Old 11th September 2009, 02:25 AM   #61
Thanks, appreciate it...
Originally Posted by AtomSoft View Post
heh sure thing. I had to zip it because forum doesnt allow the file type.
bryan is online now
Old 11th September 2009, 12:54 PM   #62
Was thinking of the same, are you planning on using the application for a aquarium sump. If it works on water I wanted to try the same and use it to control the top off water for the sump.
Well i tested the sensor on some liquids(water, milk, oil and coke) last night and its analog output voltage is similar to that of the datasheet...so it does work on liquids...il post the graphs when i get home...its on my desk top and im in uni at the moment....
fantabulous68 is offline
Old 11th September 2009, 01:18 PM   #63
Very nice. I love experimentation. Did you vary the depth of the liquid or just the distance from the liquid's surface? The experiment I would sugest is water in a deep bowl. Add about 3 to 4 cm of water and measure at 10 and 20 cm from the surface. Then increase depth of water 10 cm and repeat.
John
Edit: On reconsideration, make the initial water depth only 2 to 3 cm. Keep the rest the same.
jpanhalt is offline
Old 11th September 2009, 01:53 PM   #64
I varied the distance, i will be back later-i will try out what you said when i get home jpanhalt, my lift club is leaving soon....got to go now
Old 11th September 2009, 02:33 PM   #65
heh just dont forget in that junebug page read the comments well...
// load ADC value in 16bit math var
so..
int math
AtomSoft is offline
Old 11th September 2009, 09:41 PM   #66
This was just a rough test i did with the GP2 and various liquids....
tomorrow i plan to do a more accurate test so each liquid will have the same type of container
Old 11th September 2009, 09:43 PM   #67
Yeah Atomsoft hehe im gonna try to. Nyty nyt, its 23:04 here......take care
Old 12th September 2009, 12:21 PM   #68
jpanhalt...i posted the new measurements on my GP2 sensor thread...if you want to take a look.......
Old 13th September 2009, 10:17 PM   #69
Hello AtomSoft....this is the original code...i want to modify it slightly so that i can allow the user to ENTER 3 values(which i can use)....so my plan is to make a function out of the code i highlighted in red below....(that is the the part when the user presses enter)
i want to call that 3 different times so it does something like:
"enter height"
call enter/settings (which is now user input function in new code)
height=MyVal
"enter range"
call user_input
range=MyVal
"enter surface area"
call user_input
area=MyVal
well i just want to know if the way im assigning height=MyVal is correct in the new code below..............My val is determined in the user input stage...My Val is the number i need to manipulate...so am i assigning it correctly? or do i need to use a return MyVal then height=user_input() ???
old code:
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(void);
void home_screen(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void main(void);
void calc_distance(void);
#define LCD_RS RC0		//LCD RS pin
#define LCD_EN RC1		//LCD EN pin
#define LCD_STROBE()	LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10;		//
unsigned char cm;		//
unsigned int math;		// used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
char temp[8];
int height=50, SensorPos=10;
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
#define HOME_SW RC2				//HOME switch
#define INCREASE_SW RC3			//INCREASE switch
#define DECREASE_SW RC4			//DECREASE switch
#define ENTERSETTINGS_SW RA4	//ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
      scale=floor(0.5+scale/10.0);
      d=(unsigned char) (n/scale);
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
      n=n*10.0;
      d=(unsigned char) n;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if	XTAL_FREQ <= 2MHZ
	do {
		DelayUs(996);
	} while(--cnt);
#endif
#if    XTAL_FREQ > 2MHZ
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
void DelayS(unsigned char cnt)
	for (j=0; j<(cnt*10); j++)
		DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
	DelayMs(2); //wait for LCD to be ready shorter delay
	LCD_RS = 0;	 //write instruction
	PORTB = (c & 0xF0); //load upper nibble on LCD data lines
	LCD_STROBE(); //send instruction to LCD
	PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
	PORTB = 0x00;
	LCD_RS = 1; //write data
    PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
	PORTB &= 0x00; //load upper nibble on LCD data lines
	PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
	lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
	j = -1;
	while(s[++j]!=('\0')) // send characters until null character reached
		lcd_data(s[j]);
/*go to beginning of line 1*/
	lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
	lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
	lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	DelayMs(20); //wait for LCD startup
	lcd_cmd(0x28);	// 4-bit mode
	lcd_cmd(0x08);	// display off
	lcd_cmd(0x01);	// clear display
	lcd_cmd(0x0C);	// disp. on, cursor off, cursor blink off
	lcd_cmd(0x06);	// entry mode
	lcd_cmd(0x80);  // initialise DDRAM address to zero
// These are my inits. Comment them out and use the above for you
	lcd_cmd(0x02);
	lcd_cmd(0x08);
	lcd_cmd(0x02);
	lcd_cmd(0x08);
	lcd_cmd(0x00);
	lcd_cmd(0x06);
	lcd_cmd(0x00);
	lcd_cmd(0x0E);
	lcd_cmd(0x00);
	lcd_cmd(0x01);
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
	MyVal = 0; //initializn these variables here
	MyMinVal = 0;
	MyMaxVal = 99;
    OSCCON|=0x60; //set fosc to 4Mhz
	TRISB=0x00;
	TRISC=0xFC;
    TRISA = 0b10010010; 	// RA7 high imp, RA3 is serial out, RA4 button input
	ANSEL=0x02;            //set RA1 as analog input for GP2 sensor
	ANSELH=0x00;
	lcd_init(); //call LCD initialisation
char WaitForInput(void){
char done;
char temp;
done = 0;
while(!done){
    if(!ENTERSETTINGS_SW){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    DelayMs(150);    //debounce
    return temp;
void EnterScreen(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" ENTER/SETTINGS ");
void ShowDigits(unsigned char val){
    MyValLCD[0] = val /10;    //returns the quotient (if temp = 35 the result is 3)
    MyValLCD[1] = val % 10; 	//Returns remainder   (if temp = 35 the result is 5)
	MyValLCD[0] += 0x30;	//to ASCII
	MyValLCD[1] += 0x30;	//to ASCII
	EnterScreen();
	lcd_goto_L2();
	lcd_data(MyValLCD[0]);	//to LCD
	lcd_data(MyValLCD[1]);  //to LCD
	// from the transeiver datasheet the analog voltage is
	// the inverse of distance, so distance can be calculated
	// d = (1 / volts) then just scaled to suit the transeiver
	math = ADRESH;
	math = (math * 256);
	math += ADRESL;
	// now invert it; (1 / volts) use (6050 / volts) for scaling
	math = (6050 / math);
	if(math >= 2) math -=2;		// fix linear error (-2)
	if(math > 99) math = 99;	// max limit at 99cm
	// convert from 0-99 to 2 decimal digits, 0-99cm
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
void home_screen(void){
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
	lcd_goto_L2();
	lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
  // i dont have a while(1) here any more
//Im calling the wait for input function here
input_sw = WaitForInput();
	while(input_sw != 1);  // wait until enter is pressed
	EnterScreen();
	mnuPOS = 1;
	DelayMs(2);				//shorter delay
	while(mnuPOS == 1){
      switch(input_sw){
		case 1:
			mnuPOS = 2; //This tells us the user finished entering
			lcd_goto_L1();
			lcd_puts("     Done!      "); //home screen message (line 1)
			break;
      	case 3:
			if(MyVal < MyMaxVal)
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
			if(MyVal > MyMinVal)
      			MyVal--;
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	//Do something here with the new Value which is a decimal in
	//MyVal. The user is here because all data is entered
	//i added a return here
    //return;
	//im not 100% sure but since its a void i think a return isnt needed
void main(void)
 init();	// initialise I/O ports, LCD
 while(1){
 	home_screen();
here is the new code.....................
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void);
void user_input(void);
void EnterHeight(void);
void main(void);
void init(void)
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
void EnterHeight(void){
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" ENTER HEIGHT ");
	lcd_goto_L2();
	lcd_puts("Press UP/Down"); //home screen message (line 2)
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	while(mnuPOS == 1){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	EnterScreen();
	EnterHeight();
	mnuPOS = 1;
    user_input();
	height=MyVal;
void main(void)
 while(1){
 	home_screen();
Learn without thinking begets ignorance. Think without learning is dangerous.
Old 14th September 2009, 12:20 AM   #70
from what i see it would be ok if you declare the MyVal as a global.
AtomSoft is offline
Old 14th September 2009, 12:23 AM   #71
wait no. It will get stuck in while() loop brb gonna edit quick
AtomSoft is offline
Old 14th September 2009, 12:30 AM   #72
Try this :
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void);
unsigned char user_input(void);
void main(void);
void init(void)
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_puts("Press Up/Down"); //home screen message (line 2)
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
unsigned char user_input(void)		//This will return what we want
	char done = 0;
	MyVal = 0;			//Start on 0
	while(done == 0){
      switch(input_sw){
		case 1:
			done = 0xff; 			//This tells us the user finished entering
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	input_sw = 0;			//Reset the value
	while(input_sw != 1)  	//Wait until enter is pressed
	EnterScreen();
	EnterHeight();
    height = user_input();	//The HEIGHT var will have the myVal
void main(void)
 while(1){
 	home_screen();
EDIT: What happened to all the variable declarations?
AtomSoft is offline
Old 14th September 2009, 09:41 AM   #73
b4 when i was playing around & trying my own tricks...it did get stuck in the while loop
Hey...i am at uni.....when i get home...i will test it out n let you know what happens.........................
OOOpZ......Cut n paste
Old 14th September 2009, 09:03 PM   #74
Hello AtomSoft.....i tried the code and.....as soon as i power up it displays....
"IR LLD"
enter height
press up/down
done!
press up/down
" IR LLD"............and it loops the same sequence above....
#include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void);
void main(void);
char temp[8];
unsigned char height=50, SensorPos=10;
char input_sw;
char mnuPOS;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
      str[f]=d+'0';
      n=n-scale*d;
	  f++;
str[f]='.';
f++;
      n=n*10.0;
      str[f]=d+'0';
      n=n-d;
	  f++;
str[f]='\0';
	do {
		DelayUs(996);
	} while(--cnt);
#endif
	unsigned char	p;
	do {
		p = 4;
		do {
			DelayUs(250);
		} while(--p);
	} while(--cnt);
#endif
		DelayMs(100);
	PORTB = 0x00;
/*Clear the LCD*/
	j = -1;
		lcd_data(s[j]);
void lcd_init(void)
	LCD_RS = 0;
	LCD_EN = 0;
	lcd_cmd(0x02);
void init(void)
	MyMinVal = 0;
	MyMaxVal = 99;
	TRISB=0x00;
	TRISC=0xFC;
	ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
        temp = 1;
        done = 0xff;
    if(!HOME_SW){
        temp = 2;
        done = 0xff;
    if(!INCREASE_SW){
        temp = 3;
        done = 0xff;
    if(!DECREASE_SW){
        temp = 4;
        done = 0xff;
}//end of while
    return temp;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	lcd_clear();
	lcd_goto_L1();
	lcd_puts(" [cm] ");
	EnterScreen();
	lcd_goto_L2();
	math = ADRESH;
	math += ADRESL;
	cm10=0;
	while(math >= 10)
		cm10++;
		math -= 10;
	cm = math;
	char done = 0;
	while(done == 0){
      switch(input_sw){
		case 1:
			lcd_goto_L1();
			break;
      	case 3:
      			MyVal++;
			ShowDigits(MyVal);
			break;
      	case 4:
      			MyVal--;
			ShowDigits(MyVal);
        	break;
		default:
			break;
	DelayS(1);
	return MyVal;
	mnuPOS = 0;
	lcd_clear();
	lcd_goto_L1();
	lcd_goto_L2();
	EnterScreen();
	EnterHeight();
void main(void)
 while(1){
 	home_screen();
Old 14th September 2009, 09:05 PM   #75
ZzzzzzzzZZZZZzzzzzzzzzzzzzzzzzzzzz...im so tired, was doing my pre-prac for tomorrow...sorry for the late response...
display, lcd, pushbutton, reading
Substituting a 16x2 LCD display for 16x1 LCD display? Dawny Electronic Projects Design/Ideas/Reviews 19 11th October 2008 09:58 AM
Pushbutton Slow & Repeating Pulse btanner Electronic Projects Design/Ideas/Reviews 1 22nd January 2008 06:18 PM
Is this display burned out? (Sony MD LCD Display) Amphr_Moth General Electronics Chat 4 28th October 2007 07:47 PM
how to display '-' & '+' range number on LCD? meera83 Micro Controllers 8 5th July 2007 09:56 AM
lcd display with hd44780 display driver ANUPAMA Micro Controllers 2 7th April 2004 02:58 PM
