By the way....two very different people who know each other....but i ended up using preeste's account by mistake.
Old 28th October 2009, 11:58 AM   #18
Default Stick with one and grasp the basics
Dissociative identity disorder happens with people that have more than one account in the same forum. Stick with one or you will repeat the performance. (You waste bandwith and the time of contributors).
To you both, please decide yourself to:
1 - stick with one micro PIC or whatever.
2 - Read the relevant part in the respective datasheet. Once you grasp the concepts frequency = 1/period of PWM signal and duty cycle (how much of that period you want the output high), you should be prety much able to attempt a test with any PIC fitted with PWM capability.
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
atferrari is offline
Old 28th October 2009, 01:17 PM   #19
Well, hopefully you are learning C and can code this yourselves.Post your attempt and we will help.
Pommie is online now
Old 29th October 2009, 01:41 PM   #20
I am working on it. Will put up the code as soon as i am done
Old 31st October 2009, 08:08 AM   #21
Hey. Here is my code. Please let me know if this code is right. I have decided to use a 12Mhz crystal instead of the 7.805Mhz.
Just to recap:
I want to generate a 120Khz square wave that will last for 1ms (done by gating the RC2 pin) on RC2 when a switch connected to portD.5 is pressed.
Using the formulaes:
PWM period= [((PR2)+1)*4*Tosc*TMR2 prescalar value] and
PWM duty cycle = (CCPR1L:CCP1CON<5:4>)*Tosc*TMR2 prescalar value,
I decided to use the prescale value =1, this then gave me the following values:
PR2= 24 (0b00011000)
CCPR1L:CCP1CON<5:4> = 50 (0b0000110010)-{10 bit value}
Since CCP1CON<5:4> is the 2 LSb value = "10"--> CCP1CON="0b00101100"
therefore: CCPR1L=8 Msb="0b00001100"
CODE
#include "16F877.h"
#include "DEFS_877.H"
#include "string.h"
#include <stdlib.h>
#include <stdio.h>
#use delay (clock=12000000)
#fuses HS,NOWDT,PROTECT,NOLVP,BROWNOUT,PUT
#use rs232(baud=56000,parity=N,xmit=PIN_C6,rcv=PIN_C7)
set_tris_d(0xff); //setting port d as input
void squarewave (void)
PR2=0b00011000; //set PWM period to 8.3333us
CCPR1L=0b00001100; //sets Duty cycle to 50%
CCP1CON=0b00101100; //Dc=50%
T2CON=0b00000100; //enables timer 2 and sets the prescalar value
set_tris_C(0x00); //output pwm to pin RC2
void main (void)
//just initailises and clears port c initially
set_tris_c(0xFF); //set port c as input
PortC=0; //clear portC
while(1)
if (!input(PIN_D5)) //if switch is closed/pressed
squarewave();
delay_ms(1); //wave on RC2 for a period of 1ms
set_tris_c(0xFF); //sets RC2 as input, so no more
//Pwm present on this pin
Please take a look at my code and let me know if its accurate and correct. Thanks a lot
Old 2nd November 2009, 11:44 AM   #22
Re your PM. I tried the above code in BoostC and it appears to work as intended. There was some problems but I think that might be just compiler differences. However, the line,
will never get executed.
Old 2nd November 2009, 12:25 PM   #23
Why would that line not be executed?
Old 2nd November 2009, 02:36 PM   #24
Because execution always starts at main. I'm surprised the complier doesn't error with that line.
120khz, generation, square, wave
Square wave generation using CCP Modules on 16f747 sp_vibes Micro Controllers 1 22nd February 2009 03:08 PM
Converting a square wave into sine wave using a D/A converte khalifemazen Electronic Projects Design/Ideas/Reviews 6 21st May 2008 11:21 PM
reg: square wave to sine wave converter deepika97 Electronic Projects Design/Ideas/Reviews 4 20th May 2008 08:10 PM
circuit help: square and sin wave input = square wave output spyghost Electronic Projects Design/Ideas/Reviews 2 28th April 2004 02:09 AM
LC filter- filtering a square wave to sine wave kken6248 General Electronics Chat 3 22nd April 2004 05:32 AM
