+ Reply to Thread
Results 1 to 10 of 10
Thread: Olimex USB Programmer
  1. #1
    CR33PN Newbie
    Join Date
    Nov 2008
    Posts
    9
    Default Olimex USB Programmer
    I am having a problem programming chips with an Olimex USB programmer (pickstart plus clone).
    I have set the programmer in MPLab to Pickstart Plus and the Olimex appears to opperate the same whether there is a chip in the ZIF socket or not. If I read when there is no chip in the socket it gives me the same HEX file as if the chip is in there. Also if I do a blank check without a chip in the ZIF then it says device is blank when I would have thought it would have given some kind of error.
    Any suggestions for this problem?
  2. #2
    CR33PN Newbie
    Join Date
    Nov 2008
    Posts
    9
    Using MPLab version 8.33, PIC18F4520 and the Olimex board says 2005.
  3. #3
    be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    You need a Firmware upgrade to use with mplad 8.10 or newer
    Burt
  4. #4
    CR33PN Newbie
    Join Date
    Nov 2008
    Posts
    9
    Where do you get the upgrade from and how is it done?
  5. #5
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    Burt
  6. #6
    CR33PN Newbie
    Join Date
    Nov 2008
    Posts
    9
    Ok did that but didn't change anything and still get the same result.
    When I connect to the Olimex through MPLab it says I have PICSTART Plus Firmware Version 04.50.09 so I'm assuming this is the latest version (Upgrade 130).
  7. #7
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    I don't know what to tell you i use pickit2 I was hoping that would hook you up
    you know you have to have the 18f252 installed
    Burt
  8. #8
    CR33PN Newbie
    Join Date
    Nov 2008
    Posts
    9
    Well can you firstly tell me whether a picstart plus should give the response "Read successfully" when there is no chip in the zif socket to read?
    What could be causing it to think there is or what could it actually be reading? Could it be the 18F252 that's part of the programmer?
    What do you mean by "you know you have to have the 18f252 installed"? Yes it is in installed in the programmer which has been used before no problems, I have just inherited it from somone.
  9. #9
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    have a look at this maybe it will help http://ww1.microchip.com/downloads/e...Doc/51028f.pdf
    Read Appendix B. Troubleshooting
    Burt
  10. #10
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,709
    Blog Entries
    5
    The PicStart+ clone looks very different than a Genuine PS+. It may have been only a emulator at the software level and may not be compatible with modern PS+
    the original had a 17C series PIC but an update PCB socket adapter came out a few years ago that used an 18F PIC
    try an older MPLAB like 5.xx if you can still find it.
    Bill
    Smart Kits build Smart People
+ Reply to Thread
  1. USB Programmer
    By pjg777 in forum Micro Controllers
    Latest: 18th March 2006, 05:47 PM
  2. Max205 and olimex programmer with laptop serial
    By cgriffin in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th October 2005, 03:57 PM
  3. Olimex USB programmer?
    By Oznog in forum Micro Controllers
    Latest: 19th January 2005, 06:45 AM
  4. Olimex PIC programmer
    By Deagol_the_Dead in forum Micro Controllers
    Latest: 15th November 2003, 01:28 AM
  5. Who else has the Olimex serial PIC programmer?
    By BackInBlack in forum Micro Controllers
    Latest: 26th August 2003, 09:52 PM
Tags for this Thread
