Old 10th October 2009, 09:11 PM   #16
Just looking for a couple set voltages around 4.3 and 4.7 volts for this project. However; I'm also looking for a design that would allow me to use this same design in other projects for dimming leds where PWM is not possible.
superflux is offline
Old 10th October 2009, 10:59 PM   #17
Originally Posted by superflux View Post
To my knowledge, this is a emitter follower scenario. The more voltage placed into the transistor, the higher the resulting voltage out the emitter - no?
Depending on the switch position, either PORTB 6 or 7 will be turned on via software, suppling 5 volts, to the selected port, dropped down slightly by the resistor/diode combo into the transistor.
I am all ears and willing to learn.
Thanks!
Well your schematic shows the emitter is GROUNDED, thus output will always be zero.
It's obvious to me that there should be a resistor on the emitter and your output pulled from across it, just drawn wrong.
binzer is offline
Old 11th October 2009, 01:25 AM   #18
I used a 12f508 with resistor ladder by setting any combination of the four pins high
I could go from 0 to 5 volts makes a real good led controller
be80be is offline
Old 11th October 2009, 01:27 AM   #19
It definitely sounds like the way to go.
Old 11th October 2009, 01:42 AM   #20
I got the idea from here My PIC Projects
read down to the sine wave I did it for the voltage not a sine wave. so i'm just setting the port to get what voltage I need.
You get 16 possible resistor combination's
be80be is offline
Old 11th October 2009, 02:50 AM   #21
superflux,
You did not understand my last post about driving a LED. You do not have one output =1 and the other =0!
The pins have three states. 1, 0, Z (z=input)
pin1, pin2, current
0, 0, 10mA
Z, 0, 8mA
0, Z, 2mA
Z, Z, 0mA
ronsimpson is online now
Old 11th October 2009, 03:28 AM   #22
Originally Posted by ronsimpson View Post
superflux,
pin1, pin2, current
0, 0, 10mA
Z, 0, 8mA
0, Z, 2mA
Z, Z, 0mA
On the contrary, I did understand and I thought it was a good solution.
I was simply asking if the when 2 or more PORTs are set to OUTPUT and are connected and one of them is "1" and the other is "0", does that "0" represent 'ground' and if so, can I assume that it will ground out the voltage sent from the other connected PORT that is set to "1" (high)?
I guess what I'm asking is when an OUTPUT port is set to "0" is that GROUND or just 0 volts?
Old 11th October 2009, 05:09 AM   #23
PWM is a much better way to drive an LED, why wouldn't you want to use it?
Bill
Smart Kits build Smart People
Old 11th October 2009, 05:51 AM   #24
0=0 volts, 1=supply voltage, assuming the current is low. Z= any voltage from 0 to supply and no current.
Old 11th October 2009, 11:42 AM   #25
During the ADC process, where I sample with a delay between each of the 8x sample reading, I would get a bright blip out of the LED.
I use PWM for many other projects, but I since I need that longer sample time, I don't want to run into issues with it.
Is the R2R ladder not a good solution in your opinion?
Old 11th October 2009, 12:07 PM   #26
You can go from 0 to 5 and full on at any voltage.
You have no duty to worry about.
I've done some things with leds and R2R make the leds look like there on fire
I couldn't get it to work with pwm
be80be is offline
Old 11th October 2009, 04:41 PM   #27
That blip can be fixed with software.
Bill
Old 11th October 2009, 06:45 PM   #28
All blip can be fixed with software. Some time down the road if you don't run out of time lol
be80be is offline
Old 11th October 2009, 11:05 PM   #29
I can probably program the LED PWM in the ADC delay, but if the R2R ladder works just as well, then why bother with the extensive programming?
Old 11th October 2009, 11:15 PM   #30
That's what I think keep it simple R2R 10 lines PWM a page and 2 week making it do what you want.
What's in your code LOL
be80be is offline
outputting, pic, variable, voltages
Driving Higher Voltages from PIC 16F88 Tom81 Micro Controllers 9 18th August 2009 05:49 AM
My OpAmp is only outputting 1.6V - what am I doing wrong? PowerJunkie Electronic Projects Design/Ideas/Reviews 15 17th April 2009 04:43 PM
16f877 pic pin voltages when data is writing uditha33 Micro Controllers 2 6th June 2007 04:26 AM
outputting BCD values on a basic stamp German1981 Micro Controllers 2 12th April 2004 03:58 PM
Reading/outputting voltage magna Micro Controllers 10 4th March 2004 05:42 PM
