| | #16 |
the hardware, it should be made ?
__________________ paris (france) Last edited by seti75; 12th July 2009 at 03:48 PM. | |
| | #17 |
You can connect the simulated LCD just like a real on with the Oshonsoft simulator.
| | #18 |
I think the 16F877 has died. someone has a small program with some leds and tried to make sure that the 16F877 is dead? thank
__________________ paris (france) | |
| | #19 |
| Can you read the program back from the pic using your programmer? Try erasing the pic and reprogramming..
__________________ Eccentric millionaire financed by 'er indoors | |
| | #20 |
My Inchworm quick start poster on my site has a schematic and program to flash an LED with a 16F877
| | #21 |
I program with winpic800 and icprog. programming is normally ok at the end. reading the 16F877 is also normally with winpic800 and icprog. when I delete the pic is also good. reading indicates 3FFF ... ... so it's good 3FFF but I do not understand why the pic does not work with any program! ?.... my 16f877 -----> Imageshack - 16f87720p blueroomelectronics I can not find ? thank. ..... hex if possible i have difficulty convert asm.to .hex
__________________ paris (france) Last edited by seti75; 12th July 2009 at 09:00 PM. | |
| | #22 | |
Use Mpasm to generate the hex file from the assembly code... You can download Mpasm from Microchip's website
__________________ Eccentric millionaire financed by 'er indoors | ||
| | #23 |
I use MPLAB v8 I never managed to create a. hex from a file asm Here is what I do and every time an error project wizard --> next...16f877 --> next --> indic.location Mpaswin.exe ..---> next creat name project file ..next --->add file asm..--> completed after ....project open file project...---> make ------> error !!
| | #24 |
16f877 --> he died ?
| | #25 | |
There a lot of things that can go wrong bigest is you tried to build on the desktop and not a C:\ myfile\firsttry.asm I have had a 16f877 stop working and all it was is the osc stoped working. I wouldn't throw it away it's more likely something your doing. Last edited by be80be; 14th July 2009 at 03:18 PM. | ||
| | #26 |
Pourquoi esce que vouz utilisiez un oscillateur externe? Why are you using an external oscillator? | |
| | #27 |
| It's A 16f877 they have no internal oscillator
| | #28 |
my lcd http://www.selectronic.fr/upload/pro...nique/2337.pdf a real say j' board many programs for 16F877 n'ais I never had a successful figure ! I do not know if this is the 16F877 or lcd that has a problem ? how to say that c' is the 16f877 which has a prbléme or the lcd which has a problem? thank be80be ? ---> Imageshack - schematic
| | #29 |
You building this on a solder less bread board right try two things first clip a gnd on the OSC to gnd see if that works If not remove c5 and c4 and see if that works
| | #30 |
Alors, I have found my issue of EP numer 265.....Sadly that issue is no longer avaiable so I cant download the source code... Suffice to say, I built a project from another issue called Meleda, based on 16F84 that refused to work...So I wouldnt rule out a s/w issue...
| alarm, house |
| Old unconnected house alarm (accenta 6) | Myrmidon | General Electronics Chat | 2 | 27th January 2009 03:23 PM |
| House Alarm | slickonez99 | Electronic Projects Design/Ideas/Reviews | 33 | 24th December 2008 04:39 AM |
| Nokia gsm connected to house alarm | cctv | Electronic Projects Design/Ideas/Reviews | 3 | 6th October 2006 11:36 PM |
| Need help with burglar alarm for a model house. | rancid rock | Electronic Projects Design/Ideas/Reviews | 27 | 15th March 2006 07:55 AM |
