Old 5th November 2009, 02:46 AM   #61
so can u help me with any material or code of making interfaces
lebohangmaphothoane is offline
Old 5th November 2009, 03:20 AM   #62
Hmmm, do you mean help or do it for you :P
Mike
My website: www.ElectroBird.net
birdman0_o is online now
Old 5th November 2009, 12:46 PM   #63
i would be pleased if you guide me, i want to use visual studio.but im confused since for USART and transmission of data through rs232 i used assembly language, i wonder if visual studio would allow me to create interface using assembly language. but if the interface is made by C or C++ would they be able to match with the code of turning motor because i have written it using assembly language. could u please make an interface for me then i would try to make it to communicate with rs232 then if i fail to make them communicate then i would be happy if u do it for me
Old 5th November 2009, 03:33 PM   #64
Can you download C++ (2008) It's free from microsoft, I could write you up some code, or the whole program I guess if I find the time.
Mike
Old 7th November 2009, 12:14 AM   #65
yes i have downloaded it
Old 7th November 2009, 06:57 PM   #66
Have you played around with it yet?
Mike
Old 9th November 2009, 12:06 AM   #67
iam in a place where internet is a problem i hardly access it and the bandwith is very small .i did not know that i have to be online when installing it. im trying my best to have it installed. but i have also got NetBeans IDE 6.7.1 installed in my computer and by tomorow i would know how it works. but i promise i would ask for visual c++ 2008 somewhere if i have a problem of installing it online.
Old 9th November 2009, 03:53 AM   #68
Where are you from anyways?
Mike
Old 11th November 2009, 01:26 AM   #69
Im from Southern Africa in Lesotho
Old 11th November 2009, 02:00 AM   #70
i have successfuly installed c++ 2008, like i promised. i have made an interface using JFrameBuilder(JBF_331). but it support java only and the code looks like this:
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
 * Summary description for turn
public class turn extends JFrame
	// Variables declaration
	private JButton jButton1;
	private JButton jButton2;
	private JPanel contentPane;
	// End of variables declaration
	public turn()
		super();
		initializeComponent();
		// TODO: Add any constructor code after initializeComponent call
		this.setVisible(true);
	private void initializeComponent()
		jButton1 = new JButton();
		jButton2 = new JButton();
		contentPane = (JPanel)this.getContentPane();
		// jButton1
		jButton1.setText("clockwise");
		jButton1.addActionListener(new ActionListener() {
			public void actionPerformed(ActionEvent e)
				jButton1_actionPerformed(e);
		// jButton2
		jButton2.setText("anticlockwise");
		jButton2.setMaximumSize(new Dimension(151, 25));
		jButton2.addActionListener(new ActionListener() {
				jButton2_actionPerformed(e);
		// contentPane
		contentPane.setLayout(null);
		addComponent(contentPane, jButton1, 26,32,83,28);
		addComponent(contentPane, jButton2, 194,38,108,28);
		// turn
		this.setTitle("turn - extends JFrame");
		this.setLocation(new Point(76, 59));
		this.setSize(new Dimension(390, 300));
	/** Add Component Without a Layout Manager (Absolute Positioning) */
	private void addComponent(Container container,Component c,int x,int y,int width,int height)
		c.setBounds(x,y,width,height);
		container.add(c);
	// TODO: Add any appropriate code in the following Event Handling Methods
	private void jButton1_actionPerformed(ActionEvent e)
		System.out.println("\njButton1_actionPerformed(ActionEvent e) called.");
		// TODO: Add any handling code here
	private void jButton2_actionPerformed(ActionEvent e)
		System.out.println("\njButton2_actionPerformed(ActionEvent e) called.");
		new turn();
i do not know how to write a code that can transmit data through rs232 using java language, im familiar with assembly language. the above code, i did not write it but i can see that i have to write instructions that would transmit and receive data under these two classes
Old 11th November 2009, 02:27 AM   #71
I looked into this idea a while ago since I am currently taking a Java class.
RS232 in Java for Windows | Sebastian Kuligowski's Home Page
Mike
Old 11th November 2009, 03:04 AM   #72
thanks i will look at it. i have installed C++ 2008 i would be glad if u do that code for me,
Old 11th November 2009, 04:26 AM   #73
I'll post it tomorrow, getting late here
Mike
Old 12th November 2009, 03:55 AM   #74
Im just seggesting. What about if you write the code in such away that, if clicking the button clockwise on the interface then a letter C must be send through rs232 then on the receiving side on the code of turning motor, i will check the received bit and if it is C then i will call the Subroutine that turn the motor clockwise. The same thing aplies if clicking the button anticlockwise then a letter A must be sent and on the receiving side i will call subroutine anticlockwise that would rotate the motor anticlockwise directon
Old 12th November 2009, 04:42 PM   #75
Here is your program and A video of it as promised!
The GUI you can fix up yourself if need be.
I hope you enjoy
(Sorry I don't have any stepper motors around so I just used an LCD to prove the point)
YouTube - C and A usart
Mike
control, home, light, smart, system
Guys this is my home made 2.1 Home Theater System pasanlaksiri Electronic Projects Design/Ideas/Reviews 40 11th November 2009 05:07 AM
Traffic light control system with timer display hocklin12 Electronic Projects Design/Ideas/Reviews 6 7th May 2009 09:10 PM
smart traffic light: HELP! Crystal86 Electronic Projects Design/Ideas/Reviews 3 22nd January 2009 04:17 PM
smart home using blue tooth jayanthi Electronic Projects Design/Ideas/Reviews 4 4th September 2008 04:29 PM
traffic light control system samcheetah Electronic Projects Design/Ideas/Reviews 3 3rd May 2004 07:30 PM
