Notices
Old 14th June 2004, 05:01 AM   (permalink (permalink))
Default Delay doesn't seem to work - Help!
Delay   movlw	d'39'		; load this to the timer
Loop	btfss	_intcon,2	; if tmr0 overflow is not set
	goto	Loop		; loop, else skip
	bcf	_intcon,2	; clear the timer interrupt flag
	decfsz	w,w		; loop until the wreg is zero
	goto 	Loop		; it isn't zero so loop
	return			; zero, so we return
Not sure why this doesn't seem to work. My thinking is as follows:
Clock speed of 4000000Hz/4 = 1000000hz
This 1/4th value is further divided by my pre-scaler of choice /256: 1000000hz/256 = 3906.25hz
3906.25 pulses take 1 second - so to count 10ms delay we need to count when this has tripped over 39 times. To prove this 1/3906.25 = 2.56x10-4 * 39 = 9.98ms.
Right or wrong? Is there anything else needed to get the TMR0 overflow to work?
Thanks,
Mike
"Ambition is the last refuge of failure..." --Oscar Wilde
"Success is not final, failure is not fatal: it is the courage to continue that counts." -- Winston Churchill
bsodmike is offline
Old 14th June 2004, 06:01 AM   (permalink (permalink))
Any ideas?
bsodmike is offline
Old 14th June 2004, 06:17 AM   (permalink (permalink))
Originally Posted by bsodmike
Any ideas?
My main idea is 'why bother'.
Why not simply use the delay code generator on the PICList to generate delay code for you? - it's far more versatile!.
Are you sure you are setting everything up correctly?, you've only posted a small piece of the code, so there's no indication of how it's set up at all.
Old 14th June 2004, 06:20 AM   (permalink (permalink))
I move to RPO and have set this:
movlw b'10100000'
movwf _intcon
however by using this delay:
Delay clrf _tmr0
tloop movlw d'39'
subwf _tmr0,w
btfss _status,0
goto tloop
return
I have got it to work - but it alters tmr0. I could also count 10000 lines of code (big nested loop...) and it'll work...
I will settle for the way I've posted above...thanks
Mike
bsodmike is offline
Old 14th June 2004, 06:30 AM   (permalink (permalink))
; Delay = 0.01 seconds
; Clock frequency = 4 MHz
; Actual delay = 0.01 seconds = 10000 cycles
; Error = 0 %
	cblock
	cnt1
	cnt1_1
	endc
Delay
			;9993 cycles
	movlw	0xCE
	movwf	cnt1
	movlw	0x08
	movwf	cnt1_1
Delay_0
	decfsz	cnt1, f
	goto	$+2
	decfsz	cnt1_1, f
	goto	Delay_0
			;3 cycles
	goto	$+1
	nop
			;4 cycles (including call)
	return
This is what the generator gives me. CE = 206 and 8, so wouldn't this mean 206 * 8 ??? How is it 9993 ?!?!
bsodmike is offline
Old 14th June 2004, 08:17 AM   (permalink (permalink))
It's not as simple as that, the inner loop (cnt1) loops round to 255 after it reaches zero.
Don't worry about it, just use it!.
Old 14th June 2004, 09:47 AM   (permalink (permalink))
I took a quick glance at your code. You can't use the ff. sequence because the W register is not a regular file register.
It will compile without error but because the value of W is defined as "0", the register that will be accessed will be the INDF register. You have to use a real file register instead of W.
"Having to do with Motion Control"
motion is offline
