Old 2nd July 2009, 09:59 PM   #1
Default little dc motor microcontrolling questions
If you followed the very newb and long thread that i started:
pic compiling/programming questions
(i succeded with my ir data transmitting program)
You would know that i tried to make a diy pic programmer and failed because i dont know a lot about transistors and other then simple digital stuff (microcontrollers) and i would need help to make a very simple circuit to control a 3 amps motor trough one 1/0 of a 16f628a.
As the input/output can only source out 25 mA, do i need 2 transistors(one small signal of unknow serie and a tip31c power transistor) to be able to run the dc motor?
1)What would be a very simple design to completly source the dc motor with the 1/0 pin?
2) What would be a good small signal npn transistor?Can you give me a little list so i can search it on my surplus store website ,because the transistor are not classified there so its hard to find if you dont know.
(i should be able to pmw trough)
TIP31C Datasheet pdf - Leaded Power Transistor General Purpose - Central Semiconductor
It has 10 of hfe.
I use 5 volt for monitoring and 9 volts for power.
breadboardguy is offline
Old 2nd July 2009, 10:22 PM   #2
This would be better http://www.datasheetcatalog.org/data...tex/IRF511.pdf
here how you would do it from digital-diy.com Make sure you put a diode on the motor or you will burn something up
Look at this site http://digital-diy.com/handy-tips/68...n-channel.html
And if you want to learn adout how this all works look here
http://www.learningelectronics.net/
be80be is offline
Old 2nd July 2009, 11:11 PM   #3
Can i pmw with the IRF511? It has some delay turn on and of time.
microcontrolling, motor, questions
stepper motor questions SeanHatch General Electronics Chat 10 23rd May 2009 06:17 AM
Motor Power Supply questions ravix Electronic Projects Design/Ideas/Reviews 6 15th January 2008 10:34 PM
Windscreen wiper motor questions bitem2k General Electronics Chat 34 30th May 2007 10:59 AM
DC motor, Servo Motor or Step Motor ? wcz Electronic Projects Design/Ideas/Reviews 1 29th June 2005 02:41 PM
Motor Control Circuit Questions webzila Electronic Projects Design/Ideas/Reviews 11 30th October 2004 06:12 AM
