Hi, I am new to microcontroller programming...I would like to interface a LCD with Pic 16f877.. but i think that there is a problem in initializing the LCD...I could not able to initialize the LCD...LCD just displays black boxes... Compiler:MickroC Programmmer:PIC start Plus Programming :C I can initialize an LCD when i connect it with 89C51...But i cant do the same thing with Pic microcontroller.. What might be the problem? Whether its the problem due to compiler or code or Programmer.. Can any one help me... Please... | |
Please post your code. Initialize LCD code and initialize micro IO pins....... It is common to not have the pins right.
Is the code yours? Sounds like a hardware problem to me if its only black boxes (or bad software). | |
Thanks for your reply... I have attached the code which i tested in MicroC compiler... But it shows the black boxes... Help me Program 1: #define ldata PORTD #define rs PORTB.F0 #define rw PORTB.F1 #define en PORTB.F2 void lcdcmd(unsigned char ); void lcddata(unsigned char ); void msdelay(unsigned char); void main(void) { TRISD=0; TRISB=0; en=0; msdelay(25); lcdcmd(0x38); msdelay(25); lcdcmd(0x0E); msdelay(15); lcdcmd(0x01); msdelay(15); lcdcmd(0x06); msdelay(15); lcdcmd(0x86); msdelay(15); lcddata('A'); msdelay(15); lcddata('D'); msdelay(15); lcddata('E'); } void lcdcmd(unsigned char value) { ldata=value; rs=0; rw=0; en=1; msdelay(1); en=0; } void lcddata(unsigned char value) { ldata=value; rs=1; rw=0; en=1; msdelay(1); en=0; } void msdelay(unsigned char itime) { unsigned char i,j; for(i=0;i<itime;i++) for(j=0;j<135;j++); } Program 2:This program i downloaded it from net.. This program too gives the same output... char *text= "EQBYTE for All"; signed char data[12]; int i=0; void main (){ TRISB = 0; // PORTB is output Lcd_Init(&PORTB); // Initialize LCD connected to PORTB while (1) { Lcd_Cmd(Lcd_CLEAR); // Clear display Lcd_Cmd(Lcd_CURSOR_OFF); // Turn cursor off for (i=1;i<11;i++) { Delay_ms(200); IntToStr(i,data); //Numeric to string transform (i to data) Lcd_out(1,1,"Value="); // Print fixed text to LCD (e.g "Value") Lcd_out(1,8,data); // Print variable text to LCD, 1st row, 8th column (e.g data) Delay_ms(200); } Lcd_Cmd(Lcd_CLEAR); // Clear display Lcd_Out(2, 1, text); // Print text to LCD, 2nd row, 1st column Delay_ms(1200); } } | |
How do you know if the chip is running or not?
| | #6 |
I suspect the problem is hardware. You can add an additional program to blink a LED at some other port to make sure that the PIC is executing the code. Also, you can try my code written in mikroC for LCD interface, though I wrote for PIC16F628A. -Raj Experiments with PIC16F628A | |
| | #7 |
you can find pre-built library for controlling LCD..... you can use it if u want to check ur LCD! | |
| interfacing, lcd, pic |
| interfacing PIC 16F877 with gsm mobile | project8 | Micro Controllers | 0 | 23rd January 2009 11:35 AM |
| Bunch of questions regarding PIC, PCB fabrication, LCD interfacing and PIC-C | xieliwei | Electronic Projects Design/Ideas/Reviews | 9 | 3rd May 2008 10:12 AM |
| Lcd Interfacing With Pic-help Help Help....... | samlovesembedded | Micro Controllers | 4 | 13th March 2008 02:23 PM |
| schematic for pic 16f877 and lcd 20 pins | jijita | Micro Controllers | 1 | 7th September 2004 06:41 PM |
| clear character in LCD with matriz keypad and pic 16f877 | david_mora | Micro Controllers | 8 | 19th May 2004 09:33 AM |
