| | #46 |
Since the LED is flashing why would you assume the 16F877 is broken?
| | #47 | |
on your 16f877 Last edited by be80be; 16th July 2009 at 07:38 PM. | ||
| | #48 |
the 16f877 does not function with my lcd 2x16 to see the post at the beginning. with the moin 10 programs tested, no n' functioned with the 16f877, the lcd is good since it was tested with the 16f84 and it functions perfectly be80be --> but j' board makes test with the lcd and the 16f877 with quartz of 4mhz and without quartz I n' board ever have any favorable result
__________________ paris (france) Last edited by seti75; 16th July 2009 at 07:45 PM. | |
| | #49 | |
When you tested the blink code what crystal did you use | ||
| | #50 |
4mhz flash led 16f877 ..... ..ok 4mhz lcd 16f84.................... ..ok 4mhz and 16f877 and lcd ....... not good 20mhz and 16f877 and lcd ......not good
__________________ paris (france) | |
| | #51 |
This is how I do it. In this pic look at how the crystal resonator is placed They don't work good with jumper Last edited by be80be; 16th July 2009 at 08:34 PM. | |
| | #52 |
The original schematic used a 20Mhz xtal...
__________________ Eccentric millionaire financed by 'er indoors | |
| | #53 |
chippie I no what it used did you look at the picture that OP posted the 20mhz crystal is hooked to the 16f877 with jumpers. The chips not osculating is what's wrong This is OP board look at osc Last edited by be80be; 16th July 2009 at 08:46 PM. | |
| | #54 | |
Scoping the pins should tell whats going on...
__________________ Eccentric millionaire financed by 'er indoors | ||
| | #55 |
Before opening the post (1) first one, I had made this alarm At the beginning the problém was the same ! Nothing on the lcd. It is for that that I post Voila the position of the quartz, and it was the Same thing my alarm Imageshack - quartz
__________________ paris (france) Last edited by seti75; 17th July 2009 at 12:17 AM. | |
| | #56 | |
I have changed crystals and it worked fine. If I could fly over I bet I'd have it running in a sec. | ||
| | #57 | |
The blinking a led with the Watchdog Timer on a 16f877 will not tell you if the crystal is working Quote:
| | #58 |
be80be , thank I thank all for your help . I leave this project because it will never work! One friends think that the program b' is not good. This program was on a French forum, but the one that he proposed it was not on his (her,its) program, the electronique pratique (review) practical do not propose any more the program. If you know an alarm with a lcd and the same possibility that that her(it) thank you for me proposed. I leave , the program which made me lose a lot of time(weather), if a person want to make tries... program ---> Free - Envoyez vos documents Imageshack - sanstitre1txf Imageshack - sanstitre3p Imageshack - sanstitre4i Imageshack - sanstitre5c
| | #59 |
Was this a school project?
| | #60 |
Well seti75 it's up[ to you but I don't think your problem is as hard to fix as you think. You can't test the oscillator with the code from blueroomelectronics He was using the wdt it would still blink if you pulled the crystal out and threw it away.I still say it's in that 20 mhz crystal your using | |
| alarm, house |
| Old unconnected house alarm (accenta 6) | Myrmidon | General Electronics Chat | 2 | 27th January 2009 03:23 PM |
| House Alarm | slickonez99 | Electronic Projects Design/Ideas/Reviews | 33 | 24th December 2008 04:39 AM |
| Nokia gsm connected to house alarm | cctv | Electronic Projects Design/Ideas/Reviews | 3 | 6th October 2006 11:36 PM |
| Need help with burglar alarm for a model house. | rancid rock | Electronic Projects Design/Ideas/Reviews | 27 | 15th March 2006 07:55 AM |
