| | #46 |
#define LCD_RS RC0 //LCD RS pin #define LCD_EN RC1 //LCD EN pin Rb7 Rb6 Rb5 Rb4 are connected to 14 13 12 11 of the LCD respectively | |
| | #47 |
This works great in protues but since my line 2 doesnt work i cant see the actual digits but in MPLAB i can see they are in fact increasing and decreasing: Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(void);
void home_screen(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void main(void);
void calc_distance(void);
#define LCD_STROBE() LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10; //
unsigned char cm; //
unsigned int math; // used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
char temp[8];
int height=50, SensorPos=10;
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
#define HOME_SW RC2 //HOME switch
#define INCREASE_SW RC3 //INCREASE switch
#define DECREASE_SW RC4 //DECREASE switch
#define ENTERSETTINGS_SW RA4 //ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
scale=floor(0.5+scale/10.0);
d=(unsigned char) (n/scale);
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
n=n*10.0;
d=(unsigned char) n;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if XTAL_FREQ <= 2MHZ
do {
DelayUs(996);
} while(--cnt);
#endif
#if XTAL_FREQ > 2MHZ
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
void DelayS(unsigned char cnt)
for (j=0; j<(cnt*10); j++)
DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
DelayMs(2); //wait for LCD to be ready shorter delay
LCD_RS = 0; //write instruction
PORTB = (c & 0xF0); //load upper nibble on LCD data lines
LCD_STROBE(); //send instruction to LCD
PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
PORTB = 0x00;
LCD_RS = 1; //write data
PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
PORTB &= 0x00; //load upper nibble on LCD data lines
PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
j = -1;
while(s[++j]!=('\0')) // send characters until null character reached
lcd_data(s[j]);
/*go to beginning of line 1*/
lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
DelayMs(20); //wait for LCD startup
lcd_cmd(0x28); // 4-bit mode
lcd_cmd(0x08); // display off
lcd_cmd(0x01); // clear display
lcd_cmd(0x0C); // disp. on, cursor off, cursor blink off
lcd_cmd(0x06); // entry mode
lcd_cmd(0x80); // initialise DDRAM address to zero
// These are my inits. Comment them out and use the above for you
lcd_cmd(0x02);
lcd_cmd(0x08);
lcd_cmd(0x02);
lcd_cmd(0x08);
lcd_cmd(0x00);
lcd_cmd(0x06);
lcd_cmd(0x00);
lcd_cmd(0x0E);
lcd_cmd(0x00);
lcd_cmd(0x01);
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
MyVal = 0; //initializn these variables here
MyMinVal = 0;
MyMaxVal = 99;
OSCCON|=0x60; //set fosc to 4Mhz
TRISB=0x00;
TRISC=0xFC;
TRISA = 0b10010010; // RA7 high imp, RA3 is serial out, RA4 button input
ANSEL=0x02; //set RA1 as analog input for GP2 sensor
ANSELH=0x00;
lcd_init(); //call LCD initialisation
char WaitForInput(void){
char done;
char temp;
done = 0;
while(!done){
if(!ENTERSETTINGS_SW){
temp = 1;
done = 0xff;
if(!HOME_SW){
temp = 2;
done = 0xff;
if(!INCREASE_SW){
temp = 3;
done = 0xff;
if(!DECREASE_SW){
temp = 4;
done = 0xff;
}//end of while
DelayMs(150); //debounce
return temp;
void EnterScreen(void){
lcd_clear();
lcd_goto_L1();
lcd_puts(" ENTER/SETTINGS ");
void ShowDigits(unsigned char val){
MyValLCD[0] = val /10; //returns the quotient (if temp = 35 the result is 3)
MyValLCD[1] = val % 10; //Returns remainder (if temp = 35 the result is 5)
MyValLCD[0] += 0x30; //to ASCII
MyValLCD[1] += 0x30; //to ASCII
EnterScreen();
lcd_goto_L2();
lcd_data(MyValLCD[0]); //to LCD
lcd_data(MyValLCD[1]); //to LCD
// from the transeiver datasheet the analog voltage is
// the inverse of distance, so distance can be calculated
// d = (1 / volts) then just scaled to suit the transeiver
// load ADC value in 16bit math var
math = ADRESH;
math = (math * 256);
math += ADRESL;
// now invert it; (1 / volts) use (6050 / volts) for scaling
math = (6050 / math);
if(math >= 2) math -=2; // fix linear error (-2)
if(math > 99) math = 99; // max limit at 99cm
// convert from 0-99 to 2 decimal digits, 0-99cm
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
void home_screen(void){
mnuPOS = 0;
lcd_clear();
lcd_goto_L1();
lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
lcd_goto_L2();
lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
// i dont have a while(1) here any more
//Im calling the wait for input function here
input_sw = WaitForInput();
while(input_sw != 1); // wait until enter is pressed
EnterScreen();
mnuPOS = 1;
DelayMs(2); //shorter delay
while(mnuPOS == 1){
switch(input_sw){
case 1:
mnuPOS = 2; //This tells us the user finished entering
lcd_goto_L1();
lcd_puts(" Done! "); //home screen message (line 1)
break;
case 3:
if(MyVal < MyMaxVal)
MyVal++;
ShowDigits(MyVal);
break;
case 4:
if(MyVal > MyMinVal)
MyVal--;
ShowDigits(MyVal);
break;
default:
break;
DelayS(1);
//Do something here with the new Value which is a decimal in
//MyVal. The user is here because all data is entered
//i added a return here
//return;
//im not 100% sure but since its a void i think a return isnt needed
void main(void)
init(); // initialise I/O ports, LCD
while(1){
home_screen();
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #48 |
tried your above code... when i power up it displays: "INFRARED LIQUID LEVEL DETECTOR_" clears then displays "ENTER/SETTINGS" clears then displays.............. Done!................. when i press HOME it goes to "infrared liquid level detector_" when i release............................its stable and displays the same msg when i press settings and release settings: "INFRARED LIQUID LEVEL DETECTOR_" clears then displays "ENTER/SETTINGS" clears then displays.............. Done!................. when i press increase and release it goes to "infrared liquid level detector_" when i release............................its stable and displays the same msg the decrease does the same that the increase does | |
| | #49 |
if i press enter/settings 1st..... it says "IR LLD' then enter/settings then done! then repeats....... then i press increse and in increases but in gets interupted by the done! msg and then it stops at "IR LLD" the same thing happens for the decrease | |
| | #50 |
Sorry hay....i dont know why my browser was extremely slow today. i noticed............................. when i power on: " ir lld" is displayed then "settings/enter" then "done!" and it repeats itself continuously... when i press enter/settings 1st the same thing happens..... BUT i noticed that i can only increase and decrease Whenever the ENTER/SETTINGS passes by otherwise if i press increase and decrease when done or "irlld" flashes by it goes to "ir lld aka home screen" and stops there completely. even when enter/settings is not pressed 1st...as long as i increase and decrease when "enter/settings" flashes by...it will increase and decrease pressing home displays "ir lld" only and halts there ************************************************** *** ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() lol Im SO happy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Oh Oh i better stop b4 i get banned hehehe...... I tried the exact same code.....................BUT BUT BUT......my sixsense told be that THAT..............CONFIGURATION BITS had something to do with it........................... i didnt know which 1 to use....coz hehe im new to all this.... so i ran the code trying each type...i felt that the TYPE OF OSCILLATOR wasnt correct( it was set at external clockout) originally....But hehe i dont have any oscillator connected to the circuit...im using something internal of coz...so i tried the internal clock types: internal RC clock out.............did not work BUT internal RC NO Clock worked........... ![]() Now when i power on: it displays "IR LLD" and stays there...no repeating when i press "enter/settings"...it displays "enter/settings" ![]() when i press "increase"....it increases ![]() when i press decrease...it decreases..... ![]() and ......when i press done..... it says done....and goes back to "ir lld"...and i can go back to enter/settings if i want ![]() wow..................Thanks AtomSoft...... , You very helpful...![]() this is cool coz tomorrow the lecturer wanted to see some progress, actually every friday he wants to see progress.... so for tomorrow im going to show him the power supply and user interface Last edited by fantabulous68; 10th September 2009 at 02:49 PM. | |
| | #51 | |
.................................... Quote:
| | #52 |
heh cool!! i had mines on internal and even forgot to mention that to you glad to see its working on your side as on mines ![]() " ir lld" is a lazy way of not spelling it all right? Here is it in proteus: (second line wasnt working tho) ![]() EDIT: Forgot to note since i redid my PC (had a issue so reinstalled windows) i forgot to install Office(open office not ms) so im installing it now to see that lcd.doc stuff
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 10th September 2009 at 03:32 PM. | |
| | #53 |
got line 2 to work with this init. its the same as yours but i had to tell the lcd first that we are using 2 lines. You should try it as to avoid errors in future: Code: void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
lcd_cmd(0x02);
DelayMs(5);
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 10th September 2009 at 04:18 PM. | |
| | #54 |
Yeah will do that...Thanx... Im going to add the GP212 sensor to the circuit and test its reflectivity on water today.... Im going to use this interface code so the user can enter to inputs... the height of the container(default value of 50cm) and the min range the sensor is positioned from the surface of the liquid(10cm-80cm) 10cm is default.... I need these values which i will use in my calculate distance function.... Thank you so much for...helping me ....My browser is delayed today
| | #55 |
heh its no problem. Glad i could help you out. If you need help with anything else feel free to post your heart out
| | #56 |
Hehe...yeah i will be trying to program the GP212 to display measurements on the LCD....I'll definately be posting threads .....its 18:30 here. Im going to connect the sensor and take its output readings and compare it to the datasheet now... ill see you around...Take carelol tried adding to your reputation again cause u deserve it but they dont allow that and say: try spreading the reputation around | |
| | #57 |
thanks. They allow i think 1 time to add thanks tho have fun!
| | #58 |
Hi AtomSoft. Wondering if you could post the Proteus file ?
| | #59 |
heh sure thing. I had to zip it because forum doesnt allow the file type.
| | #60 |
Hi: Was thinking of the same, are you planning on using the application for a aquarium sump. If it works on water I wanted to try the same and use it to control the top off water for the sump. | |
| display, lcd, pushbutton, reading |
| Substituting a 16x2 LCD display for 16x1 LCD display? | Dawny | Electronic Projects Design/Ideas/Reviews | 19 | 11th October 2008 09:58 AM |
| Pushbutton Slow & Repeating Pulse | btanner | Electronic Projects Design/Ideas/Reviews | 1 | 22nd January 2008 06:18 PM |
| Is this display burned out? (Sony MD LCD Display) | Amphr_Moth | General Electronics Chat | 4 | 28th October 2007 07:47 PM |
| how to display '-' & '+' range number on LCD? | meera83 | Micro Controllers | 8 | 5th July 2007 09:56 AM |
| lcd display with hd44780 display driver | ANUPAMA | Micro Controllers | 2 | 7th April 2004 02:58 PM |
