| | #91 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() clearing the LCD gets rid of the lol "LooooOOooG values" ![]() ![]() Thanks Atomsoft......... ************************************************** *** Shady's back....back again...hehe AtomSoft im trying to integrate the user input with the sensor code..... (both work separately) When i uncomment home and run the code....it allows the user to enter values but when i press enter ...and am done! it returns to the home screen..."IR LLD' which is what i want.... BUT i want it to display the distance measurements after that and not stick on the home screen..... do i need a lcd_clear() somewhere again ???to clear "IR LLD" and show the distance.... or do i need to prevent the used input function from coming back to the home screen when entering inputs is "done!" ???Code:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h> //
void userMenu(char pos); //
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(void);
unsigned char user_input(void);
void home_screen(void);
void EnterHeight(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void calc_distance(void);
void main(void);
unsigned char cm2LCD;
unsigned char cmHigh, cmLow;
#define LCD_RS RC0 //LCD RS pin
#define LCD_EN RC1 //LCD EN pin
#define LCD_STROBE() LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10; //
unsigned char cm; //
unsigned int math; // used for voltage calculations
unsigned int LiquidLevel;
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
//char temp[8];
//[/b]
unsigned char height=50;
unsigned char range;
unsigned char area;
unsigned char SensorPos=10;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
unsigned long bres; // for bresenham 2-second timer system
unsigned char ;
#define HOME_SW RC2 //HOME switch
#define INCREASE_SW RC3 //INCREASE switch
#define DECREASE_SW RC4 //DECREASE switch
#define ENTERSETTINGS_SW RA4 //ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
scale=floor(0.5+scale/10.0);
d=(unsigned char) (n/scale);
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
n=n*10.0;
d=(unsigned char) n;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if XTAL_FREQ <= 2MHZ
do {
DelayUs(996);
} while(--cnt);
#endif
#if XTAL_FREQ > 2MHZ
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
void DelayS(unsigned char cnt)
for (j=0; j<(cnt*10); j++)
DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
DelayMs(2); //wait for LCD to be ready shorter delay
LCD_RS = 0; //write instruction
PORTB = (c & 0xF0); //load upper nibble on LCD data lines
LCD_STROBE(); //send instruction to LCD
PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
PORTB = 0x00;
LCD_RS = 1; //write data
PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
PORTB &= 0x00; //load upper nibble on LCD data lines
PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
j = -1;
while(s[++j]!=('\0')) // send characters until null character reached
lcd_data(s[j]);
/*go to beginning of line 1*/
lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
DelayMs(20); //wait for LCD startup
lcd_cmd(0x02);
lcd_cmd(0x28); // 4-bit mode
lcd_cmd(0x08); // display off
lcd_cmd(0x01); // clear display
lcd_cmd(0x0C); // disp. on, cursor off, cursor blink off
lcd_cmd(0x06); // entry mode
lcd_cmd(0x80); // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
// setup the PIC 16f690
OSCCON = 0x72; // internal osc, 8MHz
PORTA = 0;
TRISA = 0b10010010; // RA7 high imp, RA3 is serial out, RA4 button input
PORTB = 0; // PORTB not used
WPUB = 1; // PORTB pullups ON
RABPU = 0;
/* Init ADC */
ADCON0 = 0b10000101; // bit 7 right justify,analogue channel select bits bits5-2 0001=AN1,ADC ON, RA1 is ADC input
ADCON1 = 0b00100000; //bits6-4 fosc/32
ADON=1; // turn on the A2D conversion module
ANSEL=0x02; //set RA1 as analog input for GP2 sensor
ANSELH=0x00;
T1CON = 0b00010001; // TMR1 is ON, 1:2 prescale, =1MHz
T2CON = 0b00000101; // TMR2 is ON, 1:4 prescale, =1MHz
MyVal = 0; //initializn these variables here
MyMinVal = 0;
MyMaxVal = 99;
TRISB=0x00;
TRISC=0xFC;
lcd_init(); //call LCD initialisation
char WaitForInput(void){
char done;
char temp;
done = 0;
while(!done){
if(!ENTERSETTINGS_SW){
temp = 1;
done = 0xff;
if(!HOME_SW){
temp = 2;
done = 0xff;
if(!INCREASE_SW){
temp = 3;
done = 0xff;
if(!DECREASE_SW){
temp = 4;
done = 0xff;
}//end of while
DelayMs(150); //debounce
return temp;
void userMenu(char pos){
lcd_clear();
lcd_goto_L1();
switch(pos){
case 0:
lcd_puts(" HEIGHT ");
break;
case 1:
lcd_puts(" RANGE ");
break;
case 2:
lcd_puts(" SURFACE AREA ");
break;
lcd_goto_L2();
lcd_puts("Press Up/Down"); //home screen message (line 2)
// New Menu System
void EnterHeight(void){
lcd_clear();
lcd_goto_L1();
lcd_puts(" ENTER HEIGHT ");
lcd_goto_L2();
void EnterScreen(void){
lcd_clear();
lcd_goto_L1();
lcd_puts(" [cm] ");
void ShowDigits(unsigned char val){
MyValLCD[0] = val /10; //returns the quotient (if temp = 35 the result is 3)
MyValLCD[1] = val % 10; //Returns remainder (if temp = 35 the result is 5)
MyValLCD[0] += 0x30; //to ASCII
MyValLCD[1] += 0x30; //to ASCII
EnterScreen();
lcd_goto_L2();
lcd_data(MyValLCD[0]); //to LCD
lcd_data(MyValLCD[1]); //to LCD
// from the transeiver datasheet the analog voltage is
// the inverse of distance, so distance can be calculated
// d = (1 / volts) then just scaled to suit the transeiver
// load ADC value in 16bit math var
math = ADRESH;
math = (math * 256);
math += ADRESL;
// now invert it; (1 / volts) use (6050 / volts) for scaling
math = (6050 / math);
if(math >= 2) math -=2; // fix linear error (-2)
if(math > 99) math = 99; // max limit at 99cm
//LiquidLevel=height-;
// convert from 0-99 to 2 decimal digits, 0-99cm
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
unsigned char user_input(void) //This will return what we want
char done = 0;
MyVal = 0; //Start on 0
while(done == 0){
input_sw = WaitForInput();
switch(input_sw){
case 1:
done = 0xff; //This tells us the user finished entering
lcd_goto_L1();
lcd_puts(" Done! "); //home screen message (line 1)
break;
case 3:
if(MyVal < MyMaxVal)
MyVal++;
EnterScreen();
ShowDigits(MyVal);
break;
case 4:
if(MyVal > MyMinVal)
MyVal--;
EnterScreen();
ShowDigits(MyVal);
break;
default:
break;
DelayS(1);
return MyVal;
void home_screen(void){
mnuPOS = 0;
lcd_clear();
lcd_goto_L1();
lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
lcd_goto_L2();
lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
input_sw = 0; //Reset the value
while(input_sw != 1) //Wait until enter is pressed
userMenu(0);
DelayMs(2); //shorter delay
height = user_input(); //The HEIGHT var will have the myVal
userMenu(1);
range = user_input(); //The HEIGHT var will have the myVal
userMenu(2);
area = user_input(); //The HEIGHT var will have the myVal
"enter height"
call enter/settings (which is now user input function in new code)
height=MyVal
"enter range"
call user_input
range=MyVal
"enter surface area"
call user_input
area=MyVal
/* Junebug_Serial4.c RomanBlack.com 19th July 2009.
uses "zero error 1 second timer"
system to generate a 2 second interval, then every
2 seconds it reads an analog voltage from a
Sharp GP2 distance sensor and converts it to decimal
distance, then sends that data to a LCD
Code for MikroC, config handled by MikroC compiler;
_INTI02_OSC_1H
_WDT_OFF_2H
-MCLRE_ON_3H
_LVP_OFF_4L
_PWRT_ON_2L
void main(void)
init(); // initialise I/O ports, LCD
while(1){
home_screen();
// wait for 2 seconds, uses TMR1 free running at 1Mhz
while(!TMR1IF) // wait for TMR1 overflow
TMR1IF = 0; // clear overflow flag
bres += 65536; // add 65536uS to bres value
if(bres >= 2000000) // if reached 2 seconds!
bres -= 2000000; // subtract 2 seconds, keep error
// read the ADC voltage RA1 (Sharp GP2 sensor)
GODONE=1; // initiate conversion on the channel 0
while(GODONE) continue; // Wait convertion done
calc_distance(); // convert ADC value to distance
// LiquidLevel=height-;
lcd_clear(); //
lcd_data(cm10 + '0');
lcd_data(cm + '0');
lcd_goto_L2();
lcd_puts("[cm] ");
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. Last edited by fantabulous68; 17th September 2009 at 11:52 AM. | ||
| | #92 |
Try this: Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
n=n*10.0;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
do {
DelayUs(996);
} while(--cnt);
#endif
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
DelayMs(100);
PORTB = 0x00;
/*Clear the LCD*/
j = -1;
lcd_data(s[j]);
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
lcd_cmd(0x02);
void init(void)
PORTA = 0;
RABPU = 0;
/* Init ADC */
ANSELH=0x00;
MyMinVal = 0;
MyMaxVal = 99;
TRISB=0x00;
TRISC=0xFC;
char done;
char temp;
done = 0;
while(!done){
temp = 1;
done = 0xff;
if(!HOME_SW){
temp = 2;
done = 0xff;
if(!INCREASE_SW){
temp = 3;
done = 0xff;
if(!DECREASE_SW){
temp = 4;
done = 0xff;
}//end of while
return temp;
lcd_clear();
lcd_goto_L1();
switch(pos){
case 0:
break;
case 1:
break;
case 2:
break; //
case 3:
lcd_puts(" Measured ");
lcd_goto_L2();
lcd_data(cm + '0');
lcd_puts(" [cm] ");
break; //
if(pos == 3) return;
lcd_goto_L2();
// New Menu System
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
lcd_clear();
lcd_goto_L1();
lcd_puts(" [cm] ");
EnterScreen();
lcd_goto_L2();
math = ADRESH;
math += ADRESL;
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
char done = 0;
while(done == 0){
switch(input_sw){
case 1:
lcd_goto_L1();
break;
case 3:
MyVal++;
EnterScreen();
ShowDigits(MyVal);
break;
case 4:
MyVal--;
EnterScreen();
ShowDigits(MyVal);
break;
default:
break;
DelayS(1);
return MyVal;
mnuPOS = 0;
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
userMenu(0);
userMenu(1);
userMenu(2);
userMenu(3);
//Waits for user to press ENTER to show home screen
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
_INTI02_OSC_1H
_WDT_OFF_2H
-MCLRE_ON_3H
_LVP_OFF_4L
_PWRT_ON_2L
void main(void)
while(1){
home_screen();
lcd_clear(); // Using the new menu you can erase or
lcd_data(cm + '0');
lcd_goto_L2();
lcd_puts("[cm] "); //comment this out if you want
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #93 |
Right Click on this link and press "save as" or "save target as" or "save link as": http://atomsofttech.info/code/help01.avi
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 17th September 2009 at 03:04 PM. | |
| | #94 |
Wow Proteus is so NEAT!....hehe is that shareware LOL i doubt it ................Id like to get that software package...............( I will "search" for it hehehe-cough cough RapidShare cough )That clip is so cool....
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. | |
| | #95 |
uhmm i tried the code you posted...it shows the user menu stuff.... height, range, surface area..........and then: Measured 00 [cm] the values are not changing
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. Last edited by fantabulous68; 17th September 2009 at 04:31 PM. | |
| | #96 |
Well the integration works now...I repositioned some stuff. i moved the code in bold black to the bold red section without using a break.... the user interface works and after that the sensor works continuously if i use a break then the sensor captures a single digit and the lcd displays just 1 digit not continuous values... but i need continuous readings and i ALSO need to get to home screen if the user presses the home button....what should i do to get that??? Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
n=n*10.0;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
do {
DelayUs(996);
} while(--cnt);
#endif
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
DelayMs(100);
PORTB = 0x00;
/*Clear the LCD*/
j = -1;
lcd_data(s[j]);
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
lcd_cmd(0x02);
void init(void)
PORTA = 0;
RABPU = 0;
/* Init ADC */
ANSELH=0x00;
MyMinVal = 0;
MyMaxVal = 99;
TRISB=0x00;
TRISC=0xFC;
char done;
char temp;
done = 0;
while(!done){
temp = 1;
done = 0xff;
if(!HOME_SW){
temp = 2;
done = 0xff;
if(!INCREASE_SW){
temp = 3;
done = 0xff;
if(!DECREASE_SW){
temp = 4;
done = 0xff;
}//end of while
return temp;
lcd_clear();
lcd_goto_L1();
switch(pos){
case 0:
break;
case 1:
break;
case 2:
break; //
case 3:
while(1){
lcd_data(cm + '0');
// lcd_goto_L2();
lcd_puts(" [cm] "); //comment this out if you want
/* lcd_clear();
lcd_goto_L2();
lcd_data(cm + '0');
lcd_puts(" [cm] ");
//break; //*/
lcd_goto_L2();
// New Menu System
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
lcd_clear();
lcd_goto_L1();
lcd_puts(" [cm] ");
EnterScreen();
lcd_goto_L2();
math = ADRESH;
math += ADRESL;
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
char done = 0;
while(done == 0){
switch(input_sw){
case 1:
lcd_goto_L1();
break;
case 3:
MyVal++;
EnterScreen();
ShowDigits(MyVal);
break;
case 4:
MyVal--;
EnterScreen();
ShowDigits(MyVal);
break;
default:
break;
DelayS(1);
return MyVal;
mnuPOS = 0;
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
userMenu(0);
userMenu(1);
userMenu(2);
userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
_INTI02_OSC_1H
_WDT_OFF_2H
-MCLRE_ON_3H
_LVP_OFF_4L
_PWRT_ON_2L
void main(void)
while(1){
home_screen();
/*// wait for 2 seconds, uses TMR1 free running at 1Mhz
// lcd_clear(); // Using the new menu you can erase or
// lcd_data(cm10 + '0');
// lcd_data(cm + '0');
// lcd_goto_L2();
// lcd_puts("[cm] "); //comment this out if you want
************************************************** ******** By the way if i replace my Code: lcd_clear(); // Using the new menu you can erase or
lcd_data(cm + '0');
// lcd_goto_L2();
lcd_puts(" [cm] "); //comment this out if you want[/COLOR][/B]
/* lcd_clear();
lcd_goto_L2();
lcd_data(cm + '0');
lcd_puts(" [cm] ");
//break; //*/ it gives continuous readings in with the repositioning of other code but... it displays: Measured (and this is dark...visible) 35cm (extremely light in colour can hardly see it)
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. Last edited by fantabulous68; 17th September 2009 at 09:14 PM. | |
| | #97 |
You mean the Measured text is visible and the other 35cm is barely visible? Post the full code your using at the moment. Also check your PM in about 5 minutes
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 18th September 2009 at 12:52 AM. | |
| | #98 |
Yeah thats what i mean. This is the code im using.... Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
n=n*10.0;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
do {
DelayUs(996);
} while(--cnt);
#endif
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
DelayMs(100);
PORTB = 0x00;
/*Clear the LCD*/
j = -1;
lcd_data(s[j]);
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
lcd_cmd(0x02);
void init(void)
PORTA = 0;
RABPU = 0;
/* Init ADC */
ANSELH=0x00;
MyMinVal = 0;
MyMaxVal = 99;
TRISB=0x00;
TRISC=0xFC;
char done;
char temp;
done = 0;
while(!done){
temp = 1;
done = 0xff;
if(!HOME_SW){
temp = 2;
done = 0xff;
if(!INCREASE_SW){
temp = 3;
done = 0xff;
if(!DECREASE_SW){
temp = 4;
done = 0xff;
}//end of while
return temp;
lcd_clear();
lcd_goto_L1();
switch(pos){
case 0:
break;
case 1:
break;
case 2:
break; //
case 3:
while(1){
lcd_data(cm + '0');
// lcd_goto_L2();
/* lcd_clear();
lcd_goto_L2();
lcd_data(cm + '0');
lcd_puts(" [cm] ");
//break; //*/
lcd_goto_L2();
// New Menu System
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
lcd_clear();
lcd_goto_L1();
lcd_puts(" [cm] ");
EnterScreen();
lcd_goto_L2();
math = ADRESH;
math += ADRESL;
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
char done = 0;
while(done == 0){
switch(input_sw){
case 1:
lcd_goto_L1();
break;
case 3:
MyVal++;
EnterScreen();
ShowDigits(MyVal);
break;
case 4:
MyVal--;
EnterScreen();
ShowDigits(MyVal);
break;
default:
break;
DelayS(1);
return MyVal;
mnuPOS = 0;
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
userMenu(0);
userMenu(1);
userMenu(2);
userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
_INTI02_OSC_1H
_WDT_OFF_2H
-MCLRE_ON_3H
_LVP_OFF_4L
_PWRT_ON_2L
void main(void)
while(1){
home_screen();
// lcd_goto_L2();
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. Last edited by fantabulous68; 18th September 2009 at 01:57 PM. | |
| | #99 |
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
char WaitForInput(char expire); //Edited this with new expire input
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
n=n*10.0;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
do {
DelayUs(996);
} while(--cnt);
#endif
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
DelayMs(100);
PORTB = 0x00;
/*Clear the LCD*/
j = -1;
lcd_data(s[j]);
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
lcd_cmd(0x02);
void init(void)
PORTA = 0;
RABPU = 0;
/* Init ADC */
ANSELH=0x00;
MyMinVal = 0;
MyMaxVal = 99;
TRISB=0x00;
TRISC=0xFC;
// EDITED this a bit. now if expire input is set it will leave loop with a 0
//instead of rechecking this will be useful for display your measured data and
//waiting for user to exit.
char WaitForInput(char expire){
char done;
char temp;
done = 0;
temp = 0;
while(!done){
while(ENTERSETTINGS_SW);
temp = 1;
done = 0xff;
if(!HOME_SW){
while(HOME_SW);
temp = 2;
done = 0xff;
if(!INCREASE_SW){
while(INCREASE_SW);
temp = 3;
done = 0xff;
if(!DECREASE_SW){
while(DECREASE_SW);
temp = 4;
done = 0xff;
if(expire == 1) break;
}//end of while
return temp;
lcd_clear();
lcd_goto_L1();
switch(pos){
case 0:
break;
case 1:
break;
case 2:
break; //
case 3:
lcd_puts(" MEASURED ");
while(WaitForInput(1) != 1){ //Wait for user to press enter to leave loop
lcd_goto_L2(); //Only change line 2
lcd_data(cm + '0');
break;
while(WaitForInput(1) == 1);
lcd_goto_L2();
// New Menu System
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
lcd_clear();
lcd_goto_L1();
lcd_puts(" [cm] ");
EnterScreen();
lcd_goto_L2();
math = ADRESH;
math += ADRESL;
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
char done = 0;
while(done == 0){
input_sw = WaitForInput(0);
switch(input_sw){
case 1:
lcd_goto_L1();
lcd_puts(" OK "); //home screen message (line 1)
break;
case 3:
MyVal++;
EnterScreen();
ShowDigits(MyVal);
break;
case 4:
MyVal--;
EnterScreen();
ShowDigits(MyVal);
break;
default:
break;
DelayMs(250);
DelayMs(250);
return MyVal;
mnuPOS = 0;
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
userMenu(0);
userMenu(1);
userMenu(2);
userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
_INTI02_OSC_1H
_WDT_OFF_2H
-MCLRE_ON_3H
_LVP_OFF_4L
_PWRT_ON_2L
void main(void)
while(1){
home_screen();
// lcd_goto_L2();
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 18th September 2009 at 02:42 PM. | |
| | #100 |
Its displaying the distances BUT its changing extremely slowly(b4 it was fast) AND the home button doesnt go to the home screen ************************************************** ************* Actually while taking readings.....the measuring can be EXITED to the HOME screen when i press ENTER/SETTINGS not the HOME button.... so it is EXITING just not with the right button
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. Last edited by fantabulous68; 18th September 2009 at 03:09 PM. | |
| | #101 |
Try this as your usermenu stuff. The slow speed might be because of that 2 second delay you have in the menu using timer1: Code: void userMenu(char pos){
lcd_clear();
lcd_goto_L1();
switch(pos){
case 0:
break;
case 1:
break;
case 2:
break; //
case 3:
while(WaitForInput(1) != 2){ //Wait for user to press enter to leave loop
lcd_data(cm + '0');
lcd_goto_L1();
lcd_puts(" OK ");
lcd_goto_L2();
lcd_puts(" ");
break;
lcd_goto_L2();
EDIT: If you can read this try the code again. I edited it/
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 18th September 2009 at 03:11 PM. | |
| | #102 |
Ok ok i forgot a few things. try this full code: Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
n=n*10.0;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
do {
DelayUs(996);
} while(--cnt);
#endif
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
DelayMs(100);
PORTB = 0x00;
/*Clear the LCD*/
j = -1;
lcd_data(s[j]);
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
lcd_cmd(0x02);
void init(void)
PORTA = 0;
RABPU = 0;
/* Init ADC */
ANSELH=0x00;
MyMinVal = 0;
MyMaxVal = 99;
TRISB=0x00;
TRISC=0xFC;
//EDITED this a bit. now if expire input is set it will leave loop with a 0
char done;
char temp;
done = 0;
temp = 0;
while(!done){
temp = 1;
done = 0xff;
if(!HOME_SW){
while(HOME_SW);
temp = 2;
done = 0xff;
if(!INCREASE_SW){
while(INCREASE_SW);
temp = 3;
done = 0xff;
if(!DECREASE_SW){
while(DECREASE_SW);
temp = 4;
done = 0xff;
}//end of while
return temp;
lcd_clear();
lcd_goto_L1();
switch(pos){
case 0:
break;
case 1:
break;
case 2:
break; //
case 3:
lcd_data(cm + '0');
lcd_goto_L1();
lcd_puts(" OK ");
lcd_goto_L2();
lcd_puts(" ");
break;
lcd_goto_L2();
// New Menu System
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
lcd_clear();
lcd_goto_L1();
lcd_puts(" [cm] ");
EnterScreen();
lcd_goto_L2();
unsigned int mathKeep; // used for voltage calculations backup
math = ADRESH;
math += ADRESL;
//Create a copy of math for more use
mathKeep = math;
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
math = mathKeep; //Now our original data is back and can be used.
char done = 0;
while(done == 0){
switch(input_sw){
case 1:
lcd_goto_L1();
break;
case 3:
MyVal++;
EnterScreen();
ShowDigits(MyVal);
break;
case 4:
MyVal--;
EnterScreen();
ShowDigits(MyVal);
break;
default:
break;
DelayMs(250);
DelayMs(250);
return MyVal;
mnuPOS = 0;
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
userMenu(0);
userMenu(1);
userMenu(2);
userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
_INTI02_OSC_1H
_WDT_OFF_2H
-MCLRE_ON_3H
_LVP_OFF_4L
_PWRT_ON_2L
void main(void)
while(1){
home_screen();
// lcd_goto_L2();
| | #103 |
This code checks 4 times a second Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
n=n*10.0;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
do {
DelayUs(996);
} while(--cnt);
#endif
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
DelayMs(100);
PORTB = 0x00;
/*Clear the LCD*/
j = -1;
lcd_data(s[j]);
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
lcd_cmd(0x02);
void init(void)
PORTA = 0;
RABPU = 0;
/* Init ADC */
ANSELH=0x00;
MyMinVal = 0;
MyMaxVal = 99;
TRISB=0x00;
TRISC=0xFC;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
temp = 1;
done = 0xff;
if(!HOME_SW){
while(HOME_SW);
temp = 2;
done = 0xff;
if(!INCREASE_SW){
while(INCREASE_SW);
temp = 3;
done = 0xff;
if(!DECREASE_SW){
while(DECREASE_SW);
temp = 4;
done = 0xff;
}//end of while
return temp;
lcd_clear();
lcd_goto_L1();
switch(pos){
case 0:
break;
case 1:
break;
case 2:
break; //
case 3:
if(bres >= 250000) // if reached 2 seconds!
bres -= 250000; // subtract 2 seconds, keep error
lcd_data(cm + '0');
lcd_goto_L1();
lcd_puts(" Loading Home ");
lcd_goto_L2();
lcd_puts(" ");
DelayS(1);
break;
lcd_goto_L2();
// New Menu System
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
lcd_clear();
lcd_goto_L1();
lcd_puts(" [cm] ");
EnterScreen();
lcd_goto_L2();
math = ADRESH;
math += ADRESL;
mathKeep = math;
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
char done = 0;
while(done == 0){
switch(input_sw){
case 1:
lcd_goto_L1();
break;
case 3:
MyVal++;
EnterScreen();
ShowDigits(MyVal);
break;
case 4:
MyVal--;
EnterScreen();
ShowDigits(MyVal);
break;
default:
break;
DelayMs(250);
DelayMs(250);
return MyVal;
mnuPOS = 0;
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
userMenu(0);
userMenu(1);
userMenu(2);
userMenu(3);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
_INTI02_OSC_1H
_WDT_OFF_2H
-MCLRE_ON_3H
_LVP_OFF_4L
_PWRT_ON_2L
void main(void)
while(1){
home_screen();
// lcd_goto_L2();
| | #104 |
lol OK Super Cool That fixes the get to home screen problem hehehe but it comes with a price.....the sensors reading slow.....
__________________ Learn without thinking begets ignorance. Think without learning is dangerous. Last edited by fantabulous68; 18th September 2009 at 03:21 PM. | |
| | #105 |
Loading Home ![]() It got a bit faster.....R u changing the oscillator frequency???
| display, lcd, pushbutton, reading |
| Substituting a 16x2 LCD display for 16x1 LCD display? | Dawny | Electronic Projects Design/Ideas/Reviews | 19 | 11th October 2008 09:58 AM |
| Pushbutton Slow & Repeating Pulse | btanner | Electronic Projects Design/Ideas/Reviews | 1 | 22nd January 2008 06:18 PM |
| Is this display burned out? (Sony MD LCD Display) | Amphr_Moth | General Electronics Chat | 4 | 28th October 2007 07:47 PM |
| how to display '-' & '+' range number on LCD? | meera83 | Micro Controllers | 8 | 5th July 2007 09:56 AM |
| lcd display with hd44780 display driver | ANUPAMA | Micro Controllers | 2 | 7th April 2004 02:58 PM |
