Old 5th October 2009, 01:11 PM   #1
Default Lcd connection
Hello Guys!!!
I am using a 2*16 lcd module. My college sir told me that instead of connecting Vcc to pin no.2(Vcc) of lcd & using a pot between Vcc & gnd connecting its var. pin to pin no. 3(Vee) of lcd, connect directly Vcc to Vee of lcd & leave pin no. 2 of lcd open. He says, by these connections lcd will work fine. Is it correct?
Lε°ηiδμs
leonidus is offline
Old 5th October 2009, 01:20 PM   #2
Originally Posted by leonidus View Post
Hello Guys!!!
Some LCD's work with Vcontrast pin at 0V, but I would recommend a 10K pot from +5V to 0V with the wiper to Vcontrast.
This way you can set the optimum contrast for the LCD
ericgibbs is offline
Old 5th October 2009, 01:32 PM   #3
yes it is correct
you can leave pin2 and connect Vcc to VEE
you can see it in the attached simulation file
ziedan is offline
Old 5th October 2009, 02:00 PM   #4
Thank U Very Much Guys!!!
Ziedan which simulation software have u used? Is it available for free download?
Lε°ηiδμs
leonidus is offline
Old 5th October 2009, 02:13 PM   #5
Originally Posted by ziedan View Post
yes it is correct
You should not assume that a real LCD will function the same way as a simulated LCD.
Vee should be connected as per the datasheet.
This LCD help pdf will show the LCDconnections.
Old 6th October 2009, 01:28 AM   #6
MOST char LCD need fine tweaking of the Vo (Vee) voltage so they can be seen and look good.
Your college sir needs to do some more homework...
Mr RB is offline
Old 6th October 2009, 03:14 AM   #7
Check how I have connected LCD with PIC16F628A microcontroller.
Experiments with PIC16F628A
Thanks.
rajbex is offline
Old 6th October 2009, 05:54 PM   #8
i'm using proteus
and it is free to download and then crack it
ziedan is offline
Old 10th October 2009, 01:24 PM   #9
Thank U Everybody!!!
Lε°ηiδμs
leonidus is offline
Old 13th October 2009, 09:21 PM   #10
Hello Again!!!
I am using EAGLE for creating the layout. But, there are many overlaps in lcd connections when I connected lcd in standard fashion i.e. P0(0-7) to D(0-7) of lcd & P2(5,6,7) to RS,R/W,EN resp.. Instead if I connect P2(7-0) to D(0-7) & other 3 to P0 pins will it work fine?
While writing program I will take care that P2.7 to P2.0 are D0 to D7 respectively.
Latter one simplifies the problem.
Please help.
Lε°ηiδμs
leonidus is offline
Old 14th October 2009, 12:32 AM   #11
i'm using proteus
You are must be very SMART
I'm could be wrong many time's, at least I know what I'm doing.
http://shop.ebay.ca/merchant/csaba911
csaba911 is online now
connection, lcd
Looking for connection Pinouts, tft LCD doing_good General Electronics Chat 1 26th February 2008 01:16 PM
PS to PS connection? mmt General Electronics Chat 7 26th July 2006 01:17 AM
LCD programming and connection with assembly language microzone Micro Controllers 5 10th February 2006 04:14 PM
Though board connection 2camjohn General Electronics Chat 1 8th November 2004 07:54 PM
Connection for 2 D-9 MAX232 janetsmith2000@yahoo.com Micro Controllers 5 15th March 2004 06:59 AM
