Old 10th October 2009, 05:32 AM   #1
Default 6' wire to PIC ADC - any precautions?
I have 6' of 24 gauge wire that will be carrying my voltage signal to the PIC's ADC - should I use a 1uf capacitor on the ADC input pin close to the chip?
Thanks!
superflux is offline
Old 10th October 2009, 08:28 AM   #2
Thanks!
I would add a 1K in series with the 6ft lead, close to the PIC's input pin.
I dont know what common/ground/0V line for the Vsource is from the remote [6ft end], but it would be advisable to use at least a twisted pair of wires.
Thats the Vsignal and PIC 0V.
If the 6ft wire is running close to other high current switching lines, I would consider a 5.1V or 5.6V zener from the PIC adc pin to 0V.
ericgibbs is offline
Old 10th October 2009, 01:55 PM   #3
I am using a 2k resistor, but it is closer to the beginning of the 6' line. I will move it closer to the PIC.
I have 3 24 gauge wires going to the PIC, ADC wire, Ground and a 5v supply wire - all have been twisted together and placed in a vinyl jacket.
Is the Zener some type of overload protection in this case or does it block some unwanted interference?
Old 10th October 2009, 01:58 PM   #4
It's over voltage protection, but PIC pins are already protected internally anyway.
Old 10th October 2009, 02:02 PM   #5
The PIC internal diodes are limited to about 20mA, I was concerned if the 6ft line picked up a low impedance source 'spike' the 5.1V zener would help to absorb the overvoltage current.
Old 10th October 2009, 02:09 PM   #6
With a 2K resistor (as he's using) you would need 25V continuous input to pass 20mA.
If you've ever fitted a PIC in the socket backwards, you'll know that the protection diodes happily pass a LOT more than 20mA without damage
Old 10th October 2009, 02:15 PM   #7
So there's no reason to use a small cap on that ADC line right before the input pin? The reason I ask is that it's done on the supply voltage due to the distance between the Power Supply and PIC.
On a slightly different note, can you recommend a cap size that would reduce the flucuations that I am getting? The ADC readings are on a motorcycle from a voltage dividing circuit. Currently, I'm using a 100uf, but that was just a stab in the dark.
Old 10th October 2009, 02:24 PM   #8
Problem is I'm not sure where the 6ft wire is routed, if its adjacent to HV switching circuits, it could pickup a lot more than 25V.
For the very small cost of a zener, I personally would fit it, again we dont know how critical it is that the PIC fails and the program stops.
Nigel, how could you ever possibly believe I would insert a PIC backwards...
EDIT: on the m/cycle which voltage are you dividing.??
Superflex, you posted while I was typing.
Old 10th October 2009, 02:28 PM   #9
But not of a low source impedance, only a very high one.
Superflex, what is the actual project.?
As always, it depends on exactly what it's doing.
Nigel, how could ever possibly believe I would insert a PIC backwards...
I've still got one with my fingerprint burnt in the top
And a finger with the MicroChip logo permanently displayed in it
Old 10th October 2009, 02:33 PM   #10
hi Nigel, My thumb print says 74LS07...[backwards]
I said low impedance source, because I was concerned about the 'energy' in any possible spike, not a high impedance, very low current source.
Anyway it appears the OP's project is a m/cycle which could be rampant with electrical noise..
EDIT:
Superflux you may find this pdf helpful, I know its written for motor car system, but the principles are the same.
adc, pic, precautions, wire
Adc Pic richiealex General Electronics Chat 1 16th July 2008 09:23 AM
1 or 2 Wire transmission and servo control (PIC) weegee Micro Controllers 3 21st January 2008 02:23 PM
HS1101 capacitive humidity sensor; need nearly linear voltage to feed to a 1-wire ADC FirefighterBlu3 Electronic Projects Design/Ideas/Reviews 5 20th October 2007 12:06 AM
PIC ADC Spectacular Butter Micro Controllers 9 11th March 2005 05:04 PM
PIC through live wire communication etix6x2000 Micro Controllers 3 11th March 2003 05:18 PM
