| | #16 | |
BS170 is an N chl device. another BS250 is there but it has higher ON resistance and would drop more voltage. IRF9Z34 is a PMosFET. 60V and Very low ON resistance. perhaps you may try NTD4P06 in DPAK. manage to solder it or make the pcb fresh.
__________________ Regards, Sarma. Last edited by mvs sarma; 19th July 2009 at 07:53 AM. | ||
| | #17 |
Hi Robotsmani, I have not been able to find a discrete equivalent to the IRF9Z34 mosfet which is only available as a smd; unless someone knows differently. The function of the mosfet Q3 and its associate Q2 are not an essential function of the programmer - thats one of the reasons I suggested Bluerooms circuit as its much simpler but equally effective. Assuming you have all the other parts to hand now to build the mcu hobby version just build it but leave out Q2 and Q3 and it will be fine. | |
| | #18 |
IRF9Z34 mosfet is a p channel fet the bs170 is n channel see if you can get any BS250P for IRF9Z34
| | #19 |
BS170 equivalent is 2N7000 with opposite pinout.
| | #20 |
Is anybody have the pickit2 lite pcb version? Thanks, Robotsmani | |
| | #21 | |
there is a link for one artwork that works well with mostly thro hole components. as you get specific components you can load them, while initially bypassing them. But the PCB need to be made only once. it is uploaded by Nishal at PicKit 2 FULL with TH components - Need help with layout on 18th Jan2009. Here the transistors are to be pin swapped if you don't get original Philips BC639 and 640 with centre collector. also few minor errors are there, I could guide you to go thro' if you are interested. It is a one go PCB.
| | #22 |
Thanks sarma, i am interested on this. Do you have any parts list for this. i can't find it. Let me first collect the parts first. This weekend i am going to make the pcb for pickit2 clone, LC meter and ofcourse the pickit2 full (any suggestion or tips?). i will update once i have done. Do you have any idea, where do i get 3-6v dc geared motor in bangalore? online shop are costly and shipping charges also Thanks, robotsmani | |
| | #23 | |
the Philips ones have centre collector.
| | #24 |
thanks sarma, i got the bs250, bc639(phillips) and irf9z34. For bc640, i have to wait. The shop owner told me that he will get it next week. What is the diff between BEL made and Philips made? I have the BEL made. Can't i use this one? Anyway i have one week time to build the kit. This week i am building the pickit2 clone Robotsmani | |
| | #25 | |
bel follows CBE and Philips followed BCE fahion please see the datasheet what was cost of 9z34?
| | #26 |
irf9z34 - 32rs BC639 - 5rs BS250 - 12rs There is shop who is having all the rare components. He told that, he is the only supplying all the components to the market(sp road, bangalore) :-):-) Robotsmani | |
| | #27 | |
BC639 and BC640 follow ECB order BS170 and BS250 would follow SGD order. IRF9z34 , if i remember, follows GDS order however better confirm as I remember various styles are there for BS250 and BS170 / 2N7000. you may check the brand you have and get the datasheet from alldataseet.com other details i shall be posting you regarding minor changes in PCB of Nishal.
__________________ Regards, Sarma. Last edited by mvs sarma; 25th July 2009 at 07:25 PM. | ||
| | #28 |
Hi sarma, still i am not getting the bc640(phillps). i am going to make the pcb with the equallent. can you please let me know what are the minor changes in the nishal pcb. thanks, robotsmani | |
| | #29 | ||||
Hi Sarma, As per your suggestion i build the pickit2 full TH. But it is getting following errors I build the circuit using nishal pcb and made the changes suggested by sarma Quote:
![]() And me_guitarist Quote:
My pickit2 is detected and connected. The green led lit up. I started troubleshoot i am getting following error Quote:
When i connected 16f84a thru' ICSP the device is not detected. Sometime it is detected as 16f882 or 16f884. and sometime the Device : Unsupported Part (ID=3000) Please help me.... Thanks, robotsmani | |||||
| | #30 |
FYI i am uploading the schematic and pcb layout files here... Is anybody there to help me out.... Thanks, robotsmani | |
| building, clone, pickit2 |
| ICD2 Clone and dsPIC | javilon | Micro Controllers | 51 | 12th January 2009 02:48 PM |
| Icd2 Clone | LUNAR | Micro Controllers | 3 | 17th December 2008 03:10 PM |
| Help with ICD2 clone!!!!!!!!!!!! | juanbbv | Micro Controllers | 17 | 5th April 2008 06:08 AM |
| ICD 2 clone debugging | sdewinda | Micro Controllers | 14 | 12th February 2008 08:10 PM |
| Minimoog filter clone | Dr.EM | Electronic Projects Design/Ideas/Reviews | 0 | 12th March 2006 09:58 PM |
