+ Reply to Thread
Results 1 to 3 of 3
Thread: configuration bits problem in mikroe
  1. #1
    einton Newbie
    Join Date
    Jan 2009
    Location
    pakistan
    Posts
    45
    Default configuration bits problem in mikroe
    Hi guys hope every one will be fine there
    Guys I have universal programmer which ask for setting configuration bits in the file after loading it and before program chip . I don’t see any configuration bits setting window in my compiler of mikroc as like in mplab since when i used mplab i just copy the configuration bits from configuration bits gui of mplab in my config bits setting gui of my programmer and it works and but i find none same here from which i copy, i used following setting while using mikroc compiler
    osc=hs,osc=off,wdt=off,lvp=off
    i also try my [rogrammer by putting configuration bits generated from mplab according to above specification but not working
    is there any other available mikroc compiler available , please tell me what should I do i m quite nervous i have gone through most of it programming but my simple program of chasing led not working.
    thanx
  2. #2
    gaspode42 Good gaspode42 Good gaspode42 Good gaspode42 Good
    Join Date
    Feb 2009
    Location
    UK
    Posts
    201
    Default Configuration Bits
    Hi Einton,
    Not sure if I have understood your question correctly but here is what I think you mean. I am using the pro version so apologies if this is not quite correct.
    1. In your project select Project -> Edit Project
    This should show you all the configuration fuses for the processor used in the project. On the right of this window is shown the names and values that require to be used in your programmer.
    I hope this makes sense
  3. #3
    einton Newbie
    Join Date
    Jan 2009
    Location
    pakistan
    Posts
    45
    Default thanx
    Yes it works
    may u get successsful in all paths of ur life truly
+ Reply to Thread
  1. PIC18LF4423 - Configuration Bits Set Appropriately?
    By Fred.Amoson in forum Micro Controllers
    Latest: 2nd April 2008, 11:41 PM
  2. Configuration bits?
    By RedCore in forum Micro Controllers
    Latest: 9th May 2007, 08:47 AM
  3. configuration bits
    By frustration in forum Micro Controllers
    Latest: 30th April 2007, 11:43 AM
  4. 8 bits LCD Problem
    By joe_1 in forum Micro Controllers
    Latest: 27th April 2007, 01:38 AM
  5. Configuration Bits (Nigel's tutorials and Inchworm)
    By lpinkai in forum Micro Controllers
    Latest: 23rd January 2007, 05:39 PM
Tags for this Thread
