| hi, i am new on PIC.. i got a project which used PIC16C57C which are use for timer counting. The portC as and output of 4 seven segment display and also the input of a time setting switch. so, initially, i write the program, i configure the port c at output.. but then after i display the '0000' on 7 segment, i need to proceed to process 2 which detect the input of port c, to check the switch which got press and got signal in to MCU. So, how can i configure the port c bo be input?? what metter i try to configure it for eg: .... .... movlw b'00001111' ; -- port c pin 0,1,2,3 as input movwf trisc btfsc portc,0 goto result ... ... but it still not functioning.. is that possible for a port that change from output to input suddenly? my other I/O port already fulfill with other application... any one can give me some suggestion? thank you very much... wish some one can reply me as soon as posible.. thanks.
__________________ yce_kelvin | |
| Code: movlw b'00001111' ; -- port c pin 0,1,2,3 as input movwf trisc Code: movlw b'00001111' ; -- port c pin 0,1,2,3 as input TRIS PORTC
__________________ "Having to do with Motion Control" | |
| to motion, ok... i will try it now.. thank you so much.. later let u know success or not.. thank you. kelvin
| thank you so much.. its is function... i will try my best to finish this project.. thanks
