| | #31 |
when i power on: infrared liquid level detector is displayed and its stable....not being repeated. and when i press enter/settings: nothing happens.... infrared liquid level detector is still displayed and stable... | |
| | #32 |
heh i never used HI-TECH before. Seems cool. And they do have a free lite version which would be great for 10F/12F/16F PICs... Can you attach the other files like delay.h and such so i can do a decent compile and test this out with MPLAB SIM
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #33 |
Yeah sure....sorry for hehe troubling you so late...ill b off to bed soon
| | #34 |
its not late here its only 6pm .. heh im in NY
| | #35 |
hehe lucky me . The power supply is working Last edited by fantabulous68; 9th September 2009 at 11:16 PM. | |
| | #36 |
heh i am about ot eat dinner then finish helping ok
| | #37 |
yeah thats cool. Thanks very much for your time... | |
| | #38 |
Ok this code seems ok but for some reason im not sure if its just MPLAB but i cant change PORTC register. So i cant trigger a button press on PORTC but i can to PORTA and it jumps to the enter screen ok but i cant simulate a button press for INCREASE and DECREASE... Do you think its possible to use Proteus to simulate? Ill have to make a schematic tho ![]() Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(void);
void home_screen(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void main(void);
void calc_distance(void);
#define LCD_RS RC0 //LCD RS pin
#define LCD_EN RC1 //LCD EN pin
#define LCD_STROBE() LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10; //
unsigned char cm; //
unsigned int math; // used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
char temp[8];
int height=50, SensorPos=10;
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
#define HOME_SW RC2 //HOME switch
#define INCREASE_SW RC3 //INCREASE switch
#define DECREASE_SW RC4 //DECREASE switch
#define ENTERSETTINGS_SW RA4 //ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
scale=floor(0.5+scale/10.0);
d=(unsigned char) (n/scale);
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
n=n*10.0;
d=(unsigned char) n;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if XTAL_FREQ <= 2MHZ
do {
DelayUs(996);
} while(--cnt);
#endif
#if XTAL_FREQ > 2MHZ
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
void DelayS(unsigned char cnt)
for (j=0; j<(cnt*10); j++)
DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
DelayMs(20); //wait for LCD to be ready
LCD_RS = 0; //write instruction
PORTB = (c & 0xF0); //load upper nibble on LCD data lines
LCD_STROBE(); //send instruction to LCD
PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
PORTB = 0x00;
LCD_RS = 1; //write data
PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
PORTB &= 0x00; //load upper nibble on LCD data lines
PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
j = -1;
while(s[++j]!=('\0')) // send characters until null character reached
lcd_data(s[j]);
/*go to beginning of line 1*/
lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
DelayMs(20); //wait for LCD startup
lcd_cmd(0x28); // 4-bit mode
lcd_cmd(0x08); // display off
lcd_cmd(0x01); // clear display
lcd_cmd(0x0C); // disp. on, cursor off, cursor blink off
lcd_cmd(0x06); // entry mode
lcd_cmd(0x80); // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
OSCCON|=0x60; //set fosc to 4Mhz
TRISB=0x00;
TRISC=0xFC;
TRISA = 0b10010010; // RA7 high imp, RA3 is serial out,
ANSEL=0x02; //set RA1 as analog input for GP2 sensor
ANSELH=0x00;
CM1CON0 = 0;
CM2CON0 = 0;
lcd_init(); //call LCD initialisation
char WaitForInput(void){
char done;
char temp;
done = 0;
temp = 0;
while(!done){
if(!ENTERSETTINGS_SW){
while(!ENTERSETTINGS_SW);
temp = 1;
done = 0xff;
if(!HOME_SW){
while(!HOME_SW);
temp = 2;
done = 0xff;
if(!INCREASE_SW){
while(!INCREASE_SW);
temp = 3;
done = 0xff;
if(!DECREASE_SW){
while(!DECREASE_SW);
temp = 4;
done = 0xff;
}//end of while
DelayMs(150); //debounce
return temp;
void home_screen(void){
lcd_clear();
lcd_goto_L1();
lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
lcd_goto_L2();
lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
void EnterScreen(void){
mnuPOS = 0;
input_sw = 0;
lcd_clear();
lcd_goto_L1();
lcd_puts(" ENTER/SETTINGS ");
void ShowDigits(unsigned char val){
MyValLCD[0] = val /10; //returns the quotient (if temp = 35 the result is 3)
MyValLCD[1] = val % 10; //Returns remainder (if temp = 35 the result is 5)
MyValLCD[0] += 0x30; //to ASCII
MyValLCD[1] += 0x30; //to ASCII
EnterScreen();
lcd_goto_L2();
lcd_data(MyValLCD[0]); //to LCD
lcd_data(MyValLCD[1]); //to LCD
// from the transeiver datasheet the analog voltage is
// the inverse of distance, so distance can be calculated
// d = (1 / volts) then just scaled to suit the transeiver
// load ADC value in 16bit math var
math = ADRESH;
math = (math * 256);
math += ADRESL;
// now invert it; (1 / volts) use (6050 / volts) for scaling
math = (6050 / math);
if(math >= 2) math -=2; // fix linear error (-2)
if(math > 99) math = 99; // max limit at 99cm
// convert from 0-99 to 2 decimal digits, 0-99cm
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
void main(void)
init(); // initialise I/O ports, LCD
home_screen();
MyVal = 0;
MyMinVal = 0;
MyMaxVal = 99;
while(1){
input_sw = 0;
input_sw = WaitForInput();
switch(input_sw){
case 1:
EnterScreen();
mnuPOS = 1;
DelayMs(50);
break;
case 2:
home_screen();
mnuPOS = 2;
break;
while(mnuPOS == 1){
input_sw = 0;
switch(input_sw){
case 1:
mnuPOS = 2;
home_screen();
break;
case 3:
if(MyVal < MyMaxVal)
MyVal++;
ShowDigits(MyVal);
break;
case 4:
if(MyVal > MyMinVal)
MyVal--;
ShowDigits(MyVal);
break;
//Do something here with the new Value which is a decimal in MyVal.
| | #39 | ||
Goodmorning Atomsoft...Thanks for trying . Hehe had to go to bed last night...stayed up till 2am-i ran the above code and same thing happens:when i power on: infrared liquid level detector is displayed and its stable....not being repeated. and when i press enter/settings: nothing happens.... infrared liquid level detector is still displayed and stable... Im going to play around with the code that had the number of presses increasing and decreasing.... Quote:
Wow thats pretty neat stuff that can be done with proteus from the picture but it looks complicated to hehe Last edited by fantabulous68; 10th September 2009 at 10:25 AM. | |||
| | #40 |
do you by any chance have a schematic? Im trying to do it in proteus but LCD isnt working at all.
| | #41 |
im not sure if its just the LCD in proteus but i had to change he LCD INIT to: Code: lcd_cmd(0x02); lcd_cmd(0x08); lcd_cmd(0x02); lcd_cmd(0x08); lcd_cmd(0x00); lcd_cmd(0x06); lcd_cmd(0x00); lcd_cmd(0x0E); lcd_cmd(0x00); lcd_cmd(0x01);
| | #42 |
I made a few changes to the code in which the increase and decrease buttons were working.... when i power on: it displays "infrared liquid level detector" then it displays "ENTER/SETTINGS" BUT NOW its not repeating continuously and stops at the enter settings screen....... when i press increase it increases when i release increase it is stable when i decrease it decreases when i release decrease its stable however pressing HOME and enter/settings has no affect Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void);
void main(void);
char temp[8];
char input_sw;
char mnuPOS;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
n=n*10.0;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
do {
DelayUs(996);
} while(--cnt);
#endif
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
DelayMs(100);
PORTB = 0x00;
/*Clear the LCD*/
j = -1;
lcd_data(s[j]);
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
void init(void)
MyVal = 0; //initializn these variables here
MyMinVal = 0;
MyMaxVal = 99;
TRISB=0x00;
TRISC=0xFC;
TRISA = 0b10010010; // RA7 high imp, RA3 is serial out, RA4 button input
ANSELH=0x00;
char done;
char temp;
done = 0;
while(!done){
temp = 1;
done = 0xff;
if(!HOME_SW){
temp = 2;
done = 0xff;
if(!INCREASE_SW){
temp = 3;
done = 0xff;
if(!DECREASE_SW){
temp = 4;
done = 0xff;
}//end of while
return temp;
lcd_clear();
lcd_goto_L1();
EnterScreen();
lcd_goto_L2();
math = ADRESH;
math += ADRESL;
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
// i dont have a while(1) here any more
//Im calling the wait for input function here
switch(input_sw){
case 1:
EnterScreen();
mnuPOS = 1;
DelayMs(50);
break;
//i made case2 go to the default case statement only since we in the home function
case 2:
break;
default: break;// should any abnormalities occur
while(mnuPOS == 1){
switch(input_sw){
//i made case1 go to the default case statement only since we in the home function
case 1:
break;
case 3:
MyVal++;
ShowDigits(MyVal);
break;
case 4:
MyVal--;
ShowDigits(MyVal);
break;
//i added this default case
default: break; // should any abnormalities occur
//i added a return here
return;
void main(void)
while(1)
home_screen();
| | #43 |
oh gosh i dont know why my ADSL is slow today. Sorry here is the LCD part of my report that i have to submit when im done with the entire project: | |
| | #44 |
here it is.................
| | #45 |
#define LCD_RS RC0 //LCD RS pin #define LCD_EN RC1 //LCD EN pin Rb7 Rb6 Rb5 Rb4 are connected to 14 13 12 11 of the LCD respectively | |
| display, lcd, pushbutton, reading |
| Substituting a 16x2 LCD display for 16x1 LCD display? | Dawny | Electronic Projects Design/Ideas/Reviews | 19 | 11th October 2008 09:58 AM |
| Pushbutton Slow & Repeating Pulse | btanner | Electronic Projects Design/Ideas/Reviews | 1 | 22nd January 2008 06:18 PM |
| Is this display burned out? (Sony MD LCD Display) | Amphr_Moth | General Electronics Chat | 4 | 28th October 2007 07:47 PM |
| how to display '-' & '+' range number on LCD? | meera83 | Micro Controllers | 8 | 5th July 2007 09:56 AM |
| lcd display with hd44780 display driver | ANUPAMA | Micro Controllers | 2 | 7th April 2004 02:58 PM |
