| | #16 |
heh np ill b writing more and posting in a minute
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #17 |
Thanks I appreciate all the help ![]() I am still a little confused with the array as i get the error ";expected, but 'char' found" Also I am unsure how you output to the lcd i have been doing it like this: Lcd_Out(1, 3, "Temperature:") | |
| | #18 |
Are you using a 2x16 LCD? If so I'll post my LCD code so you can see how I am doing mines. U should post ur code so I can see where the error is
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 24th October 2009 at 07:01 PM. | |
| | #19 |
yes I am using a hd44780 compatible 2X16 display here is what I have so far: Code: #define KeyPORT (PORTA&0x0F)
#define KeyDIR TRISB
#define ENTER 2
#define UP 3
#define DOWN 4
#define LCD_LINE
#define LCD_DATA
#define LCD_STR
// LCD connections definitions
sbit LCD_RS at RA0_bit;
sbit LCD_EN at RA1_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISA0_bit;
sbit LCD_EN_Direction at TRISA1_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD connections definitions
unsigned rom char MainMenuLIST[2][16] = {
{"Option 1"},
{"Option 2"}
unsigned char WaitForInput(void){
unsigned char temp1; //TEMP DATA HOLDER
unsigned char done = 0; //DONE Var will determine if done
while(!done){ //while done == 0
if(KeyPORT>0){ //if KeyPORT aka PORTB&0x0F.. the &0x0f will make sure we
//return the lower part of port only RB0 to RB3
temp1 = KeyPORT; //Place the lower part of port into temp variable
while(KeyPORT==temp1); //Like a debounce for button press
done = 0xFF; //Set DONE Var so we know we are complete
return temp1; //Return our temp1 var
void MainMenu(void){
unsigned char POS = 0; //Used for cursor ONLY!
unsigned char x;
unsigned char ITEM=0;
Lcd_Cmd(_LCD_CLEAR);
while(!done){
for(x=0;x<2;x++){
LCD_LINE(x+1);
if(x == POS)
LCD_DATA('>',1);
else
LCD_DATA(' ',1);
LCD_STR(MainMenuLIST[x]);
switch(WaitForInput()){
case UP:
if(POS>0){
POS--;
ITEM--;
break;
case DOWN:
if(POS<1){
POS++;
ITEM++;
break;
case ENTER:
done = 0xFF;
break;
// ITEM contains what item is selected
// POS isnt used incase larger then 2 menu...
switch(ITEM){
case 0:
//Code to toggle C or F
break;
case 1:
//Code to jump to new menu system
break;
//Bring our title back.. cuz we are done with the menu...
LCD_LINE(1);
LCD_STR((unsigned rom char*)" AtomSoftTech ");
void main() {
CMCON |= 7; // Disable Comparators
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear LCD
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
Lcd_Out(1, 3, "Temperature:");
do {
if(Button(&PORTA,2, 1, 0)) {
MainMenu();
} while (1);
| | #20 |
can you post all the code because this is confusing to me... also what are you writing in? like which compiler...? C18, CSS, Hi-Tech, MikroC? Where are your buttons connected to ?
| | #21 |
that is all the code so far as I have not tried to combine it with my other code yet because I am just trying the menu on its own, I can post the other code if that is what you mean? I have 3 switches atm wanting to use 4th as a cancel button menu/enter - RA2 up - RA3 down - RA4 | |
| | #22 |
ok .. so you have LCD code to show data on lcd already? Like normal text? Ok um... in code the buttons are lined up like PORTA = BINARY 0000-0000 Pressing: RA2 would result in : 0000-0100 RA3 would result in : 0000-1000 RA4 would result in : 0001-0000 This means we have to change the code to accommodate using the upper byte as well... um.... something like... Code: #define KeyPORT ((PORTA>>2)&0x0F) it will come up as 0000-0001 since we right shift 2 times
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 24th October 2009 at 07:38 PM. | |
| | #23 |
Can you post your LCD code please,,, especially Lcd_Out
| | #24 |
Yes I already have lcd working wih normal text. Here is how i think it should be implemented with my ds1820 code: Code: #define KeyPORT ((PORTB>>2)&0x0F)
#define ENTER 2
#define UP 3
#define DOWN 4
#define LCD_LINE
#define LCD_DATA
#define LCD_STR
{"Option 1"},
{"Option 2"}
// String array to store temperature value to display
char *temp = "000.00";
// Temperature Resolution : No. of bits in temp value = 9
const unsigned short TEMP_RES = 9;
// Variable to store temperature register value
unsigned temp_value;
void Display_Temperature(unsigned int temp2write) {
const unsigned short RES_SHIFT = TEMP_RES - 8;
// Variable to store Integer value of temperature
char temp_whole;
// Variable to store Fraction value of temperature
unsigned int temp_fraction;
// check if temperature is negative
if (temp2write & 0x8000) {
temp[0] = '-';
// Negative temp values are stored in 2's complement form
temp2write = ~temp2write + 1;
// Get temp_whole by dividing by 2 (DS1820 9-bit resolution with
// 0.5 Centigrade step )
temp_whole = temp2write >> RES_SHIFT ;
// convert temp_whole to characters
if (temp_whole/100)
// 48 is the decimal character code value for displaying 0 on LCD
temp[0] = temp_whole/100 + 48;
else
temp[0] = '0';
temp[1] = (temp_whole/10)%10 + 48; // Extract tens digit
temp[2] = temp_whole%10 + 48; // Extract ones digit
// extract temp_fraction and convert it to unsigned int
temp_fraction = temp2write << (4-RES_SHIFT);
temp_fraction &= 0x000F;
temp_fraction *= 625;
// convert temp_fraction to characters
temp[4] = temp_fraction/1000 + 48; // Extract tens digit
temp[5] = (temp_fraction/100)%10 + 48; // Extract ones digit
// print temperature on LCD
Lcd_Out(2, 5, temp);
unsigned int digit;
void read_temp() {
//--- perform temperature reading
Ow_Reset(&PORTB, 5); // Onewire reset signal
Ow_Write(&PORTB, 5, 0xCC); // Issue command SKIP_ROM
Ow_Write(&PORTB, 5, 0x44); // Issue command CONVERT_T
Delay_ms(600);
// If this delay is less than 500ms, you will see the first reading on LCD
//85C which is (if you remember from my article on DS1820)
//a power-on-reset value.
Ow_Write(&PORTB, 5, 0xBE); // Issue command READ_SCRATCHPAD
// Read Byte 0 from Scratchpad
temp_value = Ow_Read(&PORTB, 5);
// Then read Byte 1 from Scratchpad and shift 8 bit left and add the Byte 0
temp_value = (Ow_Read(&PORTB, 5) << 8) + temp_value;
//--- Format and display result on Lcd
Display_Temperature(temp_value);
unsigned char x;
while(!done){
for(x=0;x<2;x++){
LCD_LINE(x+1);
if(x == POS)
LCD_DATA('>',1);
else
LCD_DATA(' ',1);
case UP:
if(POS>0){
POS--;
ITEM--;
break;
case DOWN:
if(POS<1){
POS++;
ITEM++;
break;
case ENTER:
done = 0xFF;
break;
switch(ITEM){
case 0:
break;
case 1:
break;
LCD_LINE(1);
void main() {
Lcd_Out(1,5,message1); // Write message1 in 1st row
Lcd_Out(2,4,message2); // Write message1 in 2nd row
Delay_ms(2000);
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Out(1, 3, "Temperature: ");
// Print degree character, 'C' for Centigrades
Lcd_Chr(2,11,223);
// different LCD displays have different char code for degree
// if you see greek alpha letter try typing 178 instead of 223
Lcd_Chr(2,12,'C');
digit = 0;
//--- main loop
do {
MainMenu();
else {
read_temp();
} while (1);
| | #25 |
lcd_out() must be in the libraries on mikroc?
| | #26 |
try : Code: unsigned char MainMenuLIST[2][16] = {
{"Option 1"},
{"Option 2"}
| | #27 |
yes that has solved the error now I can compile the code but i still need to know how LCD_STR() works in comparison to my lcd_out();
| | #28 |
I'll have to look at lcd out and compare them.
| | #29 |
I have 2 LCD_STR Code: void LCD_STR(unsigned rom char *text){
while(*text){
LCD_DATA(*text++,1);
void LCD_STR2(unsigned char *text){
while(*text){
| | #30 |
Try this: Code: #define KeyPORT ((PORTA>>2)&0x0F)
#define KeyDIR TRISA
#define ENTER 1
#define UP 2
#define DOWN 4
#define LCD_LINE
#define LCD_DATA
#define LCD_STR
{"Option 1"},
{"Option 2"}
char temp_whole;
temp[0] = '-';
if (temp_whole/100)
else
temp[0] = '0';
unsigned int digit;
void read_temp() {
Delay_ms(600);
unsigned char x;
while(!done){
for(x=0;x<2;x++){
LCD_LINE(x+1);
if(x == POS)
LCD_DATA('>',1);
else
LCD_DATA(' ',1);
LCD_OUT((x+1),2,MainMenuLIST[x])
case UP:
if(POS>0){
POS--;
ITEM--;
break;
case DOWN:
if(POS<1){
POS++;
ITEM++;
break;
case ENTER:
done = 0xFF;
break;
switch(ITEM){
case 0:
break;
case 1:
break;
void main() {
KeyDIR = (0x0F<<2);
Delay_ms(2000);
Lcd_Chr(2,11,223);
Lcd_Chr(2,12,'C');
digit = 0;
//--- main loop
do {
if(KeyPORT == ENTER) {
MainMenu();
} else {
read_temp();
} while (1);
| lcd, menu |
| LCD menu in C? | picstudent | Micro Controllers | 1 | 13th September 2009 04:48 AM |
| LCD+keypad interface -> menu structure. Concepts sought. Assembly. PIC. | astronomerroyal | Micro Controllers | 23 | 29th August 2008 04:59 AM |
| LG CRT Repair and servce menu. | dark666 | General Electronics Chat | 0 | 7th June 2008 06:17 PM |
| Electronic Music Menu | cyprio7 | General Electronics Chat | 0 | 11th April 2008 04:50 PM |
| One menu, multiple pages. Anyone good at websites? | ThermalRunaway | Chit-Chat | 6 | 25th June 2006 11:45 AM |
