I need to use PIC with wireless comm. I saw the "wireless modems" at Sparkfun, they're impressive but pricey. I can get USB Bluetooth adapters for next to nothing, with "up to" 100m range. This sounds dandy and meets my bandwidth requirements. However, using a PIC as a USB master may be too problematic. Well, I know it can, but only a few PICs can be USB masters and I need a wider choice of chips. And the USB layer doesn't help me at all, I just need to send some data here. The FTI USB-to-rs232 chips are actually USB slaves with an rs232 interface- so the UART interface can't actually make it act as a USB master to control a BT-USB adapter. Plus, an extra "specialty" chip is generally too more awkward than I would want this to be. Are any of these USB adapters known to be "hackable" where I can cut it open and wire directly into a logic-level, nondifferential UART on the hardware? This would be extremely useful.
Have you looked at XBee wireless The bluetooth USB devices are only half a solution, they need your PC to do most of the work. | |
Again, I'm looking at cheap, to keep them useful for many small projects. $20 modules are pretty high "up there" for that. I can get USB-BT adapters for like $3. Of course if it won't work it won't work. Do you have links describing what part the PC takes in handling the protocol? It's not uncommon to find a UART interface on a USB device though. Most GPS sold as USB devices have a TTL UART pin on board which is much easier to interface with a microcontroller, for example. I guess I'll get one of these USB-BT adapters, crack it open, ID the chip, and look up its spec first. Basically I'm looking for someone familiar with this specific hacking-a-USB-BT-adapter problem.
__________________ I thought what I'd do was I'd pretend I was one of those deaf-mutes. Last edited by Oznog; 13th October 2009 at 10:44 PM. | |
Some of thoese FTI USB - RS232 chips act as USB host controllers, yet I think you will have to implement a huge code to get a USB dongle working. Check these links http://www.seeedstudio.com/depot/ser...ter-p-279.html http://www.seeedstudio.com/depot/ser...ave-p-501.html They are bluetooth-serial modules I found. They are fairly cheap comparing to ones at Saprkfun. I'm going to order one of them(Master or Slave) to make my PIC communicate with a mobile phone. But I haven't tested anything yet. Hope this helps.. Last edited by Hero.sl; 14th October 2009 at 07:03 AM. | |
| adapter, bluetooth, pic |
| PCI Bluetooth Card... + bluetooth controlled electric motor & bluetooth keypad | kira_kame | Electronic Projects Design/Ideas/Reviews | 4 | 21st August 2009 07:43 PM |
| wireless barcode adapter in inventry solution.Bluetooth barcode scanner. | jane sumlung | Robotics Chat | 2 | 6th May 2009 05:16 AM |
| Bluetooth Serial Adapter | aforadi | Micro Controllers | 24 | 16th April 2009 11:43 AM |
| SENA Bluetooth serial adapter | justDIY | General Electronics Chat | 1 | 19th August 2007 03:47 PM |
| connect the pic16f877 with an adapter usb bluetooth | lm85 | Micro Controllers | 6 | 7th June 2007 07:22 PM |
