Old 18th July 2009, 04:27 AM   #61
Well I got my hands on the code that JOHN BECKER - EPE INTRUDER ALARM
It's in assembly I'm not going to post it all but here is the problem
;PIC16F877-4, 3.2768MHz, WDT OFF, POR ON, XTAL XS
be80be is offline
Old 18th July 2009, 03:02 PM   #62
it is really damage that you do not speak French.
This forum is really indeed . my English is tres restricted.
for the intruder alarm it is a nice tres alarms.
http://www.monsterup.com/upload/1247925308975.jpg
I ais the schema, program ....I would like to make him
but quesque it is S1, S2? 2 buttons ?
http://www.monsterup.com/upload/1247925351747.jpg
Thank
paris (france)
seti75 is offline
Old 18th July 2009, 03:18 PM   #63
I was going to get It to working I 'll post how the switches work. Here i not sure if this helps or not it's the switches
be80be is offline
Old 18th July 2009, 03:39 PM   #64
my keyboard keys --> 3x4 ...no 4x4
if I made the realization EPE INTRUDER ALARM
This can cause a problem ?
is my lcd 2x16 is as good ?
on this project, we have the asm file
what is important , that you think?
I started the project?
thank .....
be80be ,
I sent an email.
* Monitors between one and eight entry/exit points (zones) of a building or room
* Allows monitoring to be totally or partially suspended when required by the legitimate guardians (users) of the premises
* Indicates audibly (e.g. bell) and/or visibly (e.g. strobe) when one or more zones have been entered without authority
* Turns off activated bell after a preset period to prevent annoyance to neighbours
* Allows timed zone entry/exit (time-out) for users without triggering the full alarm
* Allows full monitoring of required zones once time-out has ended
* Allows users to terminate time-out procedure
* Allows users to control the monitoring system by means of a unique alphanumeric personal identity code (PIN) entered via a keypad
* Allows users to change the PIN code
* Allows users to access the control system without using a PIN code in the event of system failure or servicing
* Normally powered from a mains power source
* Instantaneously switches over to being powered by a heavy duty back-up battery if mains power fails
* Keeps the battery fully charged when mains power is present (the battery should be capable of keeping the monitoring system and any activated alarms operational for a reasonable period)
* Allows the system to resume active monitoring should power totally fail but subsequently resume
* Indicates that there has been a total power failure even after power has been resumed
* Prevents the bell from being activated when power is resumed
* Indicates for later viewing whether zones have been entered, even though there may also have been a power failure and resumption
* Allows monitoring of fewer zones than are available
* Automatically recognizes whether a sensor should be monitored for an open circuit or a closed circuit
* Allows open circuit or closed circuit sensors to be used without system modification
* Recognizes that a sensor is incorrectly open or closed prior to monitoring being activated and indicates which sensor is incorrect (i.e. door open when it should be closed)
* Allows users to preview zone sensor status
* Allows the bell-on time to be set for a shorter period than the 20 minutes permitted in the UK
* Prevents the bell-on time exceeding the UK limit
* Allows users to check the system by means of indicator lights without activating the bell (etc.)
* Allows indicator lights to display the status of the power supply and bell (etc.)
* Provides anti-tamper warning of interference with the system
* Provides a "Panic" button that immediately activates the bell (etc.) even if the system is not set for full zone monitoring
* Provides "passive" advice (e.g. buzzer) that a zone has been entered even if the system is not set for full monitoring, and for the advice to be terminated once the zone has been vacated (e.g. to monitor shop-door opening/closing)
* Accepts all conventional types of switched-output commercial sensor, including magnetic catches, pressure pads, passive infrared (PIR) devices, vibration detectors, etc., and for any mixture of these to be used
* Provides an optional slave keypad with separate PIN for additional access to a selected zone
* Inherently stable and most unlikely to be triggered except via the installed sensors
* Inexpensive to construct
paris (france)
seti75 is offline
Old 20th July 2009, 03:53 PM   #65
even if I do not make this alarm
It allowed my checked my LCD and PIC
all good... pic + lcd --->
http://www.monsterup.com/upload/1248095520439.jpg
http://elektron.uw.hu/elektro/PIC/riaszto/riaszto.pdf
paris (france)
seti75 is offline
alarm, house
Old unconnected house alarm (accenta 6) Myrmidon General Electronics Chat 2 27th January 2009 03:23 PM
House Alarm slickonez99 Electronic Projects Design/Ideas/Reviews 33 24th December 2008 04:39 AM
Nokia gsm connected to house alarm cctv Electronic Projects Design/Ideas/Reviews 3 6th October 2006 11:36 PM
Need help with burglar alarm for a model house. rancid rock Electronic Projects Design/Ideas/Reviews 27 15th March 2006 07:55 AM
