Hi all, I'm using the following RF modules: http://www.altronics.com.au/index.as...=item&id=Z6900 http://www.altronics.com.au/index.as...=item&id=Z6905 Attached below is a screen capture from PicKit2 Logic Tool. Channel 1 shows a square wave output of about 300us from a PIC being sent to the RF Transmitter. Channel 3 shows the received data from the RF Receiver. There is approximately 210us delay in receiving a transition to high signal. But, there is only approximately 40us delay in receiving a transition to low signal. So the received signal is far from square wave. The issue I have is that the delays are different. It appears one should compensate for these differences in the bit-banging routine for sending data but this isn't elegant. Are different delays generally evident in RF modules or should I try a different brand? Thanks, David | |
Always different, which is why you can't reliably just send RS232 data - you need to use Manchester coding (or similar) - check my tutorials.
| | #3 | |
I've modified the routine to accept a multiple length packet in the following format (all bytes except header preamble): Code: <Header preamble> <- 20 "1" bits followed by 1 "0" bit Packet length (number of data bytes) <- must be 15 or less; others are masked off Data 1 Data 2 . . . Data n Checksum (calculated by routine) Code: mrx_receive ; receive a full manchester-encoded packet clrf len_done ; Added by DKP s3 ; set flags: first_half=1, if_short=0 bsf FIRST_HALF s4 bcf IF_SHORT s5 ; init before the received packet ; set FSR to buffer start movlw mrx_buffer movwf FSR ; set byte counter movlw (packet_len+1) ; bytes / packet movwf btcnt ; set header receive mode bsf HEADER clrf bitcnt ; counting bit1-s in this mode s2 ; wait for a pulse SKH RXBIT goto s2 s6 ; wait for end of (short) pulse up to min_2t clrf tmrval s6_w SKH RXBIT goto s7 ; goto s7 at end of pulse incf tmrval, F nop movlw min_2t subwf tmrval, W btfss STATUS, C goto s6_w ; timeout, exit retlw 1 ; illegal startbit s7 ; start timer clrf tmrval s8 ; if (if_short & rxbit) goto s9 ; if (!if_short & !rxbit) goto s9 ; goto s10 btfsc IF_SHORT ; if_short = 1 goto s8_ss1 s8_ss0 ; if_short = 0 SKL RXBIT goto s10 ; rxbit = 1, goto s10 s9_ss0 ; if (timer > max_2t) exit - else goto s8 movlw max_2t subwf tmrval, W btfsc STATUS, C retlw 2 ; signal too long incf tmrval, F goto s8_ss0 s8_ss1 ; if_short = 1 SKH RXBIT goto s10 ; rxbit = 0, goto s10 s9_ss1 ; if (timer > max_2t) exit - else goto s8 movlw max_2t subwf tmrval, W btfsc STATUS, C retlw 2 ; signal too long incf tmrval, F goto s8_ss1 s10 ; invert if_short movlw if_short_val xorwf flags, F s11 ; if (timer < min_t) exit movlw min_t subwf tmrval, W btfss STATUS, C retlw 3 ; signal too short s12 ; if (timer < min_2t) goto s14 movlw min_2t subwf tmrval, W btfss STATUS, C goto s14 s13 ; if (first_half = 0) goto s16 - else exit btfss FIRST_HALF goto s16 retlw 4 ; no mid-frame transition/out of sync s14 ; invert first_half movlw first_half_val xorwf flags, F s15 ; if (first_half = 1) goto 7 btfsc FIRST_HALF goto s7 s16 ; if_short is a decoded bit. Handle here btfss HEADER goto s16_not_header ; header receiving mode btfss IF_SHORT goto s16_header_end ; header bit is 1 btfss bitcnt, 4 ; inc up to 16 incf bitcnt, F ; 16 is enough... #ifdef NOMAXHDR ; test for max header length movlw hdrcntmax subwf bitcnt, W btfss STATUS, C #endif goto s7 ; loop back retlw 9 ; header too long s16_header_end ; header ends indicated by a 0 bcf HEADER ; test for min header length movlw hdrcntmin subwf bitcnt, W btfss STATUS, C retlw 0x0a ; header too short next_byte movlw 0x0a movwf bitcnt goto s7 ; loop back s16_not_header ; receiving bytes decf bitcnt, F bz s16_s4 ; if (bitcnt = 0) check for a byte-sep 1 ; if (bitcnt = 1) check for a byte-separator 0 movlw 1 xorwf bitcnt, W bnz s16_s2 ; test for a byte separator 1 btfsc IF_SHORT goto s7 retlw 7 ; byte-ending 1 not present s16_s2 ; bit is data rrf flags, W rlf bt, F goto s7 s16_s4 ; check for a byte-separator 0 btfsc IF_SHORT retlw 8 ; byte-ending 0 not present ; Start added by DKP btfss len_done, 0 goto dkp_lenbyte save_byte ; End added by DKP ; OK, received byte is sane, store in buffer movf bt, W ; Get byte received movwf INDF ; Save it to the buffer incf FSR, F decfsz btcnt, F goto next_byte retlw 0 ; OK, buffer received ; buffer checking is not done automatically! ; if returned value is 0, call mrx_chk_buf to check ; ; Start added by DKP dkp_lenbyte movf bt, W ; Get the byte value received (we know it's the length as it's the first one) andlw b'00001111' ; Mask off any invalid bits so we get packet length no longer than 15 movwf btcnt ; Set the new byte counter incf btcnt ; Add one more for header byte incf btcnt ; Add one more for checksum bsf len_done,0 ; Set flag so we know we have length byte goto save_byte ; Save the length into the buffer ; End added by DKP mrx_chk_buf ; check buffer sanity by chksum movlw mrx_buffer movwf FSR ; movlw (packet_len+1) ; number of bytes with the chksum byte movf INDF, W ; number of bytes movwf btcnt incf btcnt ; add the length byte incf btcnt ; add the checksum byte movlw 0xff movwf bt ; used as sum register chk0 movf INDF, W ; fast CRC-8 algorithm with poly x^8+x^5+x^4+1 ; executes in 23 cycles per update xorwf bt,f clrw btfsc bt,7 xorlw 0x7a btfsc bt,6 xorlw 0x3d btfsc bt,5 xorlw 0x86 btfsc bt,4 xorlw 0x43 btfsc bt,3 xorlw 0xb9 btfsc bt,2 xorlw 0xc4 btfsc bt,1 xorlw 0x62 btfsc bt,0 xorlw 0x31 movwf bt incf FSR, F decfsz btcnt, F goto chk0 ; correct checksum must be zero movf bt, W bnz chk_err retlw 0 ; result is in Z chk_err retlw 0x0c ; checksum error | ||
| | #4 | |
Channel 1 shows the square wave output from the PIC pin to the RF Transmitter. Channel 3 shows the data pin on the RF Receiver. It's some pretty impressive code Nigel published considering it adjusts to missing header preamble bits and varying timing. | ||
| | #5 | |
![]() I just modified it to do what I wanted for the tutorial, the actual Manchester receive routines are VERY difficult to understand - but the transmit routines are nice and simple. | ||
| 433mhz, delays, modules, receiver, timing, transmitter |
| simple 433mhz antennas? | NleahciM | General Electronics Chat | 24 | 12th March 2009 12:22 PM |
| 433Mhz Tx help please | harry00000001 | General Electronics Chat | 3 | 20th May 2008 06:39 PM |
| Antenna for 433Mhz | folia | General Electronics Chat | 7 | 11th January 2007 10:11 PM |
| 433MHz transmitter | missy | Electronic Projects Design/Ideas/Reviews | 13 | 5th March 2006 09:48 AM |
| 433mhz rx | zachtheterrible | General Electronics Chat | 5 | 22nd April 2005 09:02 PM |
