Old 25th October 2009, 05:31 PM   #76
i meant like the project files. Like can you post a zip or something with all files in that folder so i can see how everything is setup
AtomSoft is offline
Old 25th October 2009, 06:14 PM   #77
Here is my project files and schematic
dawson is offline
Old 25th October 2009, 06:17 PM   #78
You are using MikroC ? Or MikroC Pro?
AtomSoft is offline
Old 25th October 2009, 06:22 PM   #79
mikroC PRO sorry didnt realise there was a difference
dawson is offline
Old 25th October 2009, 06:51 PM   #80
Try This pal:
//REV2
 #define MENU   2
#define UP  3
#define DOWN  4
// LCD connections definitions
sbit LCD_RS at RA0_bit;
sbit LCD_EN at RA1_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISA0_bit;
sbit LCD_EN_Direction at TRISA1_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD connections definitions
 unsigned char MainMenuLIST[3][16] = {
{"Option A"},
{"Option B"},
{"Option C"}
unsigned char WaitForInput(void){
        unsigned char done = 0; //DONE Var will determine if done and hold key
        while(!done){                                  //while done == 0
    if (Button(&PORTA, MENU, 1, 0))
          done = MENU;
    if (Button(&PORTA, UP, 1, 0))
          done = UP;
    if (Button(&PORTA, DOWN, 1, 0))
          done = DOWN;
        return done;                                  //Return our done/key var
void MainMenu(void){
unsigned char POS = 0;         //Used for cursor ONLY!
unsigned char x;
unsigned char ITEM=0;
unsigned char PAGE=0;
Lcd_Cmd(_LCD_CLEAR);
while(!done){
    for(x=0;x<2;x++){
        if(x == POS)
            Lcd_Out((x+1),1,">");
        else
            Lcd_Out((x+1),1," ");
        Lcd_Out((x+1),2,MainMenuLIST[(x+PAGE)]);
    switch(WaitForInput()){
        case UP:
            if(POS>0){
                POS--;
                ITEM--;
            } else {
                if(PAGE>0){
                    POS++;
                    ITEM++;
                    PAGE=0;
            break;
        case DOWN:
            if(POS<1){
                POS++;
                ITEM++;
            } else {
                if(PAGE<1){
                    PAGE = 1;
                    POS--;
                    ITEM--;
            break;
        case MENU:
            done = 0xFF;
            break;
        // ITEM contains what item is selected
        // POS isnt used incase larger then 2 menu...
    ITEM+=PAGE;
    switch(ITEM){
        case 0:
            Delay_ms(2000);
            break;
        case 1:
            Delay_ms(2000);
            break;
void main() {
  CMCON  |= 7;                       // Disable Comparators
  TRISA = 0b00011100;                 // RA5,RA4,RA3,RA2 are set to input
  Lcd_Init();                                    // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);                           // Clear LCD
  Lcd_Cmd(_LCD_CURSOR_OFF);                      // Turn cursor off
  Lcd_Out(1, 3, "Waiting");
      do {
                case MENU:
                Delay_ms(100);
                MainMenu();
                break;
} while (1);
AtomSoft is offline
Old 25th October 2009, 06:56 PM   #81
hey i just edited the above code. Use the one with
//REV2
at the top
AtomSoft is offline
Old 25th October 2009, 07:02 PM   #82
That last one now produces:
">Option A"
"Option B"
"Option B"
">Option C"
so it misses Option B
dawson is offline
Old 25th October 2009, 07:14 PM   #83
i has to be your hardware then. I have that code working flawless in Proteus. Ill post a video... using mikroC pro and proteus to test it
AtomSoft is offline
Old 25th October 2009, 07:26 PM   #84
I had a look and noticed there was no delay for switch presses I have now added in a delay for each press and it is working
Thanks for all the help.
dawson is offline
Old 25th October 2009, 07:33 PM   #85
Here is the simulation video:
YouTube - Menu Help
AtomSoft is offline
Old 25th October 2009, 07:39 PM   #86
heh no problem you are right tho:
        if (Button(&PORTA, MENU, 1, 0)){
              Delay_ms(10);
              done = MENU;
        if (Button(&PORTA, UP, 1, 0)){
              Delay_ms(10);
              done = UP;
        if (Button(&PORTA, DOWN, 1, 0)){
              Delay_ms(10);
              done = DOWN;
Thats way better
AtomSoft is offline
Old 25th October 2009, 07:39 PM   #87
Yea thats how it now works with the delays
dawson is offline
Old 25th October 2009, 07:48 PM   #88
just one more problem, when i combine it to my temp sensor code it waits for the button then wats ti read temp then there is delays in temp before it comes back round to wait for MENU to be pressed so you have to get the timing right when pressing it.
here is the code:
 do {
           case MENU:
              Delay_ms(100);
              MainMenu();
              break;
        read_temp();
     } while (1);
is there a better way of waiting for a button press while it is doing the temprature reading?
dawson is offline
Old 25th October 2009, 08:08 PM   #89
The best way is with interrupts. But thats not my strong point heh you can ask around for that.
I can barely do it in C18 i can imagin MikroC is simpler but i would have to learn it more
AtomSoft is offline
Old 25th October 2009, 08:13 PM   #90
also interrupts are on PORTRB line.. If you want to test another way is to check the MENU button with the temp code itself. Like through in:
                   MainMenu();
every now and then to check for the press
AtomSoft is offline
lcd, menu
LCD menu in C? picstudent Micro Controllers 1 13th September 2009 04:48 AM
LCD+keypad interface -> menu structure. Concepts sought. Assembly. PIC. astronomerroyal Micro Controllers 23 29th August 2008 04:59 AM
LG CRT Repair and servce menu. dark666 General Electronics Chat 0 7th June 2008 06:17 PM
Electronic Music Menu cyprio7 General Electronics Chat 0 11th April 2008 04:50 PM
One menu, multiple pages. Anyone good at websites? ThermalRunaway Chit-Chat 6 25th June 2006 11:45 AM
