Hi All, I am planning to build a pickit2 clone from MCU Hobby - Articles: Building a PICkit2 clone. Only thing is i could not able to find some of following components 680uH - Do we have any equivalents or can i make coil of my own. How can i make? BAT85 BS170 IRF9Z34 - Is the any equivalents of the above which easily available india I already have jdm programmer which is working fine. So i can programe the 8550 easily Thanks, Robotsmani | |
Hi, This might help.. Not sure about the choke, but 470 uh also works fine | |
Thanks Wp100.. That's really a cool circuit. In this i have seen some FBT1(ferrite bead), what it is? And the choke 470uh or 680uh, i don't think so i will get it here. Can we make some thing with same value or can we take some coil from CFL lamp and modify it. How can i get the inductance value, what are the calculation, Any Idea? Thanks, Robotsmani | |
Its the lite version of Bill's blueroomelectronics - Smart Kits Build Smart People Junebug. Go to this website and check the Junebug User Manual. Its a PICKIT2 SE compatible programmer.The inductor is for the Vpp pump. I think the values Bill said were usable were 520 to 820uh.
__________________ Syed Last edited by Wond3rboy; 12th July 2009 at 08:45 AM. | |
Hello Robotsmani, I've read some post in this board, you can try to use inductor from old pc motherboard. It's in form of toroidal in 0,8cm diameter. I cannot find the inductor, but luckily got it in form of 1W resistor (Vishay product - Inductors - Vishay ) from my mail order shop. For FB, I was using an inductor in toroidal form, diameter/length about 0,4cm. | |
| | #6 |
You don't even need a ferrite bead The pickit2 doesn't have one my junebug doesn't have and the two clone I made do not have one and all work fine. As for the choke 470uh or 680uh works I have got them from old phone caller ID
| | #7 | |
use a drum core with tags- by salvaging the indcutors locally sold. use 40 swg copper wisr make around 130 turns to 150 turns. solder the wires to the tags present dip it in molten bee's wax. use it components-- BS170 is locally sold-- otherwise use 2N7000 IRFZ34-- use IRFZ44 BAT85 -- use 1N5819, OR 5822 For your own interest, try to make an LC meter from googling for LC Meter2 by Phil Rice it works well once made, it helps you make good coils of known accuracy
| | #8 | |
Thanks mvs sarma | ||
| | #9 | |
perhaps you might have seen that "LC Meter2" at Digital LC Meter Version 2 I made one . It works well, Thanks to Phil Rice (VK3BHR) of Australia.
| | #10 | |
@ Sarma, Is the PCB layout available on the site ready to print with respect to Pad sizes?
__________________ Syed | ||
| | #11 |
| Yes, provided the type of relay they used is available with you.
| | #12 |
thanks all, Building a LC meter itself a 100mh inductor required :-( Let me check with the local shop for the inductors. otherwise i need to find out from salvage computer parts. Let's hope i can get something this weekend... Thanks, Robotsmani | |
| | #13 | |
these coils are very much available across market in the shape of 1/2 watt resistors. marked brow black and brown followed by silver. More important is the 1000pF or 1nF caps 2 off with a low tolerance like 2%. these are sold by Farnell, as box caps( polyester type). On the overall this meter is very handy if are interested in RF filed as Hobby. similarly a frequency counter by IK3OIL.
| | #14 |
Robotsmani If you need that choke you can get one out of almost any old cel phone car chargers and it also has a good regulator that can step up low volts to high or high to low I get all of them I can find just for them two parts. Last edited by be80be; 17th July 2009 at 10:32 PM. | |
| | #15 |
Thanks mvs sarma and be80be... I got the inductor(680uH) in the market in the shape of 1/2 watt resistors :-) :-) . only i could not able to find IRF9Z34 mosfet. Is there any available equivalents? can i use bs170? There is no IRF kind of mosfets are available in the market. Other all parts are ready except the IRF9Z34. Help me... Robotsmani | |
| building, clone, pickit2 |
| ICD2 Clone and dsPIC | javilon | Micro Controllers | 51 | 12th January 2009 02:48 PM |
| Icd2 Clone | LUNAR | Micro Controllers | 3 | 17th December 2008 03:10 PM |
| Help with ICD2 clone!!!!!!!!!!!! | juanbbv | Micro Controllers | 17 | 5th April 2008 06:08 AM |
| ICD 2 clone debugging | sdewinda | Micro Controllers | 14 | 12th February 2008 08:10 PM |
| Minimoog filter clone | Dr.EM | Electronic Projects Design/Ideas/Reviews | 0 | 12th March 2006 09:58 PM |
