Does anyone has a sample code that displays a text / string on LCD display?
You don't say if you need ASM, BAS or HEX....
The standard 4 bit 44780 code will work, you need to specify the connection based on your hardware.
LCD display on PICDEM 2 Plus board [Archive] - MEL PICBASIC Forum
Here is a Picbasic version made to work on your hardware.
PortD4 to 7 lcd data
PortA1 = E
PortA2 = R/W
PortA3 = RS
Microchip Application Maestro can create a template for you for ASM code.
Application Maestro Software
Nigel's tutorial should be a good start to.
PIC Tutorial* Three - LCD Modules
Also 100's of info available on the net.
4 bit lcd asm - Google Search
Csaba
I'm could be wrong many time's, at least I know what I'm doing.
http://shop.ebay.ca/merchant/csaba911
