+ Reply to Thread
Results 1 to 9 of 9
Thread: 18F4620 can blink LED in MikroC but not ASM
  1. #1
    Peter_wadley Good Peter_wadley Good
    Join Date
    Mar 2007
    Location
    Toronto, Canada
    Posts
    374
    Default 18F4620 can blink LED in MikroC but not ASM
    Hey there,
    I've just switched over to from 16F to 18F..
    Having a bit of a problem though.
    I'm doing the Hello World LED blink test but having problems.
    I'm using the PICKIT2 to program.
    I've been trying for hours to get an LED blink on Pin 0 of Port D with no luck.
    When I program the µC to blink using mikroC it was fine.
    But when I use the attached code in MPLAB it does not work..
    I've tried selecting the bits from MPLAB rather then setting them in code...
    You can even see the commented out section where I tried hardcoding the config bits to exactly what worked with MikroC....
    I've tried everything it seems!! Anyone see anything wrong with the code?
    Thanks!!
    	LIST P=18F4620		;directive to define processor
    	#include <P18F4620.INC>	;processor specific variable definitions
    ;__CONFIG _CONFIG1H, 0xC2
    ;__CONFIG _CONFIG2H, 0x1E
    ;__CONFIG _CONFIG2L, 0x1F
    ;__CONFIG _CONFIG3H, 0x87
    ;__CONFIG _CONFIG4L, 0x81
    ;__CONFIG _CONFIG5H, 0xC0
    ;__CONFIG _CONFIG5L, 0x0F
    ;__CONFIG _CONFIG6H, 0xE0
    ;__CONFIG _CONFIG6L, 0x0F
    ;__CONFIG _CONFIG7H, 0x40
    ;__CONFIG _CONFIG7L, 0x0F
     __CONFIG  _CONFIG1H,  _OSC_HS_1H
     __CONFIG   _CONFIG2H, _WDT_OFF_2H
     __CONFIG   _CONFIG3H, _MCLRE_ON_3H
     __CONFIG   _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    CBLOCK	0x080
    d1
    d2
    d3
    ENDC
    ORG	0x0000
    Main:
    CLRF TRISD
    CLRF PORTD
    Start:
    BSF PORTD,0
    call delay
    BCF PORTD,0
    call delay
    goto Start
    delay
    ; Delay for 1 second using 20mhz clock
    movlw	0x2D
    	movwf	d1
    	movlw	0xE7
    	movwf	d2
    	movlw	0x0B
    	movwf	d3
    Delay_0
    	decfsz	d1, f
    	goto	$+2
    	decfsz	d2, f
    	goto	$+2
    	decfsz	d3, f
    	goto	Delay_0
    nop
    retlw	0x00
    goto Main
    END
    "Stick around" - Arnold Schwarzenegger in The Predator after impaling a soldier to a wood post
    9vDC Guitar Pedal PSU
    PIC16F84a Game Module
  2. #2
    be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent be80be Excellent
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    maybe this get it going
    CBLOCK	0x080
    d1
    d2
    d3
    ENDC
    ORG	0x0000
    Main:
    CLRF TRISD
    CLRF LATD
    movlw 0h
    movwf TRISD
    Start:
    BSF PORTD,0
    call delay
    BCF PORTD,0
    call delay
    goto Start
    delay
    movlw	0x2D
    	movwf	d1
    	movlw	0xE7
    	movwf	d2
    	movlw	0x0B
    	movwf	d3
    Delay_0
    	decfsz	d1, f
    	goto	$+2
    	decfsz	d2, f
    	goto	$+2
    	decfsz	d3, f
    	goto	Delay_0
    nop
    retlw	0x00
    goto Main
    END
    Burt
  3. #3
    Join Date
    Mar 2007
    Location
    Toronto, Canada
    Posts
    374
    Still nothing
    something doesn't seem right...
    Circuit works completely fine when using mikroC code:
    void main(){
     TRISD = 0;
     PORTD = 0;
     while(1){
     PORTD = 255;
    Delay_ms(1000);
     PORTD = 0;
     Delay_ms(1000);
  4. #4
    Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent Pommie Excellent
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,799
    This is why I detest the use of goto $+n, try changing it to,
    Delay_0
    		decfsz	d1, f
    		goto	Del1
    		decfsz	d2, f
    Del1		goto	Del2
    		decfsz	d3, f
    Del2		goto	Delay_0
    		nop
    		retlw	0x00
    And all will work correctly. Look at the disassembly list to see why.
    Join Date
    Mar 2007
    Location
    Toronto, Canada
    Posts
    374
    WOW! Now that was something I was never going to find!!!
    I seriously tried for 2 days more than I should have to get this to work!!
    Thanks Mike! Karma++ to you!!
    I looked at the disassembly and from what I could see the $+2 instruction jumped to locations that weren't in use..
    Is this correct?
    Why is this happening? What does the $ sign mean?
    I have used this delay code generator for all of my 16F projects in the past without problems..
    Microchip PIC, ASM Delay Code, Code Generator
    is it that the 18F's just don't like this code?
  6. #6
    Join Date
    Aug 2008
    Location
    morristown,tn
    Posts
    2,000
    It was jumping to two nops but your delay looked right mikes the man
    Burt
  7. #7
    Join Date
    Mar 2005
    Location
    Brisbane Australia
    Posts
    6,799
    The $ sign is used to represent the program counter and so goto $+2 jumps over the next instruction. However, on 18 series chips each instruction occupies two locations and gotos use 4. You can change the goto $+2 to goto $+6 but I prefer using labels.
    Join Date
    Mar 2007
    Location
    Toronto, Canada
    Posts
    374
    aww I see..
    So ... for 16F
    if the program counter was at location 0x20
    goto $+2 would tell the PC to go to 0x22? - skipping the instruction @ 0x21
    but for 18F if this code was used, a byte of the 'goto $+2' instruction would actually be located @ 0x22 (since it started in 0x20) sending the PC into no man's land??
    I'm I understanding this correctly?
    so $+6 would work like...
    goto $+6 ; is located @ 0x20
    ;0x20 ;is used by 'goto $+6'
    ;0x21 ;is used by 'goto $+6'
    ;0x22 ;is used by 'goto $+6'
    ;0x23 ;is used by 'goto $+6'
    ;0x24 ;first byte of instruction we want to skip
    ;0x25 ;Second byte of instruction we want to skip
    ;0x26 ; instruction we wanted to skip too
    interesting!! 18F is a whole new animal it seems...
    I just worked through transferring code from 16F to 18F which plays a short 5000 bit/second audio clip.
    Since the 16F877a only had 8K of ROM
    I wanted to use us the 18F4620 with 64K of ROM.
    When I went to play the sound for the first time all of the high frequency was lost ... I realized I needed to change the computed GOTO statement since each retlw in the table use 2 bytes of ROM and not 1 like 16F. So I increased the offset by 2 after every byte is retrieved
    I guess this would mean I can only use 32K this way.
    In order to use the entire 64K I assume I will need to use the table read and write??
  9. #9
    Join Date
    Mar 2007
    Location
    Toronto, Canada
    Posts
    374
    Also is it true that the fcall macro is no longer needed? which sets up the pclath reg properly before calling functions on a different page
    here is the 16F code for the sound player (1bit,1pin setup)
    #include <p16F877A.inc>
    __CONFIG  _HS_OSC &   _WDT_OFF & _CP_OFF & _CPD_OFF & _LVP_OFF
         cblock 0x20
    d1
    d2
    d3
    Delay1               ; Define two file registers for the
    Delay2               ; delay loop
    bitCount
    byteCount
    blockCount
    dataByte
    OffsetH
    OffsetL
    endc
     ; the fcall macro
    fcall	macro subroutine_name
    	local here
    	lcall 	subroutine_name ; set PCLATH correctly
    	pagesel here 			; set PCLATH correctly - means?
    here:
    	endm
    org 0x00
    bsf       STATUS,RP0     ; select Register Bank 1
    bcf       TRISD,0        ; make IO Pin RD0 an output
    bcf       STATUS,RP0     ; back to Register Bank 0
    Start   clrf OffsetH
            clrf OffsetL
    SoundLoop
            fcall Table
    		nop
    		nop
    		nop
    		nop
            movwf dataByte
    		movlw	d'8'
    		movwf	bitCount
    BitBang
    		rlf		dataByte
    		btfss	STATUS,C
    		bcf		PORTD,0
    		btfsc	STATUS,C
    		bsf		PORTD,0
    		call	delay
    		decfsz	bitCount
    		goto	BitBang
            incf OffsetL    ; add 1 to data pointer
            skpnz
            incf OffsetH
    NoUp    movlw Low(d'8060')
            xorwf OffsetL,W
            skpz
            goto SoundLoop
            movlw High(d'8060')
            xorwf OffsetH,W
     	skpz
            goto SoundLoop
            fcall label
    delay
    		;998 cycles
    	movlw	0xC7
    	movwf	d1
    	movlw	0x01
    	movwf	d2
    Delay_0
    	decfsz	d1, f
    	goto	$+2
    	decfsz	d2, f
    	goto	Delay_0
    retlw	0x00
    ; SOUND DATA TABLE
    Table movlw   High(TStart)
            addwf   OffsetH,W
            movwf   PCLATH
            movlw   Low(TStart)
            addwf   OffsetL,W
            skpnc
            incf 	   PCLATH,F
            movwf   PCL     ;computed goto with right PCLATH
            				; end Table subroutine
    TStart
      ;-------------------------  0
         retlw b'10010110'   ; 96
         retlw b'11000010'   ; c2
         retlw b'10101111'   ; af
         retlw b'00100100'   ; 24
         retlw b'11010110'   ; d6
         retlw b'00110011'   ; 33
         retlw b'00110110'   ; 36
         retlw b'10001100'   ; 8c
         retlw b'11100101'   ; e5
         retlw b'10010010'   ; 92
         retlw b'11010101'   ; d5
         retlw b'10001101'   ; 8d
         retlw b'10010101'   ; 95
    ..... 8060 retlw's in total (not included) ...
    and the 18F code ... changes include:
    1) RLF to RLCF for cycling the bits through the port
    2) changing offset range from 8060 to 8060 x 2 = 16120
    3) No need for fcall macro since 'call' can address 2MB ROM space
    4)skpnc, skpnz, skpz, and skpc weren't defined anymore so had to use btfsc STATUS, C ... ect
    cblock 0x80
    d1
    d2
    d3
    Delay2               ; delay loop
    bitCount
    byteCount
    blockCount
    dataByte
    OffsetH
    OffsetL
    endc
    org 0x00
    Start  clrf OffsetH
             clrf OffsetL
    SoundLoop
            call Table
    	nop
    	nop
    	nop
    	nop
            movwf dataByte
    	movlw	d'8'
    	movwf	bitCount
    BitBang
    		rlcf	dataByte
    		btfss	STATUS,C
    		bcf	PORTD,0
    		btfsc	STATUS,C
    		bsf	PORTD,0
    		call	delay
    		decfsz	bitCount
    		goto	BitBang
           	btfsc STATUS,Z
            incf OffsetH
           	btfsc STATUS,Z
            incf OffsetH
    NoUp
    movlw Low(d'16120')
            xorwf OffsetL,W
            btfss STATUS,Z
            goto SoundLoop
            movlw High(d'16120')
            xorwf OffsetH,W
     		btfss STATUS,Z
            goto SoundLoop
            call 	Start			; end
    delay
    			;998 cycles
    	movlw	0xC7
    	movwf	d1
    	movlw	0x01
    	movwf	d2
    Delay_0
    	decfsz	d1, f
    	goto	$+6
    	decfsz	d2, f
    	goto	Delay_0
    	nop
    	nop
    retlw	0x00
    ; SOUND DATA TABLE
    Table
    	movlw 	High(TStart)
            addwf   OffsetH,W
            movwf   PCLATH
            movlw 	Low(TStart)
            addwf 	OffsetL,W
            btfsc 	STATUS,C
            incf 	PCLATH,F
    TStart
         retlw b'01001101'   ; 4d
         retlw b'01011000'   ; 58
         retlw b'01100010'   ; 62
         retlw b'10111010'   ; ba
         retlw b'01010101'   ; 55
         retlw b'01100011'   ; 63
+ Reply to Thread
  1. MMC with PIC18F4550 using MiKroC
    By Nizar in forum Micro Controllers
    Latest: 28th February 2009, 01:14 PM
  2. i need mikroC code
    By ouranix in forum Micro Controllers
    Latest: 21st February 2009, 01:31 PM
  3. simulation 18F4620
    By Mitt in forum Micro Controllers
    Latest: 19th February 2009, 12:06 PM
  4. pic 18f4620
    By mai_elec in forum Micro Controllers
    Latest: 25th January 2009, 09:06 PM
  5. mikroC problem
    By colin mac in forum Micro Controllers
    Latest: 22nd July 2008, 12:02 PM
Tags for this Thread
