Old 9th October 2009, 02:10 AM   #1
Default Large scale LED controller for boat
I sure could use some help on this project, also would be willing to pay for high quality professional services. (must prove you are qualified)
Here's the project: We have 50 - 20ma high output LED's that will be installed in the boat transom, approx. 2" spacing. Need to have these led's scroll, chase, dim. Power supply is 12v (not 24v)
Where do I start? I'm not an electrical engineer, I am a test engineer stuck with this project for a show boat to be displayed at an annual convention.
Thanks.
Greg
heygreg is offline
Old 9th October 2009, 03:33 AM   #2
You can buy 50' LED rope light with 8 function controller for <$50, see ebay. May require dropping the 12V down to whatever the unit uses.
dougy83 is offline
Old 9th October 2009, 03:46 AM   #3
No rope light stuff for this boat! These are high output stainless led designed for marine environment were using. Were looking for a high end custom install, not a store bought, off the shelf screw on or glue on. Thanks though.
heygreg is offline
Old 9th October 2009, 03:59 AM   #4
Well, if you want to make it yourself and have flexibility in the patterns and timing, you will likely want to use a microcontroller and drive the LEDs using multiplexing.
For a standard multiplex, there will be 15 wires that you will have to route to the LEDs. If you would like to elaborate on what you require, including customisation features, I can design or at least help you design a unit.
dougy83 is offline
Old 9th October 2009, 11:16 AM   #5
Ok....lets get started.
heygreg is offline
Old 9th October 2009, 11:42 AM   #6
Well, what do you require?
* Individual control of brightness for each LED?
* User programmable patterns?
* Pattern-change triggered by external input? (or just internally timed?)
dougy83 is offline
Old 9th October 2009, 12:28 PM   #7
User progamable...dimming all, screoll, sequence, etc.
If the guys like the transom, then they want me to do the sides, which will be 125 LED's per side.
heygreg is offline
Old 9th October 2009, 01:03 PM   #8
How will you find someone to come install if you haven't specified a location!
Mike
My website: www.ElectroBird.net
birdman0_o is online now
Old 10th October 2009, 01:58 AM   #9
Deleted
Deleted
I'm could be wrong many time's, at least I know what I'm doing.
http://shop.ebay.ca/merchant/csaba911
csaba911 is offline
Old 10th October 2009, 08:40 AM   #10
Well he said he was a test engineer and his people had given him this project. It would be logical to assume that he can do the electrical install itself but wants someone else to do the microcontroller module design.
Mr RB is offline
Old 10th October 2009, 10:55 AM   #11
Yes, this is correct. No problems installing it, just need design help.
Since it's going on a boat, they don't want do-it-yourslef cricuit boats.
So, what's next?
heygreg is offline
Old 10th October 2009, 12:39 PM   #12
hi heygreg,
I would recommend something simple and hefty on the display side with full brightness and PWM brightness control. You should get an idea from the crude drawing below for the 15-pin LED wiring harness. You might consider four push buttons in a "diamond" pattern and a 2x16 LCD display for the user interface or perhaps something as simple as lighted push buttons switches. Power budget for the display below would be a maximum of 960-ma.
Let me know if you need help on this project.
Kind regards, Mike McLaren, K8LH (Westland, MI, USA)
Large scale LED controller for boat-boat.png   Large scale LED controller for boat-boat-switches.png
Mike, K8LH is offline
Old 11th October 2009, 07:48 AM   #13
Originally Posted by Mike, K8LH View Post
You should get an idea from the crude drawing below...
Where's the crude drawing?? All I can see are the REALLY nice looking professional drawings.
Mr RB is offline
Old 11th October 2009, 12:34 PM   #14
He can say that when he's good
All this work looks professional
be80be is offline
Old 11th October 2009, 01:02 PM   #15
Thanks guys.
If the OP comes back, let's try to convince him to go with 48 LEDs instead of 50 (for reasons that are more obvious to us hardware/software types, LOL)...
Say, I wonder if an "SOS" effect would be nice to have (and hopefully never used)...
Kind regards, Mike
boat, chasing, controller, dimming, large, led, led controller, scale, scrolling
Want to build large LED chasing, how To drive LED? wilykat Electronic Projects Design/Ideas/Reviews 16 27th September 2009 04:14 PM
New to al this - large scale transporter Combat Wombat Robotics Chat 6 15th January 2009 09:06 PM
LED project for model boat - clueless and need help oates151 Electronic Projects Design/Ideas/Reviews 8 26th October 2008 04:31 AM
Large Scale LED controller VizualXTC Electronic Projects Design/Ideas/Reviews 19 18th May 2008 05:12 PM
Large scale desoldering? HarveyH42 General Electronics Chat 12 20th October 2006 05:52 PM
