Old 9th September 2009, 10:20 AM   #1
Default READING A PUSHBUTTON & display on LCD
I recently got a pikit 2, its the 1st time that im using push button switches.
im using 4 pushbuttons. when i power the circuit The LCD displays "infrared liquid level detector" permanently, so the lcd code and initialising is working.
All i want for now is:
when i press ENTER/Settings button....i want "enter/settings" to display on the LCD. And that is not happening when i press the button. Please help me solve this problem....i attached a picture of how i connect the switch to the pic.
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
char input_sw;
#define HOME_SW RC2				//HOME switch
#define INCREASE_SW RC3			//INCREASE switch
#define DECREASE_SW RC4			//DECREASE switch
#define ENTERSETTINGS_SW RA4    	//ENTERSETTINGS switch
void init(void)
    OSCCON|=0x60; //set fosc to 4Mhz
	TRISB=0x00;
	TRISC=0xFC;
        TRISA = 0b10000010; 	// RA7 high imp, RA3 is serial out,
	ANSEL=0x02;            //set RA1 as analog input for GP2 sensor
	ANSELH=0x00;
	lcd_init(); //call LCD initialisation
 void read_input_sw(void)
 char input_sw2;
 input_sw = ((HOME_SW*8)+(INCREASE_SW*4)+(DECREASE_SW*2)+(ENTERSETTINGS_SW*1)); //create a binary combination of the input switches
 if (input_sw != 0) //check if any of the switches are pressed
	 DelayMs(20); //switch debouncing
	 input_sw2 = ((HOME_SW*8)+(INCREASE_SW*4)+(DECREASE_SW*2)+(ENTERSETTINGS_SW*1));
	 while (input_sw2 != 0) //if a switch is pressed wait for release
void home_screen(void)
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
	read_input_sw();
	while(input_sw == 0)
		read_input_sw();
		switch(input_sw)
		case 8: break;
		//	ENTER/SETTINGS	button pressed
		case 1: {	lcd_clear();
		            lcd_goto_L1();
		            lcd_puts(" ENTER/SETTINGS ");
		            DelayS(1);
		            lcd_clear();
					break;
                   default : break; //should any abnormalties occur
	return;
void main(void)
	init();	// initialise I/O ports, LCD
	while (1)
	home_screen();
fantabulous68 is offline
Old 9th September 2009, 10:57 AM   #2
If thats how the buttons are wired then you have to check for a LOW signal.
like ..
char WaitForInput(void){
char done;
char temp;
done = 0;
while(!done){
    if(!ENTERSETTINGS_SW){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    DelayMs(20);    //debounce
    return temp;
and do this for calling in your main code:
if(WaitForInput = 1){
    //This is where you put code if the user pressed ENTER
if(WaitForInput = 2){
    //This is where you put code if the user pressed Home
if(WaitForInput = 3){
    //This is where you put code if the user pressed Increase
if(WaitForInput = 4){
    //This is where you put code if the user pressed Decrease
or
switch(WaitForInput){
    case 1:
        //User Pressed ENTER do something
        break;
    case 2:
        //User Pressed HOME do something
        break;
    case 3:
        //User Pressed INCREASE do something
        break;
    case 4:
        //User Pressed DECREASE do something
        break;
AtomSoft is offline
Old 9th September 2009, 11:10 AM   #3
Thanks ALOT AtomSoft...Im going to try that out now....
Old 9th September 2009, 11:17 AM   #4
heh no problem.
This would be the same but smoother:
  char temp;
  while(1){
        temp = 1;
        break;
    if(!HOME_SW){
        temp = 2;
        break;
    if(!INCREASE_SW){
        temp = 3;
        break;
    if(!DECREASE_SW){
        temp = 4;
        break;
  }//end of while
    return temp;
AtomSoft is offline
Old 9th September 2009, 11:28 AM   #5
Uhmm its giving an error
illegal type for switch expression
illegal conversion of integer to pointer
    case 1:
        break;
    case 2:
        break;
    case 3:
        break;
    case 4:
        break;
Old 9th September 2009, 11:32 AM   #6
oops try this:
switch(WaitForInput()){
    case 1:
        break;
    case 2:
        break;
    case 3:
        break;
    case 4:
        break;
if that fails then simply:
input_sw = WaitForInput();
switch(input_sw){
    case 1:
        break;
    case 2:
        break;
    case 3:
        break;
    case 4:
        break;
AtomSoft is offline
Old 9th September 2009, 11:49 AM   #7
hehe, the 1st 1 worked, now for the lol testing it on the circuit
Old 9th September 2009, 11:59 AM   #8
heh good luck. I leave in about 1 hours for errands then come home then wait about 1 hours till i have to goto work. so enjoy and have fun. and if you need help ill try to post .
AtomSoft is offline
Old 9th September 2009, 12:04 PM   #9
yay lol getting somewhere. i tested it now.
when i power up without pressing switches it displays:
clears then
enter/settings
clears then
clears then
enter/settings
and keeps doing this.......
when i press the home button down continuously :
it displays
"infrared liquid level detector" continuously
thats correct because the home button takes you to the home screen
when i release the home button then:
clears then
enter/settings
clears then
clears then
enter/settings
uhmm im going to play around to see if i can get it to stay at enter/settings screen
Old 9th September 2009, 12:05 PM   #10
Thanks again n again n again. Im very happy now....that im seeing some progress.
Going to continue to make all the buttons work now. ill b backfor sure
Old 9th September 2009, 01:02 PM   #11
heh was bored and about to leave but i have a gift
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
void init(void);
char WaitForInput(void);
void home_screen(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void main(void);
void init(void)
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
  char temp;
  while(1){
        temp = 1;
        break;
    if(!HOME_SW){
        temp = 2;
        break;
    if(!INCREASE_SW){
        temp = 3;
        break;
    if(!DECREASE_SW){
        temp = 4;
        break;
  }//end of while
    return temp;
void home_screen(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
void EnterScreen(void){
	lcd_clear();
	lcd_goto_L1();
	DelayS(1);
	lcd_clear();
void ShowDigits(unsigned char val){
    MyValLCD[0] = val /10;    //returns the quotient (if temp = 35 the result is 3)
    MyValLCD[1] = val % 10; 	//Returns remainder   (if temp = 35 the result is 5)
	MyValLCD[0] += 0x30;	//to ASCII
	MyValLCD[1] += 0x30;	//to ASCII
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_data(MyValLCD[0]);	//to LCD
	lcd_data(MyValLCD[1]);  //to LCD
void main(void)
	home_screen();
	MyVal = 0;
	MyMinVal = 0;
	MyMaxVal = 99;
while(1){
    switch(input_sw){
      case 1:
      	EnterScreen();
		mnuPOS = 1;
        break;
      case 2:
		home_screen();
		mnuPOS = 2;
        break;
	while(mnuPOS == 1){
      switch(input_sw){
		case 1:
			mnuPOS = 2;
			home_screen();
			break;
      	case 3:
			if(MyVal < MyMaxVal)
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
			if(MyVal > MyMinVal)
      			MyVal--;
			ShowDigits(MyVal);
        	break;
	//Do something here with the new Value which is a decimal in MyVal.
AtomSoft is offline
Old 9th September 2009, 07:24 PM   #12
Hehe, that was a nice surprise when i logged in again. Thanks lol i hope you not counting how many times i said that I tried the code. i commented home screen() in the main code otherwise it only displays infra red liquid level detector and ignores the button presses.
void main(void)
	//home_screen();
ALSO
it works when i replace:
  char temp;
  while(1){
        temp = 1;
        break;
    if(!HOME_SW){
        temp = 2;
        break;
    if(!INCREASE_SW){
        temp = 3;
        break;
    if(!DECREASE_SW){
        temp = 4;
        break;
  }//end of while
    return temp;
with:
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
if i dont replace it then pressing the buttons has no affect...it keeps displaying "enter/settings"
when i replace it and power on:
"enter/settings" is displayed continuously
when i press home button: infra red liquid level detect is displayed.
it does not display the full word "detector"
when i release home button: "enter/settings" is displayed continuously
when i press increase button: the screen remains blank
when i release increase button:"enter/settings" is displayed continuously
uhmmm it does not show the number of times the button is pressed on the LCD
when i press decrease button: the screen remains blank
when i release decrease button:"enter/settings" is displayed continuously
when i press home/settings button:"enter/settings" is displayed continuously
when i release home/settings button:"enter/settings" is displayed continuously
Old 9th September 2009, 07:31 PM   #13
im thinking maybe this:
is affecting the "detect" word from being "detector".
i was bread boarding a switch mode power supply-boost regulator
3.2V to 5V, im waiting for the batteries to charge so i can test it...hehe.
Old 9th September 2009, 08:07 PM   #14
that should not affect the other text.
Can you post full code?
Try this:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
char input_sw;
char mnuPOS;
void init(void);
void main(void);
void init(void)
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    DelayMs(150);    //debounce
    return temp;
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID "); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR  "); //home screen message (line 2)
	lcd_clear();
	lcd_goto_L1();
	DelayS(1);
	lcd_clear();
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
void main(void)
    DelayMs(20);    // init delay
	home_screen();	//display home screen
	MyVal = 0;
	MyMinVal = 0;
	MyMaxVal = 99;
	mnuPOS = 2;
while(1){
    switch(input_sw){
      case 1:
      	EnterScreen();
		mnuPOS = 1;
        break;
      case 2:
		home_screen();
		mnuPOS = 2;
        break;
	while(mnuPOS == 1){
    	DelayMs(50);    //debounce #2 for a total of 200ms (user can press button 5 times in 1 second)
      switch(input_sw){
		case 1:
			mnuPOS = 2;
			home_screen();
			break;
      	case 3:
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			ShowDigits(MyVal);
        	break;
AtomSoft is offline
Old 9th September 2009, 08:13 PM   #15
Default Heres the code i used and remarked on
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
void main(void);
void calc_distance(void);
#define LCD_RS RC0		//LCD RS pin
#define LCD_EN RC1		//LCD EN pin
#define LCD_STROBE()	LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10;		//
unsigned char cm;		//
unsigned int math;		// used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
char temp[8];
int height=50, SensorPos=10;
char input_sw;
char mnuPOS;
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
      scale=floor(0.5+scale/10.0);
      d=(unsigned char) (n/scale);
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
      n=n*10.0;
      d=(unsigned char) n;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if	XTAL_FREQ <= 2MHZ
	do {
		DelayUs(996);
	} while(--cnt);
#endif
#if    XTAL_FREQ > 2MHZ
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
void DelayS(unsigned char cnt)
	for (j=0; j<(cnt*10); j++)
		DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
	DelayMs(20); //wait for LCD to be ready
	LCD_RS = 0;	 //write instruction
	PORTB = (c & 0xF0); //load upper nibble on LCD data lines
	LCD_STROBE(); //send instruction to LCD
	PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
	PORTB = 0x00;
	LCD_RS = 1; //write data
    PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
	PORTB &= 0x00; //load upper nibble on LCD data lines
	PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
	lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
	j = -1;
	while(s[++j]!=('\0')) // send characters until null character reached
		lcd_data(s[j]);
/*go to beginning of line 1*/
	lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
	lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
	lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	DelayMs(20); //wait for LCD startup
	lcd_cmd(0x28);	// 4-bit mode
	lcd_cmd(0x08);	// display off
	lcd_cmd(0x01);	// clear display
	lcd_cmd(0x0C);	// disp. on, cursor off, cursor blink off
	lcd_cmd(0x06);	// entry mode
	lcd_cmd(0x80);  // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	DelayS(1);
	lcd_clear();
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	// from the transeiver datasheet the analog voltage is
	// the inverse of distance, so distance can be calculated
	// d = (1 / volts) then just scaled to suit the transeiver
	// load ADC value in 16bit math var
	math = ADRESH;
	math = (math * 256);
	math += ADRESL;
	// now invert it; (1 / volts) use (6050 / volts) for scaling
	math = (6050 / math);
	if(math >= 2) math -=2;		// fix linear error (-2)
	if(math > 99) math = 99;	// max limit at 99cm
	// convert from 0-99 to 2 decimal digits, 0-99cm
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
void main(void)
    //home_screen();
	MyVal = 0;
	MyMinVal = 0;
	MyMaxVal = 99;
while(1){
    switch(input_sw){
      case 1:
      	EnterScreen();
		mnuPOS = 1;
        break;
      case 2:
		home_screen();
		mnuPOS = 2;
        break;
	while(mnuPOS == 1){
      switch(input_sw){
		case 1:
			mnuPOS = 2;
			home_screen();
			break;
      	case 3:
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			ShowDigits(MyVal);
        	break;
display, lcd, pushbutton, reading
Substituting a 16x2 LCD display for 16x1 LCD display? Dawny Electronic Projects Design/Ideas/Reviews 19 11th October 2008 09:58 AM
Pushbutton Slow & Repeating Pulse btanner Electronic Projects Design/Ideas/Reviews 1 22nd January 2008 06:18 PM
Is this display burned out? (Sony MD LCD Display) Amphr_Moth General Electronics Chat 4 28th October 2007 07:47 PM
how to display '-' & '+' range number on LCD? meera83 Micro Controllers 8 5th July 2007 09:56 AM
lcd display with hd44780 display driver ANUPAMA Micro Controllers 2 7th April 2004 02:58 PM
