| | #16 |
try this and tell me what happens: Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void FloatToStr(float , char[]);
void DelayMs(unsigned char);
void lcd_cmd(unsigned char);
void lcd_data(unsigned char);
void lcd_clear(void);
void lcd_puts(const char[]);
void lcd_goto_L1(void);
void lcd_goto_L2(void);
void lcd_cursor(unsigned char);
void lcd_init(void);
void init(void);
char WaitForInput(void);
void home_screen(void);
void EnterScreen(void);
void ShowDigits(unsigned char val);
void main(void);
void calc_distance(void);
#define LCD_RS RC0 //LCD RS pin
#define LCD_EN RC1 //LCD EN pin
#define LCD_STROBE() LCD_EN = 1; asm("nop"); asm("nop"); LCD_EN = 0
unsigned char cm10; //
unsigned char cm; //
unsigned int math; // used for voltage calculations
unsigned char NumDec;
unsigned char NumSep[2];
unsigned char i,j,k;
char temp[8];
int height=50, SensorPos=10;
char input_sw;
char mnuPOS;
unsigned char MyVal;
unsigned char MyValLCD[2];
unsigned char MyMaxVal;
unsigned char MyMinVal;
#define HOME_SW RC2 //HOME switch
#define INCREASE_SW RC3 //INCREASE switch
#define DECREASE_SW RC4 //DECREASE switch
#define ENTERSETTINGS_SW RA4 //ENTERSETTINGS switch
///////////////////////CONVERT FLOAT TO STRING///////////////////
// This function was taken from the CAVR library. It was modified slightly
// to suit our design.
void FloatToStr(float n, char str[])
float scale;
unsigned char d,f;
f=0;i=0;
if (n<0.0) {n=-n; str[f]='-'; f++;};
n=n+0.005;
scale=1.0;
while (n>=scale) {scale=scale*10.0; ++i;};
if (i==0) {str[f]='0'; f++;}
else
while (i--)
scale=floor(0.5+scale/10.0);
d=(unsigned char) (n/scale);
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
for (j=0;j<=1;j++) //2 decimal points
n=n*10.0;
d=(unsigned char) n;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
///////////////////END CONVERT FLOAT TO STRING///////////////////
/////////////////////////////DELAY///////////////////////////////
void DelayMs(unsigned char cnt)
#if XTAL_FREQ <= 2MHZ
do {
DelayUs(996);
} while(--cnt);
#endif
#if XTAL_FREQ > 2MHZ
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
void DelayS(unsigned char cnt)
for (j=0; j<(cnt*10); j++)
DelayMs(100);
///////////////////////////DELAY END/////////////////////////////
//////////////////////////////LCD SETUP//////////////////////////
/* send a command to the LCD */
void lcd_cmd(unsigned char c)
DelayMs(20); //wait for LCD to be ready
LCD_RS = 0; //write instruction
PORTB = (c & 0xF0); //load upper nibble on LCD data lines
LCD_STROBE(); //send instruction to LCD
PORTB = ((c << 4) & 0xF0); //load upper nibble on LCD data lines
/* send data to the LCD */
void lcd_data(unsigned char c)
PORTB = 0x00;
LCD_RS = 1; //write data
PORTB |= (c & 0xF0); //load upper nibble on LCD data lines
PORTB &= 0x00; //load upper nibble on LCD data lines
PORTB |= ( (c << 4) & 0xF0);
/*Clear the LCD*/
lcd_cmd(0x01); //command to clear LCD
/*write a string of chars to the LCD*/
void lcd_puts(const char s[])
j = -1;
while(s[++j]!=('\0')) // send characters until null character reached
lcd_data(s[j]);
/*go to beginning of line 1*/
lcd_cmd(0b10000000); // command to go to line 1
/*go to beginning of line 2*/
lcd_cmd(0b11000000); // command to go to line 2
/*move cursor "x" positions to the right*/
void lcd_cursor(unsigned char x)
lcd_cmd(((x)&0x7F)|0x80);
/*initialise the LCD - put into 4 bit mode*/
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
DelayMs(20); //wait for LCD startup
lcd_cmd(0x28); // 4-bit mode
lcd_cmd(0x08); // display off
lcd_cmd(0x01); // clear display
lcd_cmd(0x0C); // disp. on, cursor off, cursor blink off
lcd_cmd(0x06); // entry mode
lcd_cmd(0x80); // initialise DDRAM address to zero
//////////////////////////LCD SETUP END//////////////////////////
void init(void)
OSCCON|=0x60; //set fosc to 4Mhz
TRISB=0x00;
TRISC=0xFC;
TRISA = 0b10000010; // RA7 high imp, RA3 is serial out,
ANSEL=0x02; //set RA1 as analog input for GP2 sensor
ANSELH=0x00;
lcd_init(); //call LCD initialisation
char WaitForInput(void){
char done;
char temp;
done = 0;
while(!done){
if(!ENTERSETTINGS_SW){
temp = 1;
done = 0xff;
if(!HOME_SW){
temp = 2;
done = 0xff;
if(!INCREASE_SW){
temp = 3;
done = 0xff;
if(!DECREASE_SW){
temp = 4;
done = 0xff;
}//end of while
DelayMs(150); //debounce
return temp;
void home_screen(void){
lcd_clear();
lcd_goto_L1();
lcd_puts("INFRARED LIQUID"); //home screen message (line 1)
lcd_goto_L2();
lcd_puts("LEVEL DETECTOR"); //home screen message (line 2)
void EnterScreen(void){
lcd_clear();
lcd_goto_L1();
lcd_puts(" ENTER/SETTINGS ");
void ShowDigits(unsigned char val){
MyValLCD[0] = val /10; //returns the quotient (if temp = 35 the result is 3)
MyValLCD[1] = val % 10; //Returns remainder (if temp = 35 the result is 5)
MyValLCD[0] += 0x30; //to ASCII
MyValLCD[1] += 0x30; //to ASCII
EnterScreen();
lcd_goto_L2();
lcd_data(MyValLCD[0]); //to LCD
lcd_data(MyValLCD[1]); //to LCD
// from the transeiver datasheet the analog voltage is
// the inverse of distance, so distance can be calculated
// d = (1 / volts) then just scaled to suit the transeiver
// load ADC value in 16bit math var
math = ADRESH;
math = (math * 256);
math += ADRESL;
// now invert it; (1 / volts) use (6050 / volts) for scaling
math = (6050 / math);
if(math >= 2) math -=2; // fix linear error (-2)
if(math > 99) math = 99; // max limit at 99cm
// convert from 0-99 to 2 decimal digits, 0-99cm
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
void main(void)
init(); // initialise I/O ports, LCD
//home_screen();
MyVal = 0;
MyMinVal = 0;
MyMaxVal = 99;
while(1){
input_sw = WaitForInput();
switch(input_sw){
case 1:
EnterScreen();
mnuPOS = 1;
DelayMS(50);
break;
case 2:
home_screen();
mnuPOS = 2;
break;
while(mnuPOS == 1){
switch(input_sw){
case 1:
mnuPOS = 2;
home_screen();
break;
case 3:
if(MyVal < MyMaxVal)
MyVal++;
ShowDigits(MyVal);
break;
case 4:
if(MyVal > MyMinVal)
MyVal--;
ShowDigits(MyVal);
break;
//Do something here with the new Value which is a decimal in MyVal.
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics | |
| | #17 |
Im using the new code you suggested and now when i power on: "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and so forth. when i press home button: infra red liquid level detector is displayed continuously when i release home button: "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and so forth. Code: when i press increase button: it displays enter/settings on 1st line
then 01 on 2nd line
then 02 on 2nd line
and continues increasing...
when i release increase button:"enter/settings" is displayed continuously Code: when i press decrease button: it displays enter/settings on 1st line
then 02 on 2nd line
then 01 on 2nd line
then 00 on 2nd line
then 00 on 2nd line
and 00 is the lowest it decreases to
when i release decrease button:"enter/settings" is displayed continuously when i press home/settings button: "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and so forth. when i release home/settings button: "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and so forth. Last edited by fantabulous68; 9th September 2009 at 08:41 PM. | |
| | #18 |
i think you might have a hardware issue. Are all the buttons pulled high? As soon as it goes on it should not say anything. It should be blank and you have to press the home button for it to show that "infrared liquid level detector" Hence why i suggest you uncomment the : Code: void main(void)
home_screen();
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 9th September 2009 at 09:23 PM. | |
| | #19 |
Maybe the configuration bits in MPLAB are not set corrrectly???that would affect the micro right. im using momentary push button switches....
| | #20 |
im going to uncomment home and c what happens. When i tried your new code....home is uncommented and the same remarks apply.
| | #21 |
heh replacing time: Code: TRISA = 0b10000010; // RA7 high imp, RA3 is serial out, Code: TRISA = 0b10010010; // RA7 high imp, RA3 is serial out, RA4 button input
__________________ AtomSofts eBay Store AtomSoftTech: C18 TIPS & TRICKS v9 PDF Nokia 6100 Driver/Software My Name: Jason Lopez http://atomsofttech.info/ | My YouTube Videos! My Favorite Store: dipmicro Electronics Last edited by AtomSoft; 9th September 2009 at 09:36 PM. | |
| | #22 |
oscillator external RC clockout watchdog timer off power up timer off master clear enable external code protect off data ee ee protect off brown out detect BOD enabled, sboren disabled internal external switchover mode enabled monitor clock fail-safe enabled | |
| | #23 |
what pic are you using?
| | #24 |
i replaced the TRISA line but: when i power on: "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and so forth. when i press home button: infra red liquid level detector is displayed continuously when i release home button: "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and "infrared liquid level detector is displayed" then it clears and "enter/settings" is displayed continuously then it clears and so forth. BUT now also sumtimes when i hold down the home button for long: the screen remains blank until i release it again | |
| | #25 |
im using the pic 16f690.
| | #26 |
ok. What are you using to program it? CCS or something? try this: Code: #include <pic.h>
#include "pic.h"
#include "delay.h"
#include "math.h"
#include <stdio.h>
#include <stdlib.h>
void init(void);
void main(void);
char temp[8];
char input_sw;
char mnuPOS;
float scale;
unsigned char d,f;
f=0;i=0;
n=n+0.005;
scale=1.0;
else
while (i--)
str[f]=d+'0';
n=n-scale*d;
f++;
str[f]='.';
f++;
n=n*10.0;
str[f]=d+'0';
n=n-d;
f++;
str[f]='\0';
do {
DelayUs(996);
} while(--cnt);
#endif
unsigned char p;
do {
p = 4;
do {
DelayUs(250);
} while(--p);
} while(--cnt);
#endif
DelayMs(100);
PORTB = 0x00;
/*Clear the LCD*/
j = -1;
lcd_data(s[j]);
void lcd_init(void)
LCD_RS = 0;
LCD_EN = 0;
void init(void)
TRISB=0x00;
TRISC=0xFC;
ANSELH=0x00;
char done;
char temp;
done = 0;
temp = 0;
while(!done){
while(!ENTERSETTINGS_SW);
temp = 1;
done = 0xff;
if(!HOME_SW){
while(!HOME_SW);
temp = 2;
done = 0xff;
if(!INCREASE_SW){
while(!INCREASE_SW);
temp = 3;
done = 0xff;
if(!DECREASE_SW){
while(!DECREASE_SW);
temp = 4;
done = 0xff;
}//end of while
return temp;
lcd_clear();
lcd_goto_L1();
lcd_goto_L2();
mnuPOS = 0;
input_sw = 0;
lcd_clear();
lcd_goto_L1();
EnterScreen();
lcd_goto_L2();
math = ADRESH;
math += ADRESL;
cm10=0;
while(math >= 10)
cm10++;
math -= 10;
cm = math;
void main(void)
home_screen();
MyVal = 0;
MyMinVal = 0;
MyMaxVal = 99;
while(1){
input_sw = 0;
switch(input_sw){
case 1:
EnterScreen();
mnuPOS = 1;
DelayMS(50);
break;
case 2:
home_screen();
mnuPOS = 2;
break;
while(mnuPOS == 1){
input_sw = 0;
switch(input_sw){
case 1:
mnuPOS = 2;
home_screen();
break;
case 3:
MyVal++;
ShowDigits(MyVal);
break;
case 4:
MyVal--;
ShowDigits(MyVal);
break;
| | #27 |
im using the pic kit 2 demo board with mplab ide v8.01-hi-tech universal toolsuite:hi tech ansi c compiler pic lite....whats ccs???hehe
| | #28 |
the new code it gives an error: Error [499] ; 0. undefined symbol: _DelayMS(ctest.obj) ok i corrected it....MS to Ms Last edited by fantabulous68; 9th September 2009 at 10:10 PM. | |
| | #29 |
ok i ran the new code and: when i power up: infrared liquid level detector is displayed and its stable....not being repeated. however pressing the buttons has no effect | |
| | #30 |
Ok the way this works is to enter settings you need to press enter then use increase and decrease. What happens when you press enter? nothing?
| display, lcd, pushbutton, reading |
| Substituting a 16x2 LCD display for 16x1 LCD display? | Dawny | Electronic Projects Design/Ideas/Reviews | 19 | 11th October 2008 09:58 AM |
| Pushbutton Slow & Repeating Pulse | btanner | Electronic Projects Design/Ideas/Reviews | 1 | 22nd January 2008 06:18 PM |
| Is this display burned out? (Sony MD LCD Display) | Amphr_Moth | General Electronics Chat | 4 | 28th October 2007 07:47 PM |
| how to display '-' & '+' range number on LCD? | meera83 | Micro Controllers | 8 | 5th July 2007 09:56 AM |
| lcd display with hd44780 display driver | ANUPAMA | Micro Controllers | 2 | 7th April 2004 02:58 PM |
