| | #31 |
This is what get's me Op ask for help with this but no code has been posted and they said they tried it with a 16f84 and no go. If you look at the circuit for 16f84 it has a 4 mhz crystal so if you left the 20mhz on the board it wouldn't work the start up delays would be to fast for the lcd. Last edited by be80be; 14th July 2009 at 04:55 PM. | |
| | #32 |
c4 and c5 removed, that does not function. the program of this alarm -----> Free - Envoyez vos documents is somebody has a simple program (leds) for tested this 16f877 and knowledge s' it is good? I specify once again that several programs were tested with this 16f877 and no n' functioned!
__________________ paris (france) | |
| | #33 |
I can't read that maybe if you want this fix you would take time to post it so we can help you. a hex is not much good if some thing goes wrong you need the code
| | #34 |
One do not understand . If you look at my post since the debut, kept silent will see that it is an assembly (editing) of electronique practice ( alarm ) with one 16f877 and a quartz of 20mhz. My probléme it is to know if my 16f877 is good....?
__________________ paris (france) Last edited by seti75; 14th July 2009 at 06:37 PM. | |
| | #35 |
Try flashing an LED. I posted a link to a simple LED flasher for the 16F877.
| | #36 | |
Bill they want a hex that blinks. yes you put the thing together so you can call it Quote:
It's hard to help you because we can't see what your doing and your writing is worst then mine | ||
| | #37 |
my lcd is good with the program of this page PIC to LCD interface test my lcd --> Imageshack - hellw it is necessary that I find the same program test for a 16f877. to know if the 16f877 really died
| | #38 | |
Do what Blueroom electronics suggested...flash an led....You can write the code so that you could test each pin individually or sequentially... ;*** WDT reset toggles RB0 list p=16F877A include <p16F877A.inc> __CONFIG 0x3F7D org 0 bsf STATUS, RP0 movlw b'00001110' movwf OPTION_REG bcf TRISB, 0 bcf STATUS, RP0 movlw 1 xorwf PORTB, f sleep end BRE, Hope you dont mind me posting the code...
__________________ Eccentric millionaire financed by 'er indoors Last edited by Chippie; 16th July 2009 at 04:35 PM. | ||
| | #39 |
I do not include/understand ? with which diagram ? (schématic) thank
__________________ paris (france) Last edited by seti75; 16th July 2009 at 04:55 PM. | |
| | #40 |
Follow the link....schema is at the bottom of the page... http://www.blueroomelectronics.com/d...%20Project.pdf
__________________ Eccentric millionaire financed by 'er indoors | |
| | #41 |
| | #42 |
If you program the hex file into the 877, and wire up to the schema it should blink the led....
| | #43 |
I do not know only c' is vpp, pgd, pgc I have just finished l' test without connected vpp, pgd, and pgc the led remains extinct, I believe that the 16f877 died!
| | #44 |
That's why it's handy to keep a spare.
| | #45 |
test 16f877 flash led with another program my 16f877 ---> YouTube - clig 16f877 I do not include/understand any more ! j" stays on my peak had died… .it is ok ? why it does not function with the lcd 2x16 ?
| alarm, house |
| Old unconnected house alarm (accenta 6) | Myrmidon | General Electronics Chat | 2 | 27th January 2009 03:23 PM |
| House Alarm | slickonez99 | Electronic Projects Design/Ideas/Reviews | 33 | 24th December 2008 04:39 AM |
| Nokia gsm connected to house alarm | cctv | Electronic Projects Design/Ideas/Reviews | 3 | 6th October 2006 11:36 PM |
| Need help with burglar alarm for a model house. | rancid rock | Electronic Projects Design/Ideas/Reviews | 27 | 15th March 2006 07:55 AM |
