i am having trouble programming pic16f877a. i have a code using MicroC that includes use of eeprom to display words in a dot matrix. I can simulate it in Proteus but when it comes to actual it doesn't work. I am using WinPic as the programmer.can someone help me please if winpic involves other settings to enable the eeprom of pic16f877a???
Hi, First you need to see if your code is being loaded in to WinPic correctly. If you load your program then open the Data folder you should see your eeprom code. If the data is there then check the Options folder that the Data box is checked on to program it. | |
You should first check that your pic is actually programmed and running. Does your programmer verify the code? Have you tied MCLR to 5V? Does your crystal have the correct capacitors? Did you select the correct oscillator in the config? Do you have a clean power supply? Correct decoupling capacitors? etc. Mike. | |
| eeprom, pic |
| PIC16F877 EEPROM problem | nicknamefrank | Micro Controllers | 14 | 20th February 2009 08:40 AM |
| PIC16f877 internal eeprom programming | malcolm | Micro Controllers | 6 | 12th February 2009 02:50 PM |
| data write/read from EEPROM in pic16f877 | flemmard | Micro Controllers | 4 | 6th September 2007 02:07 PM |
| Hi all eeprom | TKS | Micro Controllers | 4 | 21st June 2004 09:44 AM |
| Using Internal Data EEPROM on PIC16F877 | lee_man_tbu | Micro Controllers | 0 | 4th December 2003 02:47 AM |
