Old 18th September 2009, 03:29 PM   #106
It needs to be pretty fast to detect the changes in the level of the liquid
MATHKEEP Ok thats a better solution by far...lol dont know why my thinking is so complicated hehehe maybe coz im a gal
Learn without thinking begets ignorance. Think without learning is dangerous.
fantabulous68 is offline
Old 18th September 2009, 03:54 PM   #107
Thanks AtomSoft....You helped solve alot of problems
Old 18th September 2009, 04:19 PM   #108
unsigned char LLHigh, LLLow;
unsigned int LiquidLevel;
void calc_distance(void)
unsigned int mathKeep;		// used for voltage calculations backup
	// from the transeiver datasheet the analog voltage is
	// the inverse of distance, so distance can be calculated
	// d = (1 / volts) then just scaled to suit the transeiver
	// load ADC value in 16bit math var
	math = ADRESH;
	math = (math * 256);
	math += ADRESL;
	// now invert it; (1 / volts) use (6050 / volts) for scaling
	math = (6050 / math);
	if(math >= 2) math -=2;		// fix linear error (-2)
	if(math > 99) math = 99;	// max limit at 99cm
	//Create a copy of math for more use
	mathKeep = math;
	// convert from 0-99 to 2 decimal digits, 0-99cm
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	math = mathKeep;	//Now our original data is back and can be used.
	do i need to say height=user_input???
      LiquidLevel=height-math;
      //LiquidLevel is higher than 09 so spilt the variable LiquidLevel into 2 //
      LLHigh = ( LiquidLevel / 10 ) + '0'; //
      LLLow = ( LiquidLevel % 10 ) + '0';  //
Old 18th September 2009, 04:27 PM   #109
LOL it workzzzzzzzzzzzzzzzzzzzzzzzz!!!!!!
it displays the height-liquid level
Old 18th September 2009, 04:30 PM   #110
I only made the changes in RED highlight..................
I entered the height as 70cm
i put a paper 10cm away from the sensor...
& it says measured 60cm
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>	//
void userMenu(char pos); //
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(char expire);
unsigned char user_input(void);
void home_screen(void);
void EnterHeight(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void calc_distance(void);
void main(void);
unsigned char cm2LCD;
#define LCD_RS RC0		//LCD RS pin
#define LCD_EN RC1		//LCD EN pin
#define LCD_STROBE()	LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10;		//
unsigned char cm;		//
unsigned int math;		// used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
//char temp[8];
//[/b]
unsigned char height=50;
unsigned char range;
unsigned char area;
unsigned char SensorPos=10;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
unsigned long bres;		// for bresenham 2-second timer system
unsigned char ;
#define HOME_SW RC2				//HOME switch
#define INCREASE_SW RC3			//INCREASE switch
#define DECREASE_SW RC4			//DECREASE switch
#define ENTERSETTINGS_SW RA4	//ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
      scale=floor(0.5+scale/10.0);
      d=(unsigned char) (n/scale);
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
      n=n*10.0;
      d=(unsigned char) n;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if	XTAL_FREQ <= 2MHZ
	do {
		DelayUs(996);
	} while(--cnt);
#endif
#if    XTAL_FREQ > 2MHZ
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
void DelayS(unsigned char cnt)
	for (j=0; j<(cnt*10); j++)
		DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
	DelayMs(2); //wait for LCD to be ready shorter delay
	LCD_RS = 0;	 //write instruction
	PORTB = (c & 0xF0); //load upper nibble on LCD data lines
	LCD_STROBE(); //send instruction to LCD
	PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
	PORTB = 0x00;
	LCD_RS = 1; //write data
    PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
	PORTB &= 0x00; //load upper nibble on LCD data lines
	PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
	lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
	j = -1;
	while(s[++j]!=('\0')) // send characters until null character reached
		lcd_data(s[j]);
/*go to beginning of line 1*/
	lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
	lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
	lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	DelayMs(20); //wait for LCD startup
	lcd_cmd(0x02);
	lcd_cmd(0x28);	// 4-bit mode
	lcd_cmd(0x08);	// display off
	lcd_cmd(0x01);	// clear display
	lcd_cmd(0x0C);	// disp. on, cursor off, cursor blink off
	lcd_cmd(0x06);	// entry mode
	lcd_cmd(0x80);  // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
	// setup the PIC 16f690
	OSCCON = 0x72;      	// internal osc, 8MHz
	PORTA = 0;
	TRISA = 0b10010010; 	// RA7 high imp, RA3 is serial out, RA4 button input
 	PORTB = 0;          	// PORTB not used
    WPUB = 1;				// PORTB pullups ON
    RABPU = 0;
    /* Init ADC */
    ADCON0 = 0b10000101;	// bit 7 right justify,analogue channel select bits bits5-2  0001=AN1,ADC ON, RA1 is ADC input
	ADCON1 = 0b00100000;	//bits6-4  fosc/32
    ADON=1;	                // turn on the A2D conversion module
	ANSEL=0x02;            //set RA1 as analog input for GP2 sensor
	ANSELH=0x00;
    T1CON = 0b00010001;     // TMR1 is ON, 1:2 prescale, =1MHz
	T2CON = 0b00000101;     // TMR2 is ON, 1:4 prescale, =1MHz
	MyVal = 0; //initializn these variables here
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	lcd_init(); //call LCD initialisation
//EDITED this a bit. now if expire input is set it will leave loop with a 0
//instead of rechecking this will be useful for display your measured data and
//waiting for user to exit.
char WaitForInput(char expire){
char done;
char temp;
done = 0;
temp = 0;
while(!done){
    if(!ENTERSETTINGS_SW){
		while(ENTERSETTINGS_SW);
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
	if(expire == 1) break;
}//end of while
    DelayMs(150);    //debounce
    return temp;
void userMenu(char pos){
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			lcd_puts("    HEIGHT    ");
			break;
		case 1:
			lcd_puts("    RANGE     ");
			break;
		case 2:
			lcd_puts(" SURFACE AREA ");
			break;							//
		case 3:
			lcd_puts("   MEASURED   ");
			 while(WaitForInput(1) != 2){		//Wait for user to press enter to leave loop
 				// wait for 2 seconds, uses TMR1 free running at 1Mhz
   				while(!TMR1IF)  		// wait for TMR1 overflow
				TMR1IF = 0; 			// clear overflow flag
				bres += 65536;			// add 65536uS to bres value
				if(bres >= 250000)		// if reached 2 seconds!
    				bres -= 250000;	// subtract 2 seconds, keep error
					// read the ADC voltage RA1 (Sharp GP2 sensor)
					GODONE=1;					// initiate conversion on the channel 0
					while(GODONE) continue;  	// Wait convertion done
					calc_distance();			// convert ADC value to distance
				    lcd_goto_L2();				//Only change line 2
					lcd_data(LLHigh + '0');
					lcd_data(LLLow + '0');
	    			lcd_puts(" [cm] ");			//comment this out if you want
		lcd_goto_L1();
		lcd_puts(" Loading Home ");
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	if(pos == 3) return;
	lcd_goto_L2();
	lcd_puts("Press Up/Down"); //home screen message (line 2)
// New Menu System
void EnterHeight(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" ENTER HEIGHT ");
	lcd_goto_L2();
void EnterScreen(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
void ShowDigits(unsigned char val){
    MyValLCD[0] = val /10;    //returns the quotient (if temp = 35 the result is 3)
    MyValLCD[1] = val % 10; 	//Returns remainder   (if temp = 35 the result is 5)
	MyValLCD[0] += 0x30;	//to ASCII
	MyValLCD[1] += 0x30;	//to ASCII
	EnterScreen();
	lcd_goto_L2();
	lcd_data(MyValLCD[0]);	//to LCD
	lcd_data(MyValLCD[1]);  //to LCD
	math = ADRESH;
	math += ADRESL;
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
unsigned char user_input(void)		//This will return what we want
	char done = 0;
	MyVal = 0;			//Start on 0
	while(done == 0){
   	  input_sw = WaitForInput(0);
      switch(input_sw){
		case 1:
			done = 0xff; 			//This tells us the user finished entering
			lcd_goto_L1();
			lcd_puts("      OK       "); //home screen message (line 1)
			break;
      	case 3:
			if(MyVal < MyMaxVal)
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
			if(MyVal > MyMinVal)
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
void home_screen(void){
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
	input_sw = 0;			//Reset the value
	while(input_sw != 1)  	//Wait until enter is pressed
	userMenu(0);
	DelayMs(2);				//shorter delay
    height = user_input();	//The HEIGHT var will have the myVal
	userMenu(1);
    range = user_input();	//The HEIGHT var will have the myVal
	userMenu(2);
    area = user_input();	//The HEIGHT var will have the myVal
	userMenu(3);
//Waits for user to press ENTER to show home screen
void main(void)
    init();	// initialise I/O ports, LCD
    while(1){
 	home_screen();
 /*// wait for 2 seconds, uses TMR1 free running at 1Mhz
	if(bres >= 2000000)		// if reached 2 seconds!
    	bres -= 2000000;	// subtract 2 seconds, keep error
	//	LiquidLevel=height-;
	//	lcd_clear();                // Using the new menu you can erase or
	//	lcd_data(cm10 + '0');
	//	lcd_data(cm + '0');
	 //   lcd_goto_L2();
	   // lcd_puts("[cm] ");			//comment this out if you want
Hehe...just applying YOUR tricks there AtomSoft......................................
Fast learner lol i hope i am...........THANX THANX THANX AtomSoft 4 President!!!
Uhmmmmm but i still got to work on speeding it up.....(i am goin to do that now)
Old 18th September 2009, 06:46 PM   #111
OMG!!!! i dont know what happened now.....i reloaded the exact code from above(the one i made changes to...the one that was working) but!!!
the measured "values" are ALPHABETS!!!! now
Old 18th September 2009, 07:26 PM   #112
Ok there it is..... Shew!!!!working again BUT i noticed that.....it does still display measurements as ALPHABETS but this happens in acertain case.....:
CASE 1[negative case]
Eg if height=30
distance away from sensor=40
liquid level will thus be=-10 BUT we dont have negative distances....
*(uhmmmm i declared LiquidLevel as unsigned int)
AND thats when it displays all funny kind alien like wingding symbols hehehe...
CASE 2 [positive case]
But if height=30
distance away from sensor=10
lcd displays measuerd distance=20cm
So basically the negative case(liquid level is higher than the container-maybe an overflow) is like an impossible situation in which case it would be appropriate to display a suitable message if the distance is negative???
Uhmmm but also i should consider displaying a message if the container is full
ie. container height=liquid level
Well i want to know what can i do to prevent those funny symbols from appearing????
& how can i speed up the sensor....i tried in vein hehe
ADCON2 = 0b10100010; // right justify, 8Tad, 32Tosc would increasing the32Tosc help?
O the speed all deals with the timer?
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	PORTA = 0;
    RABPU = 0;
    /* Init ADC */
	ANSELH=0x00;
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
				    lcd_data(LLHigh);
    		 	    lcd_data(LLLow);
		lcd_goto_L1();
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
// New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	mathKeep = math;
    //LiquidLevel=height-;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	userMenu(0);
	userMenu(1);
	userMenu(2);
	userMenu(3);
"enter height"
call enter/settings (which is now user input function in new code)
height=MyVal
"enter range"
call user_input
range=MyVal
"enter surface area"
call user_input
area=MyVal
/*  Junebug_Serial4.c    RomanBlack.com 19th July 2009.
    uses "zero error 1 second timer"
	system to generate a 2 second interval, then every
	2 seconds it reads an analog voltage from a
	Sharp GP2 distance sensor and converts it to decimal
	distance, then sends that data to a LCD
	Code for MikroC, config handled by MikroC compiler;
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    while(1){
 	home_screen();
	 //   lcd_goto_L2();
Old 18th September 2009, 09:22 PM   #113
no if you take out that delay or make it less then its faster:
    unsigned int delaytime = 100000; // 100ms CHANGE THIS FOR YOUR BELOW DELAY
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
				if(bres >= delaytime )		// if reached 2 seconds!
    				bres -= delaytime ;	// subtract 2 seconds, keep error
					lcd_data(cm + '0');
		lcd_goto_L1();
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
AtomSoft is offline
Old 18th September 2009, 09:32 PM   #114
sorry im not a negative number person not sure how to allow it... just got back from work. Ill take a look in a minute
AtomSoft is offline
Old 18th September 2009, 10:28 PM   #115
Yeah thats cool
Maybe i should say something like :
1)if liquid level<0 [ie. negative]
[this would happen for an over flow ie .when the level of the liquid is > height of container]
then--> lcd display "ERROR"
in this way it would prevent funny symbols from being displayed...........
AND all negative distances will be represented by "error"
2)if liquid level=height then--> lcd display "FULL"
3)if liqud level level=00 then--> lcd display "EMPTY"
so these 3 cases cater for all 3 scenarios that can take place.....
sounds good???
Old 18th September 2009, 11:01 PM   #116
The speed is much much better now-only changed the part in RED.....hope im displaying it correctly to LCD. The alien wingdings appear when the level is negative otherwise it displays positive values correctly
					lcd_data(LLHigh);
					lcd_data(LLLow);
here the code with the red highlight included:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	PORTA = 0;
    RABPU = 0;
    /* Init ADC */
	ANSELH=0x00;
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
					lcd_data(LLHigh);
					lcd_data(LLLow);
		lcd_goto_L1();
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
// New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	userMenu(0);
	userMenu(1);
	userMenu(2);
	userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    while(1){
 	home_screen();
	 //   lcd_goto_L2();
I didnt use this below to display
	//	lcd_data(LLLow + '0');
because the LCD displays ALPHABET measurements
EG
Measured
ae
Old 18th September 2009, 11:52 PM   #117
Try this it will show 00cm if its a Negative:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	PORTA = 0;
    RABPU = 0;
    /* Init ADC */
	ANSELH=0x00;
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
		while(HOME_SW);
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
		while(INCREASE_SW);
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
		while(DECREASE_SW);
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;							//
		case 3:
					lcd_data(LLHigh);
					lcd_data(LLLow);
		lcd_goto_L1();
		lcd_goto_L2();
		lcd_puts("              ");
		DelayS(1);
		break;
	lcd_goto_L2();
// New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	mathKeep = math;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	//This will check if negative
        if((LiquidLevel < 0) || (LiquidLevel > 0xFFB0))
		LiquidLevel = 0;
	//if below zero which will be in the 0xFFFF range i just chose any 0xFFxx number :D
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayMs(250);
	DelayMs(250);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	userMenu(0);
	userMenu(1);
	userMenu(2);
	userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    while(1){
 	home_screen();
	 //   lcd_goto_L2();
AtomSoft is offline
Old 19th September 2009, 04:55 AM   #118
The usual way to handle negative numbers is by doing something like,
    if(value<0){        //if negative
        value=-value;   //negate it
        LcdPut('-')     //print minus character
    }else{              //if positive
        LcdPut(' ')     //print space to keep allignment
As you are doing the calcs in a function, you could set a flag in you code when you negate it.
Pommie is online now
Old 19th September 2009, 09:56 AM   #119
ok i will try the code....Thanx AtomSoft....
Tried it & it works....
*i will also write some code for calculating the volume of the liquid in the container....
surface area X level of liquid
Now later today im going to test this "IR LLD" on LIQUIDS How exciting lol....................I hope it works accurately.....
For now im going to start learning for my exams
Old 19th September 2009, 10:03 AM   #120
Originally Posted by fantabulous68 View Post
ok i will try the code....Thanx Atom....
bt i think it should only display 00cm when its empty
i think "error/overflow" is more suitable for the negative case
Morning Miss f,
IMO 'error/overflow' is misleading, sounds as though the 'tank' is over full.
Pommie's method is often used to indicate less than zero values.
ericgibbs is offline
display, lcd, pushbutton, reading
Substituting a 16x2 LCD display for 16x1 LCD display? Dawny Electronic Projects Design/Ideas/Reviews 19 11th October 2008 09:58 AM
Pushbutton Slow & Repeating Pulse btanner Electronic Projects Design/Ideas/Reviews 1 22nd January 2008 06:18 PM
Is this display burned out? (Sony MD LCD Display) Amphr_Moth General Electronics Chat 4 28th October 2007 07:47 PM
how to display '-' & '+' range number on LCD? meera83 Micro Controllers 8 5th July 2007 09:56 AM
lcd display with hd44780 display driver ANUPAMA Micro Controllers 2 7th April 2004 02:58 PM
