Old 22nd October 2009, 05:08 PM   #16
Smile
Originally Posted by rajbex View Post
Try these new hex files. The hardware should be the same. If it works, I will send you the modified assemble code.
DEAR RAJ SIR
THANK YOU THANK YOU THANK YOU THANK YOU .
i will try it. HOW CAN OPEN [DS_STORE File]
sahu is offline
Old 22nd October 2009, 06:01 PM   #17
What does that mean? 'HOW CAN OPEN [DS_STORE File] '
- Raj
Experiments with PIC16F628A
rajbex is offline
Old 22nd October 2009, 06:43 PM   #18
- Raj
dear sir
IR HEX have two File Folder ....{1}.__.MACOSX , {2} IR_hex
{1}__MACOSX have one File Folder ... {a} IR_hex
{a} IR_hex have one File Folder ..[A] ._.DS_Store ....it is....show type of folder.......DS_STORE File
{2} IR_hex have two File Folder.....[A] .DS_Store , [B] ir_rx_new.hex & [C] ir_tx_new.hex .
[A] .DS_Store ....it is....show type of folder.......DS_STORE File.
so again my que. DS_STORE File. hwo can open it.
sahu is offline
Old 22nd October 2009, 07:28 PM   #19
Sorry, something has gone wrong. I compressed the folder on a MAC computer, so you might be having trouble in decompressing. Actually, that folder should have only two hex files: ir_tx_new.hex and ir_rx_new.hex. I have assembly files at home. I will send them in the evening.
- Raj
rajbex is offline
Old 22nd October 2009, 07:29 PM   #20
If you see these two files, ir_tx_new.hex and ir_rx_new.hex, you are done. Try them out, there are no more supporting files.
-Raj
rajbex is offline
Old 22nd October 2009, 07:37 PM   #21
-Raj
YES ITS , I FOUND ir_tx_new.hex and ir_rx_new.hex. I WILL TRY IT TOMORROW.
GOOD NIGHT
sahu is offline
Old 23rd October 2009, 05:06 PM   #22
-Raj
dear sir
today try only ir tx .found some problam,so pl clear my prob... pl see it .
sahu is offline
Old 23rd October 2009, 05:37 PM   #23
R1 is far too high (range will be short) and C3 is much too small, needs to be 220uF or so (battery life will be very short otherwise).
Nigel Goodwin is online now
Old 3rd November 2009, 06:06 PM   #24
Red face
sorry, something has gone wrong. I compressed the folder on a mac computer, so you might be having trouble in decompressing. Actually, that folder should have only two hex files: Ir_tx_new.hex and ir_rx_new.hex. I have assembly files at home. I will send them in the evening.
- raj
experiments with pic16f628a
today i cheked it. It working fine ,only button 2 ,4 , 6 ,8 workin & button 1 ,3 ,5 ,7 not working. So pl help me.
sahu is offline
Old 3rd November 2009, 07:22 PM   #25
I am sorry I can't help you to that extent because I have not tried that circuit myself, and I have no time for that. I helped you in changing PIC16f630 code to equivalent PIC16f676 code. I would say you check your hardware carefully. If it works for some of the pins then it should work for the rest too.
- Raj
rajbex is offline
based, control, pic, remote
ADC sensing code needed using pic16f676\16f72 sahu Micro Controllers 10 26th October 2009 06:09 PM
Current Sensing Resistors - Newb Help Needed. Jack.Straw General Electronics Chat 8 31st July 2009 02:01 AM
Problem in ADC code Jyothi@Pic Micro Controllers 1 10th February 2009 05:59 PM
Eprom write problem using PIC16F676 mathur2000 Micro Controllers 9 6th July 2007 07:27 AM
C code for ADC sampling patricktran Micro Controllers 4 15th June 2004 02:42 AM
