Old 14th September 2009, 09:05 PM   #76
what do you want it to do? It works fine for me. when i press up or down it says
[cm]
01
AtomSoft is online now
Old 14th September 2009, 09:16 PM   #77
Here you go complete:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>	//
void userMenu(char pos); //
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(void);
unsigned char user_input(void);
void home_screen(void);
void EnterHeight(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void main(void);
void calc_distance(void);
#define LCD_RS RC0		//LCD RS pin
#define LCD_EN RC1		//LCD EN pin
#define LCD_STROBE()	LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10;		//
unsigned char cm;		//
unsigned int math;		// used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
char temp[8];
//[/b]
unsigned char height=50;
unsigned char range;
unsigned char area;
unsigned char SensorPos=10;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
unsigned char ;
#define HOME_SW RC2				//HOME switch
#define INCREASE_SW RC3			//INCREASE switch
#define DECREASE_SW RC4			//DECREASE switch
#define ENTERSETTINGS_SW RA4	//ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
      scale=floor(0.5+scale/10.0);
      d=(unsigned char) (n/scale);
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
      n=n*10.0;
      d=(unsigned char) n;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if	XTAL_FREQ <= 2MHZ
	do {
		DelayUs(996);
	} while(--cnt);
#endif
#if    XTAL_FREQ > 2MHZ
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
void DelayS(unsigned char cnt)
	for (j=0; j<(cnt*10); j++)
		DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
	DelayMs(2); //wait for LCD to be ready shorter delay
	LCD_RS = 0;	 //write instruction
	PORTB = (c & 0xF0); //load upper nibble on LCD data lines
	LCD_STROBE(); //send instruction to LCD
	PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
	PORTB = 0x00;
	LCD_RS = 1; //write data
    PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
	PORTB &= 0x00; //load upper nibble on LCD data lines
	PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
	lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
	j = -1;
	while(s[++j]!=('\0')) // send characters until null character reached
		lcd_data(s[j]);
/*go to beginning of line 1*/
	lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
	lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
	lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	DelayMs(20); //wait for LCD startup
	lcd_cmd(0x02);
	lcd_cmd(0x28);	// 4-bit mode
	lcd_cmd(0x08);	// display off
	lcd_cmd(0x01);	// clear display
	lcd_cmd(0x0C);	// disp. on, cursor off, cursor blink off
	lcd_cmd(0x06);	// entry mode
	lcd_cmd(0x80);  // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
	MyVal = 0; //initializn these variables here
	MyMinVal = 0;
	MyMaxVal = 99;
    OSCCON|=0x60; //set fosc to 4Mhz
	TRISB=0x00;
	TRISC=0xFC;
    TRISA = 0b10010010; 	// RA7 high imp, RA3 is serial out, RA4 button input
	ANSEL=0x02;            //set RA1 as analog input for GP2 sensor
	ANSELH=0x00;
	lcd_init(); //call LCD initialisation
char WaitForInput(void){
char done;
char temp;
done = 0;
while(!done){
    if(!ENTERSETTINGS_SW){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    DelayMs(150);    //debounce
    return temp;
void userMenu(char pos){
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			lcd_puts("    HEIGHT    ");
			break;
		case 1:
			lcd_puts("    RANGE     ");
			break;
		case 2:
			lcd_puts(" SURFACE AREA ");
			break;
	lcd_goto_L2();
	lcd_puts("Press Up/Down"); //home screen message (line 2)
// New Menu System
void EnterHeight(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" ENTER HEIGHT ");
	lcd_goto_L2();
void EnterScreen(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
void ShowDigits(unsigned char val){
    MyValLCD[0] = val /10;    //returns the quotient (if temp = 35 the result is 3)
    MyValLCD[1] = val % 10; 	//Returns remainder   (if temp = 35 the result is 5)
	MyValLCD[0] += 0x30;	//to ASCII
	MyValLCD[1] += 0x30;	//to ASCII
	EnterScreen();
	lcd_goto_L2();
	lcd_data(MyValLCD[0]);	//to LCD
	lcd_data(MyValLCD[1]);  //to LCD
	// from the transeiver datasheet the analog voltage is
	// the inverse of distance, so distance can be calculated
	// d = (1 / volts) then just scaled to suit the transeiver
	// load ADC value in 16bit math var
	math = ADRESH;
	math = (math * 256);
	math += ADRESL;
	// now invert it; (1 / volts) use (6050 / volts) for scaling
	math = (6050 / math);
	if(math >= 2) math -=2;		// fix linear error (-2)
	if(math > 99) math = 99;	// max limit at 99cm
	// convert from 0-99 to 2 decimal digits, 0-99cm
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
unsigned char user_input(void)		//This will return what we want
	char done = 0;
	MyVal = 0;			//Start on 0
	while(done == 0){
   	  input_sw = WaitForInput();
      switch(input_sw){
		case 1:
			done = 0xff; 			//This tells us the user finished entering
			lcd_goto_L1();
			lcd_puts("     Done!      "); //home screen message (line 1)
			break;
      	case 3:
			if(MyVal < MyMaxVal)
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
			if(MyVal > MyMinVal)
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	return MyVal;
void home_screen(void){
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
	input_sw = 0;			//Reset the value
	while(input_sw != 1)  	//Wait until enter is pressed
	//EnterScreen();
	//EnterHeight();
	userMenu(0);
	DelayMs(2);				//shorter delay
    height = user_input();	//The HEIGHT var will have the myVal
	userMenu(1);
    range = user_input();	//The HEIGHT var will have the myVal
	userMenu(2);
    area = user_input();	//The HEIGHT var will have the myVal
"enter height"
call enter/settings (which is now user input function in new code)
height=MyVal
"enter range"
call user_input
range=MyVal
"enter surface area"
call user_input
area=MyVal
void main(void)
 init();	// initialise I/O ports, LCD
 while(1){
 	home_screen();
Old 14th September 2009, 09:17 PM   #78
well its doing the above stuff without me pressing any buttons....
o gosh i just looked at mplab config bits again.....i had saved this in a new file and it reset the config bits to default.....
im sure it will work after i set the bits correctly again.....thanx AtomSoft.....
Learn without thinking begets ignorance. Think without learning is dangerous.
fantabulous68 is offline
Old 14th September 2009, 09:18 PM   #79
heh no problem. I made the whole menu in the new code posted. I add the range and area stuff
Old 14th September 2009, 09:20 PM   #80
lol complete thanx ....
Yeah it sure is working smoothly...tried it out now....
i have to start paying forward my bank balance (im not working yet lol)...if i dont start paying back in kind hehe....
Old 14th September 2009, 09:29 PM   #81
heh paying foward heh If you need any more help be sure to simply ask
Old 16th September 2009, 01:58 PM   #82
Uhmmmm Hello AtomSoft...could you tell me why you suggest i use int instead of unsigned int....??? the distances are all going to be positive...
This is from the original code:
heh just dont forget in that junebug page read the comments well...
so..
int math
Old 16th September 2009, 02:01 PM   #83
I never checked original code. Also i never said dont use unsigned int as long as its a int
Unsigned int is best in this case
Old 16th September 2009, 02:08 PM   #84
O Ok...Cool. Hello AtomSoft...I wrote a test today & came home early...hehe I am attempting ADC 1st time today lol....well it looks easy to set up and stuff...hopefully it will work when i put it in the circuit (o else lol someone will be getting bothered )
Old 16th September 2009, 02:55 PM   #85
This compiled successfully but im not sure if im doing the part highlighted in red correctly.....I want to display the unsigned int value stored in cm to the LCD. cm=math from the calc_distance function. i commented home_screen for now. Want to get cm value displaying and will integrate it later.
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
void init(void);
void main(void);
unsigned int temp;
unsigned char cm2LCD;
//char temp[8];
//[/b]
unsigned char area;
//[/b] New Vars
char input_sw;
char mnuPOS;
unsigned long bres;		// for bresenham 2-second timer system
unsigned char ;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	// setup the PIC 16f690
	OSCCON = 0x72;      	// internal osc, 8MHz
	PORTA = 0;
 	PORTB = 0;          	// PORTB not used
    WPUB = 1;				// PORTB pullups ON
    RABPU = 0;
    /* Init ADC */
    ADCON0 = 0b10000101;	// bit 7 right justify,analogue channel select bits bits5-2  0001=AN1,ADC ON, RA1 is ADC input
	ADCON1 = 0b00100000;	//bits6-4  fosc/32
    ADON=1;	                // turn on the A2D conversion module
	ANSELH=0x00;
    T1CON = 0b00010001;     // TMR1 is ON, 1:2 prescale, =1MHz
	T2CON = 0b00000101;     // TMR2 is ON, 1:4 prescale, =1MHz
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	switch(pos){
		case 0:
			break;
		case 1:
			break;
		case 2:
			break;
	lcd_goto_L2();
// New Menu System
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			EnterScreen();
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			EnterScreen();
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	userMenu(0);
	userMenu(1);
	userMenu(2);
"enter height"
height=MyVal
"enter range"
call user_input
range=MyVal
call user_input
area=MyVal
/*  Junebug_Serial4.c    RomanBlack.com 19th July 2009.
    uses "zero error 1 second timer"
	system to generate a 2 second interval, then every
	2 seconds it reads an analog voltage from a
	Sharp GP2 distance sensor and converts it to decimal
	distance, then sends that data to a LCD
	Code for MikroC, config handled by MikroC compiler;
	_INTI02_OSC_1H
	_WDT_OFF_2H
	-MCLRE_ON_3H
	_LVP_OFF_4L
	_PWRT_ON_2L
void main(void)
    while(1){
 	//	home_screen();
 	// wait for 2 seconds, uses TMR1 free running at 1Mhz
   	while(!TMR1IF)  // wait for TMR1 overflow
	TMR1IF = 0; 	// clear overflow flag
	bres += 65536;			// add 65536uS to bres value
	if(bres >= 2000000)		// if reached 2 seconds!
    	bres -= 2000000;	// subtract 2 seconds, keep error
		// read the ADC voltage RA1 (Sharp GP2 sensor)
		GODONE=1;	// initiate conversion on the channel 0
		while(GODONE) continue;  // Wait convertion done
		calc_distance();		// convert ADC value to distance
		cm2LCD=cm+0x30;    //converting cm(from calc_distance procedure) to ascii
		lcd_data(cm2LCD);
Old 16th September 2009, 03:00 PM   #86
actually i tried something like this 1st:
tempvar=calc_distance();   // tempvar assigned cm value from calc_distance procedure
cm2LCD=tempvar+0x30;
 lcd_data(cm2LCD);
but i was messing up the var types
Old 16th September 2009, 03:25 PM   #87
You have to remember this. Can CM be higher than 09 ? if so then you should spilt the variable CM into 2 like
cmHigh = ( ( cm >> 4 ) & 0x0F ) + 0x30;
cmLow = ( cm & 0x0F ) + 0x30;
lcd_data(cmHigh);
lcd_data(cmLow);
This will give you 2 seperate ASCII values for the LCD.
Old 16th September 2009, 05:32 PM   #88
the sensor has a range from 10cm to 80 cm So yes CM can be higher than 09.
I ran my code that i posted and the LCD displays random numbers when i power up.
EG. 12768126498124987491874
12094809128409283498239
But when i put a page in front the sensor and i hold it steadily then the sensor displays
EG. 888888888888888888888888
and if i move it away and hold it steady it displays
4444444444444444444444444444
if its not steady then the numbers are just random......im guessing im not formatting it correctly or something......
im going to try what you suggested now..........
its improving.................
when i power up its random numbers
now when i put a page & hold it steady....
EG.
010101010101010
010101010101010
i keep moving it away and...
020202020202020
020202020202020
030303030303030
030303030303030
till.....
090909090909090
090909090909090
THEN
000000000000000
000000000000000
and it repeats the sequence
010101010101010
010101010101010...............
and so on......
BTW
(it does not go to 111111111111111
111111111111111)
and 1212121212121212
1212121212121212 .....etc)
i just measured manually with a ruler to verify the values....its accurate
meaning....
the sensor has a min range of 10 cm......
so when the page is 10cm away it displays....
000000000000000
000000000000000
and if it 5cm away from the min range(ie. 15cm)
then it display:
050505050505050
050505050505050
and i measured this with a ruler and it gives 15cm
Old 16th September 2009, 10:33 PM   #89
ook just so i dont screw up the code.. can you post entire project again. So i can have a clear look.
Old 16th September 2009, 10:34 PM   #90
to me it sounds like its just looping with no stop heh which is a simple fix when i see the code.
display, lcd, pushbutton, reading
Substituting a 16x2 LCD display for 16x1 LCD display? Dawny Electronic Projects Design/Ideas/Reviews 19 11th October 2008 09:58 AM
Pushbutton Slow & Repeating Pulse btanner Electronic Projects Design/Ideas/Reviews 1 22nd January 2008 06:18 PM
Is this display burned out? (Sony MD LCD Display) Amphr_Moth General Electronics Chat 4 28th October 2007 07:47 PM
how to display '-' & '+' range number on LCD? meera83 Micro Controllers 8 5th July 2007 09:56 AM
lcd display with hd44780 display driver ANUPAMA Micro Controllers 2 7th April 2004 02:58 PM
